iPsec S2S ASA to ASR with VRF Using Lo IF ADDRESS
so i have a solution, and then a question on that solution :
first the solution and config for any guy in the future who would need that :
to configure ASA VPN to ASR :
crypto keyring KEYS-SITE-B-DC
  local-address [asr-ip-address]
  pre-shared-key address [ASA-ip-address] key test123
crypto isakmp profile ISAKMP-SITE-B-DC
   vrf VPN
   match identity address [ASA-ip-address] 255.255.255.255
crypto isakmp policy 9
encr aes
authentication pre-share
group 2
lifetime 28800
crypto map VPN-S2S local-address Loopback11
crypto map VPN-S2S 10 ipsec-isakmp
description ### VPN S2S SITE-B-DC ASA ###
set peer [ASA-ip-address]
set transform-set TRANS_SET-SITE-B-DC
set pfs group2
set isakmp-profile ISAKMP-SITE-B-DC
match address IPSEC-VPN-ACL_SITE-B-DC
crypto ipsec transform-set TRANS_SET-SITE-B-DC esp-aes esp-sha-hmac
mode tunnel
interface EGRESS/INGRESS
description ### BECAUSE WE RUN DYNAMIC PROTOCOL(BGP in my case), ANY INTERFACE COULD BE THE INGRESS/EGRESS IF , SO THESE IFs MUST ALSO HAVE THE CRYPTOMAP ###
crypto map VPN-S2S
interface Loopback11
description ### TEST IPSEC ###
ip address [asr-ip-address] 255.255.255.255
ip access-list extended IPSEC-VPN-ACL_SITE-B-DC
permit ip host [ASR-LAN-addresses] host [ASA-LAN-addresses]
ip route vrf VPN [ASA-LAN-addresses] 255.255.255.x 8.8.8.8 global name GENERIC-IPSEC-CRYPTO-ROUTE(ANYCAST) **the route here is for the traffic to be encrypted , the next hop MUST be non-recursive route **
So now for my question :
does it REALLY have to be a route that has a matching on the routing table OTHER than a Default route ?
( because it doesnt work with a route that directs to the default route , even when the recursive route points to the same interface the spefic route does ) .
is there any other way of doing that ? because to point the route to 8.8.8.8 , means im depending my tunnels to be available on the availability of a route for 8.0.0.0 in the RIB .
help would be much appriciated here guys !
Marcin Latosiewicz
Why not let the router hide the complexity from admin by using RRI?
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_conn_vpnav/configuration/15-mt/sec-rev-rte-inject.html#GUID-DEBFE993-16DF-4599-946A-1B7A42521C92
The example is not perfect because of point to point connection between two routers, but you can figure out what IP address to put as gateway.
I would also suggest coming away from crypto maps on new software. logical interfaces with tunnel protection is the way to go. The problem does not appear there.
5 Replies 5
Marcin Latosiewicz
Thanks for your Comment Marcin !
The ASA does not support VTIs which is what you are talking about . so the ASR must use the "OLD" method .
ps i would check the Reverse Route Option , with the static option , sounds best for me when i have multiple tunnels .
ASR-01(config-crypto-map)#reverse-route ?
  remote-peer  Create route in route table for remote tunnel endpoint
  static       Create routes based on static ACLs permanently
but doesnt the example here refers to a situation where the crypto-map is applied to a VRF interface ?
my scenario is different .
My interface is in the global RIB , not in vrf , thus i did the route :
ASR01#ip route vrf VPN [LAN-BEHIND-ASA] 255.255.255.255 8.8.8.8 global name GENERIC-IPSEC-CRYPTO-ROUTE
is there a way to perform this with the reverse route ? or perhaps i just misunderstod it ?
The example is showing pretty well the overall challange of routing with front and back VRFs, you can check what the result was on iVRF and fVRF in the example, same will ablly whether front is global or any other.
"static" is not the option you're looking for, it will only make the entires permanent, regardless of state of IPsec SAs.
It can be of some help in certain scenarios indeed, but it's not the solution to the problem you outline in original post.
ok , ill check that ,
thanks !
I use:
ip route vrf xxxx loopbackxxx global
tunnel can be turn up.
