IPSEC tunnel won't attempt connection
k.langley
I have a 5510 and a 5505 that I'm attempting to configure a simple VPN tunnel over. I have tried step by step configurations form CISCO ASA configs, as well as every source I can find. I have walked throught the config with IOS commands as well as Wizards. All my packets are dropped at the the inside or outside interface.
When I show SH ISAKMP command all I get are 0's straight down. Any ideas how I can troubleshot this
Try the following on the 5505 (assuming your object groups are consistent with the example in the configs)
access-list outside_1_cryptomap extended permit ip 192.168.5.0 255.255.255.0 192.168.13.0 255.255.255.0
nat (inside,outside) source static NETWORK_OBJ_192.168.5.0_24  NETWORK_OBJ_192.168.5.0_24 destination static  NETWORK_OBJ_192.168.13.0_24 NETWORK_OBJ_192.168.13.0_24
Try this on the ASA 5510
access-list outside_1_cryptomap extended permit ip 192.168.13.0 255.255.255.0 192.168.5.0 255.255.255.0
nat (inside,outside) source static NETWORK_OBJ_192.168.13.0_24  NETWORK_OBJ_192.168.13.0_24 destination static  NETWORK_OBJ_192.168.5.0_24 NETWORK_OBJ_192.168.5.0_24
Tarik Admani
*Please rate helpful posts*
7 Replies 7
k.langley
here are the configs
5510 config
ASA Version 8.3(1)
hostname ciscoasa
enable password RLPMUQ26KL4blgFN encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 132.172.105.133 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.13.100 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
same-security-traffic permit inter-interface
object network NETWORK_OBJ_192.168.13.0_24
subnet 192.168.13.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.13.0 255.255.255.0 192.168.13.0 255.255.255.0
pager lines 24
logging asdm informational
mtu management 1500
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_192.168.13.0_24 NETWORK_OBJ_192.168.13.0_24 destination static NETWORK_OBJ_192.168.13.0_24 NETWORK_OBJ_192.168.13.0_24
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 132.172.105.132
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 10
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
tunnel-group 132.172.105.132 type ipsec-l2l
tunnel-group 132.172.105.132 ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:e829ea360581230097c8204bc696d005
: end
5505 config
ASA Version 8.3(1)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.13.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 132.172.105.132 255.255.255.0
switchport access vlan 2
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
pager lines 24
mtu outside 1500
mtu inside 1500
arp timeout 14400
nat (inside,outside) dynamic interface
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.13.0 255.255.255.0 inside
crypto map outside_map 1 set peer 132.172.105.133
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
webvpn
tunnel-group 132.172.105.133 type ipsec-l2l
tunnel-group 132.172.105.133 ipsec-attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:6ac1a0875e433c7a736e53f7fdbe27c5
: end
Are these overlapping networks? If so then you may need to NAT one of the networks using policy NAT in order to get this to work. The document is a little dated with the nat statements but keep that in mind and see if this is what you are looking for.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080b37d0b.shtml
thanks,
Tarik Admani
I had different networks on the inside ..13.0/24 and a..5.0/24 previously. Those didn't work either. It appears from the config guide that if my outside interfaces are on an overlapping network which they will be, then I will need to nat the outside. Do you agree?
No the outside network is a simulation of a link on the same network. The networks that are being tunnelled from site A to site B are both 192.168.1.0/24 networks. Based on you configuration you have the same networks being protected.
Can you please label which networks you want to protect and tunnel and which ASA they current sit behind. Also i didnt see any routes configured on the ASA either.
Tarik Admani
Sorry. In my attempt to simlify I made it more confusing.
My original config which I didn't post was as follows:
ASA 5505
Inside 192.168.5.0/24
outside 132.172.105.132/26
The route I had was 0.0.0.0 0.0.0.0 132.172.105.133
ASA 5510
Inside 192.168.13.0/24
Outside 132.172.105.133/26
The route I had was 0.0.0.0 0.0.0.0 132.172.105.132
Tarik Admani
That didn't do it either. I tried a few other things after that. I suspect I have a bad device or IOS. The Organization I work for let thier Cisco support expire. It is almost back so I can get a fresh IOS. I have some other boxes I can test with. I got these boxes atfer they fired another tech who worked on these for 14 month and never got them working. I thank you for assistance.
