*Oct 29 15:19:03.181 UTC: ISAKMP: (0):SA request profile is PRO_XXXX
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):Created a peer struct for 40.71.228.241, peer port 500
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):New peer created peer = 0x7F7D7D633F58 peer_handle = 0x8002C842
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):Locking peer struct 0x7F7D7D633F58, refcount 1 for isakmp_initiator
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):local port 500, remote port 500
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):set new node 0 to QM_IDLE
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):Find a dup sa in the avl tree during calling isadb_insert sa = 7F7D7E2FDD30
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):Can not start Aggressive mode, trying Main mode.
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):Found ADDRESS key in keyring KR-XXXX_key
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):IKE->PKI Get configured TrustPoints state (I) MM_NO_STATE (peer 40.71.228.241)
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):PKI->IKE Got configured TrustPoints state (I) MM_NO_STATE (peer 40.71.228.241)
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):growing send buffer from 1024 to 3072
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):constructed NAT-T vendor-rfc3947 ID
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):constructed NAT-T vendor-07 ID
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):constructed NAT-T vendor-03 ID
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):constructed NAT-T vendor-02 ID
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):Old State = IKE_READY New State = IKE_I_MM1
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):beginning Main Mode exchange
*Oct 29 15:19:03.181 UTC: ISAKMP-PAK: (0):sending packet to 40.71.228.241 my_port 500 peer_port 500 (I) MM_NO_STATE
*Oct 29 15:19:03.181 UTC: ISAKMP: (0):Sending an IKE IPv4 Packet.
*Oct 29 15:19:13.181 UTC: ISAKMP: (0):retransmitting phase 1 MM_NO_STATE...
*Oct 29 15:19:13.181 UTC: ISAKMP: (0):: incrementing error counter on sa, attempt 1 of 5: retransmit phase 1
*Oct 29 15:19:13.181 UTC: ISAKMP-PAK: (0):sending packet to 40.71.228.241 my_port 500 peer_port 500 (I) MM_NO_STATE
*Oct 29 15:19:13.181 UTC: ISAKMP: (0):Sending an IKE IPv4 Packet.
*Oct 29 15:19:23.181 UTC: ISAKMP: (0):retransmitting phase 1 MM_NO_STATE...
*Oct 29 15:19:23.182 UTC: ISAKMP: (0):: incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
*Oct 29 15:19:23.182 UTC: ISAKMP: (0):retransmitting phase 1 MM_NO_STATE
*Oct 29 15:19:23.182 UTC: ISAKMP-PAK: (0):sending packet to 40.71.228.241 my_port 500 peer_port 500 (I) MM_NO_STATE
*Oct 29 15:19:23.182 UTC: ISAKMP: (0):Sending an IKE IPv4 Packet.
*Oct 29 15:19:33.181 UTC: ISAKMP-ERROR: (0):SA is still budding. Attached new ipsec request to it. (local 199.52.101.1, remote 40.71.228.241)
*Oct 29 15:19:33.182 UTC: ISAKMP-ERROR: (0):Error while processing SA request: Failed to initialize SA
*Oct 29 15:19:33.183 UTC: ISAKMP-ERROR: (0):Error while processing KMI message 0, error 2.
*Oct 29 15:19:33.183 UTC: ISAKMP: (0):retransmitting phase 1 MM_NO_STATE...
*Oct 29 15:19:33.183 UTC: ISAKMP: (0):: incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
*Oct 29 15:19:33.183 UTC: ISAKMP-PAK: (0):sending packet to 40.71.228.241 my_port 500 peer_port 500 (I) MM_NO_STATE
*Oct 29 15:19:33.183 UTC: ISAKMP: (0):Sending an IKE IPv4 Packet.
*Oct 29 15:19:42.961 UTC: ISAKMP: (0):purging SA., sa=7F7D7F3D7BA0, delme=7F7D7F3D7BA0
*Oct 29 15:19:43.183 UTC: ISAKMP: (0):retransmitting phase 1 MM_NO_STATE...
*Oct 29 15:19:43.183 UTC: ISAKMP: (0):: incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
*Oct 29 15:19:43.183 UTC: ISAKMP-PAK: (0):sending packet to 40.71.228.241 my_port 500 peer_port 500 (I) MM_NO_STATE
*Oct 29 15:19:43.183 UTC: ISAKMP: (0):Sending an IKE IPv4 Packet.
*Oct 29 15:20:29.729 UTC: ISAKMP-ERROR: (0):Failed to find peer index node to update peer_info_list
*Oct 29 15:20:42.134 UTC: ISAKMP-ERROR: (0):Failed to find peer index node to update peer_info_list
*Oct 29 15:20:03.184 UTC: ISAKMP: (0):retransmitting phase 1 MM_NO_STATE...
*Oct 29 15:20:03.184 UTC: ISAKMP: (0):peer does not do paranoid keepalives.
*Oct 29 15:20:03.184 UTC: ISAKMP-ERROR: (0):deleting SA reason "Death by retransmission P1" state (I) MM_NO_STATE (peer 40.71.228.241)
*Oct 29 15:20:03.184 UTC: ISAKMP: (0):Unlocking peer struct 0x7F7D7D633F58 for isadb_mark_sa_deleted(), count 0
*Oct 29 15:20:03.184 UTC: ISAKMP: (0):Deleting peer node by peer_reap for 40.71.228.241: 7F7D7D633F58
*Oct 29 15:20:03.188 UTC: ISAKMP: (0):deleting node 2091495314 error FALSE reason "IKE deleted"
*Oct 29 15:20:03.188 UTC: ISAKMP: (0):deleting node 2980217384 error FALSE reason "IKE deleted"
*Oct 29 15:20:03.188 UTC: ISAKMP: (0):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
*Oct 29 15:20:03.188 UTC: ISAKMP: (0):Old State = IKE_I_MM1 New State = IKE_DEST_SA
