1101
Highlighted
Beginner
IPSEC TUNNEL (Show IPSEC SA output issue)
Dear Fellows,
I am trying to establish a tunnel on my cisco router but seem to be making some mistake. please do review and let me know where i am going wrong. I have also appended the #sh crypto isakmp and #sh crypto ipsec sa output after trying to ping.
My configuration is as follows
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key Cisco address 198.X.X.X
crypto isakmp xauth timeout 80
crypto ipsec transform-set myset1 esp-3des esp-md5-hmac
crypto map MYMAP 10 ipsec-isakmp
set peer 198.X.X.X
set transform-set myset1
match address 100
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 125.X.X.X 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
crypto map MYMAP
interface GigabitEthernet0/1
ip address 192.168.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0/0
no ip
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list ISLC interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 125.209.X.X (gateway)
ip route 125.209.X.X 255.255.255.248 GigabitEthernet0/0
ip route 192.168.0.0 255.255.255.0 GigabitEthernet0/1
ip route 194.X.X.X 255.255.255.252 GigabitEthernet0/0
ip access-list standard ISLC
permit any
access-list 100 permit ip 192.168.0.0 0.0.0.255 194.117.X.X 0.0.0.3
#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
194.39.131.178  125.209.123.172 QM_IDLE           1001 ACTIVE
#sh crypto ipsec sa
interface: GigabitEthernet0/0
    Crypto map tag: MYMAP, local addr 125.209.123.172
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.0.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (194.117.106.128/255.255.255.252/0/0)
   current_peer 194.39.131.178 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 125.209.123.172, remote crypto endpt.: 194.39.131.178
     path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0
     current outbound spi: 0x0(0)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
The below was the requirement by the remote end user
Mandatory IPSec Features (for the Internet VPN option)
• Encapsulating Security Protocol (ESP)
• Internet Key Exchange (IKE), with support of Diffie-Hellman Group 2 (1024 bits keys)
• Encryption Algorithm: Triples DES (3DES)
• Authentication Algorithm: HMAC-MD5 and HMAC-SHA1
• Support for authentication using shared secrets, RSA digital signatures, and X.509 certificates
• Support for Diffie-Hellman Group 2 (keys of 1024 bits)
• Key exchanges using Internet PKIs
3 REPLIES 3
Beginner
The phase 1 seems to be up, but the phase 2 isn't. it could be a mismatch in configuration from the other end too, could you please turn on debugs (and log it)  and try to bring the tunnel up. please share those debugs for analysis.
debug cry isa
~Harry
Beginner
Hi Harshit,
The debug output is somewhat like this
Nov  2 16:23:42.634: ISAKMP:(1002): sitting IDLE. Starting QM immediately (QM_ID98: IPSEC(key_engine): request timer fired: count = 1,7.106.128 0.0.0.3/0/13des
LE      )ac
QUICK
Nov  2 16:23:42.634: ISAKMP:(1002):beginning Quick Mode exchange, M-ID of 163556
Nov  2 16:23:42.638: ISAKMP:(1002):Node 1635562640, Input = IKE_MESG_INTERNAL, I
KE_INIT_QM
Nov  2 16:23:42.638: ISAKMP:(1002):Old State = IKE_QM_READY  New State = IKE_QM_
I_QM1
Nov  2 16:23:42.798: ISAKMP (1002): received packet from 194.39.131.178 dport 45
00 sport 4500 Global (I) QM_IDLE
Nov  2 16:23:42.798: ISAKMP: set new node 507011038 to QM_IDLE
Nov  2 16:23:42.798: ISAKMP:(1002): processing HASH payload. message ID = 507011
038
Nov  2 16:23:42.798: ISAKMP:(1002): processing NOTIFY PROPOSAL_NOT_CHOSEN protoc
ol 3
        spi 3749995589, message ID = 507011038, sa = 0x31A56D28
Nov  2 16:23:42.798: ISAKMP:(1002): deleting spi 3749995589 message ID = 1635562
640
Nov  2 16:23:42.798: ISAKMP:(1002):deleting node 1635562640 error TRUE reason "D
elete Larval"
Nov  2 16:23:42.798: ISAKMP:(1002):deleting node 507011038 error FALSE reason "I
nformational (in) state 1"
Nov  2 16:23:42.798: ISAKMP:(1002):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
Nov  2 16:23:42.798: ISAKMP:(1002):Old State = IKE_P1_COMPLETE  New State = IKE_
P1_COMPLETE
0 peer_port 4500 (I) QM_IDLE
Nov  2 16:24:12.634: ISAKMP:(1002):Sending an IKE IPv4 Packet.
Nov  2 16:24:12.634: ISAKMP:(1002):Node 2305233083, Input = IKE_MESG_INTERNAL, I
KE_INIT_QM
Nov  2 16:24:12.634: ISAKMP:(1002):Old State = IKE_QM_READY  New State = IKE_QM_
I_QM1
Nov  2 16:24:12.794: ISAKMP (1002): received packet from 194.39.131.178 dport 45
Nov  2 16:24:12.794: ISAKMP: set new node 579471621 to QM_IDLE
Nov  2 16:24:12.798: ISAKMP:(1002): processing HASH payload. message ID = 579471
621
Nov  2 16:24:12.798: ISAKMP:(1002): processing NOTIFY PROPOSAL_NOT_CHOSEN protoc
ol 3
        spi 1941906697, message ID = 579471621, sa = 0x31A56D28
Nov  2 16:24:12.798: ISAKMP:(1002): deleting spi 1941906697 message ID = 2305233
083
Nov  2 16:24:12.798: ISAKMP:(1002):deleting node -1989734213 error TRUE reason "
Delete Larval"
Nov  2 16:24:12.798: ISAKMP:(1002):deleting node 579471621 error FALSE reason "I
Nov  2 16:24:12.798: ISAKMP:(1002):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
Nov  2 16:24:12.798: ISAKMP:(1002):Old State = IKE_P1_COMPLETE  New State = IKE_
P1_COMPLETE
Nov  2 16:24:32.798: ISAKMP:(1002):purging node 1635562640
Nov  2 16:24:32.798: ISAKMP:(1002):purging node 507011038
#debug crypto ipsec
Nov  2 16:20:16.186: IPSEC(sa_request): ,
  (key eng. msg.) OUTBOUND local= 10.10.10.10:500, remote= 194.39.131.178:500,
    local_proxy= 192.168.0.0/255.255.255.0/0/0 (type=4),
    remote_proxy= 194.117.106.128/255.255.255.252/0/0 (type=4),
    protocol= ESP, transform= esp-3des esp-md5-hmac  (Tunnel),
    lifedur= 3600s and 4608000kb,
    spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x0
Nov  2 16:20:46.186: IPSEC(key_engine): request timer fired: count = 1,
  (identity) local= 10.10.10.10:0, remote= 194.39.131.178:0,
Nov  2 16:20:46.186: IPSEC(sa_request): ,
Nov  2 16:21:16.186: IPSEC(key_engine): request timer fired: count = 2,
Nov  2 16:22:58.966: ISAKMP:(1002):deleting node -1323225912 error TRUE reason "
Delete Larval"
Beginner
there seems to be some mismatch at phase 2 config, could you please confirm with the other end about the settings.
if possible please post a config from there end as well.
~Harry
