1343
Highlighted
Beginner
IPSEC VPN between Cisco 2901 and Sonicwall
Our existing Cisco 2901 is already doing a DMVPN between our locations and is using a zone-based firewall. I've been asked to configure a VPN to a Sonicwall from that same 2901. The Sonicwall does not support DMVPN so I'd need to do an IPSEC VPN. Is it possible for both to co-exist on the 2901? I've started adding some of the IPSEC config to my 2901 and pasted the config below (I've removed any identifying public IP addresses) but the VPN to the Sonicwall is not operational.
Using 15540 out of 262136 bytes
! Last configuration change at 14:05:21 PDT Wed Jun 12 2013 by SiteTech
! NVRAM config last updated at 14:05:48 PDT Wed Jun 12 2013 by SiteTech
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname rtr-xxx-pd-01
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 warnings
enable secret 4 nqDHNNAboQs3pRtIt7QPcjUYTEPSRmg5GiHQcIb3Uq2
no aaa new-model
clock timezone PST -8 0
clock summer-time PDT recurring
no ipv6 cef
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.48.25.1 10.48.25.63
ip dhcp excluded-address 10.48.26.1 10.48.26.63
ip dhcp excluded-address 10.48.27.1 10.48.27.63
ip dhcp pool voice
network 10.48.26.0 255.255.255.0
default-router 10.48.26.1
option 42 ip 10.48.255.9 10.48.255.254
option 2 hex ffff.8f80
option 156 ascii "ftpservers=10.48.2.16, country=1, language=1, layer2tagging=1, vlanid=102"
dns-server 64.60.0.17
ip dhcp pool data
network 10.48.25.0 255.255.255.0
default-router 10.48.25.1
ip dhcp pool chartwell
network 10.48.27.0 255.255.255.0
default-router 10.48.27.1
no ip bootp server
ip domain lookup source-interface Loopback0
ip domain name xxx.intra
ip name-server 64.60.0.17
ip name-server 64.60.0.18
ip inspect log drop-pkt
parameter-map type inspect global
log dropped-packets enable
parameter-map type ooo global
tcp reassembly queue length 64
tcp reassembly memory limit 4096
crypto pki trustpoint TP-self-signed-4286009541
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4286009541
revocation-check none
rsakeypair TP-self-signed-4286009541
crypto pki certificate chain TP-self-signed-4286009541
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
license udi pid CISCO2901/K9 sn FTX1622Y01L
username sitetech privilege 15 secret 4 nqDHNNAboQs3pRtIt7QPcjUYTEPSRmg5GiHQcIb3Uq2
redundancy
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 1
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-all SSH_ACCESS
match access-group name SSH
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
match protocol ntp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any SDM_IP
match access-group name SDM_IP
class-map type inspect match-any SDM_GRE
match access-group name SDM_GRE
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_DMVPN_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_GRE
match class-map SDM_ESP
class-map type inspect match-all SDM_DMVPN_PT
match access-group 101
match class-map SDM_DMVPN_TRAFFIC
class-map type inspect match-any Mon-Echo-Svc
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any out-in
match access-group name out-in
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map match-any Call-Signaling
match ip dscp cs3
match ip dscp af31
class-map match-any Voice
match ip dscp ef
match access-group 161
class-map type inspect match-all ccp-cls-ccp-permit-1
match class-map Mon-Echo-Svc
match access-group name RM-Mon-Traffic
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-permit-gre
class type inspect SDM_GRE
  pass
class class-default
  drop log
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
policy-map type inspect out-in
class type inspect out-in
  inspect
class class-default
  drop
class type inspect SDM_DMVPN_PT
  pass
class type inspect ccp-cls-ccp-permit-1
  inspect
class type inspect SSH_ACCESS
  inspect
class class-default
  drop log
policy-map type inspect sdm-permit-ip
class type inspect SDM_IP
  pass
class class-default
  drop log
policy-map WAN-EDGE
class Voice
  priority percent 33
class Call-Signaling
  bandwidth percent 5
class class-default
  fair-queue
zone security dmvpn-zone
zone security in-zone
zone security out-zone
zone-pair security sdm-zp-in-gre1 source in-zone destination dmvpn-zone
service-policy type inspect sdm-permit-ip
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security sdm-zp-gre-in1 source dmvpn-zone destination in-zone
zone-pair security ccp-zp-out-gre source out-zone destination dmvpn-zone
service-policy type inspect sdm-permit-gre
zone-pair security ccp-zp-gre-out source dmvpn-zone destination out-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security out-in source out-zone destination in-zone
service-policy type inspect out-in
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp policy 11
encr 3des
group 2
crypto isakmp key *********** address x.x.x.x
crypto isakmp key *********** address 0.0.0.0 0.0.0.0
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 10 periodic
crypto ipsec transform-set jag-trans esp-aes 256 esp-md5-hmac
crypto ipsec transform-set JAG-agent esp-3des esp-sha-hmac
crypto ipsec profile jag-agent
set transform-set JAG-agent
crypto ipsec profile jag-dmvpn
set transform-set jag-trans
crypto map vpn 11 ipsec-isakmp
description VPN tunnel to Jeff Russell Sonicwall
set peer z.z.z.z
set security-association lifetime seconds 86400
match address 102
interface Loopback0
description $FW_INSIDE$
ip address 10.48.255.17 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly in
zone-member security in-zone
load-interval 30
interface Tunnel0
description DMVPN via TelePacific$FW_INSIDE$
bandwidth 1000
ip address 10.255.48.18 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1400
ip flow ingress
ip nhrp authentication DMVPN_NW
ip nhrp map 10.255.48.254 206.82.221.230
ip nhrp map multicast 206.82.221.230
ip nhrp network-id 100000
ip nhrp holdtime 30
ip nhrp nhs 10.255.48.254
zone-member security dmvpn-zone
ip tcp adjust-mss 1360
ip summary-address eigrp 1048 10.48.16.0 255.255.252.0
delay 1000
qos pre-classify
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile jag-dmvpn
interface Null0
no ip unreachables
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description TelePacific Internet$FW_OUTSIDE$
ip address y.y.y.y 255.255.255.248
ip access-group MILLS in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
zone-member security out-zone
load-interval 30
duplex auto
speed auto
no cdp enable
no mop enabled
crypto map vpn
service-policy output WAN-EDGE
interface GigabitEthernet0/1
description Inside Trunk
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
load-interval 30
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1.101
description PD Data$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 101
ip address 10.48.25.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface GigabitEthernet0/1.102
description PD Voice$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 102
ip address 10.48.26.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface GigabitEthernet0/1.110
description PD Chartwell$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 110
ip address 10.48.27.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
router eigrp 1048
network 10.0.0.0
network 10.48.0.0 0.0.255.255
network 10.255.48.0 0.0.0.255
network 10.255.49.0 0.0.0.255
passive-interface GigabitEthernet0/0
ip local policy route-map pbr-ping-monitor
no ip forward-protocol nd
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip http server
ip http access-class 90
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 110 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 10.48.25.24 80 198.101.110.27 80 extendable
ip nat inside source static tcp 10.48.25.24 443 198.101.110.27 443 extendable
ip nat inside source static tcp 10.48.25.24 4000 198.101.110.27 4000 extendable
ip nat inside source static tcp 10.48.25.24 44000 198.101.110.27 44000 extendable
ip nat inside source static 10.48.25.24 198.101.110.27
ip route 0.0.0.0 0.0.0.0 198.101.110.25
ip route 10.48.4.0 255.255.252.0 10.48.13.15
ip access-list extended Mon-Echo-Traffic
remark CCP_ACL Category=128
permit ip r.r.r.r 0.0.0.31 any
ip access-list extended NATIP
deny   ip 10.48.0.0 0.0.255.255 10.0.0.0 0.0.0.255
permit ip 10.48.0.0 0.0.255.255 any
ip access-list extended RM-Mon-Traffic
permit ip 206.82.221.224 0.0.0.31 any
ip access-list extended SDM_AH
permit ahp any any
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended SDM_GRE
permit gre any any
ip access-list extended SDM_IP
remark CCP_ACL Category=0
permit ip any any
ip access-list extended SSH
permit tcp any any eq 22
ip access-list extended natip
ip access-list extended out-in
permit tcp any host 10.48.25.24 eq 443
permit tcp any host 10.48.25.24 eq 4000
permit tcp any host 10.48.25.24 eq 44000
permit tcp any host 10.48.25.24 eq www
ip access-list extended pbr-ping-TP
permit icmp host y.y.y.y host r.r.r.r
access-list 1 permit 10.48.0.0 0.0.255.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 10.48.0.0 0.0.255.255
access-list 90 remark HTTP Server ACL
access-list 90 permit 10.255.48.0 0.0.0.255
access-list 90 permit 10.48.0.0 0.0.255.255
access-list 90 permit 10.20.0.0 0.3.255.255
access-list 90 permit 10.16.1.0 0.0.0.255
access-list 90 permit 206.82.221.224 0.0.0.15
access-list 90 deny   any
access-list 100 permit ip 198.101.110.24 0.0.0.3 any
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any host 198.101.110.26
access-list 101 permit ip any host 198.101.110.26
access-list 102 permit ip 10.48.25.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 102 permit ip 10.48.26.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 102 permit ip 10.48.25.0 0.0.0.255 172.17.1.0 0.0.0.255
access-list 102 permit ip 10.48.26.0 0.0.0.255 172.17.1.0 0.0.0.255
access-list 103 remark VTY Access-class list1
access-list 103 permit ip 10.255.48.0 0.0.0.255 any
access-list 103 permit ip 10.48.0.0 0.0.255.255 any
access-list 103 permit ip 10.16.1.0 0.0.0.255 any
access-list 103 permit ip 10.20.0.0 0.3.255.255 any
access-list 103 permit ip r.r.r.r 0.0.0.31 any
access-list 103 deny   ip any any
access-list 110 permit ip 10.48.0.0 0.0.255.255 any
access-list 111 permit ip 10.48.0.0 0.0.255.255 any
access-list 161 remark : ShoreTel Voice over IP Ports
access-list 161 permit udp any any eq 2427
access-list 161 permit udp any any eq 2727
access-list 161 permit udp any any range 5440 5446
access-list 161 permit udp any any eq 5004
access-list 161 permit udp any any eq 5060
access-list 161 permit tcp any any eq 5060
access-list 161 permit udp host 10.48.14.16 gt 1024 any gt 1024
access-list 161 permit udp 10.48.10.0 0.0.0.255 any
control-plane
banner login ^CCThis system is considered private and proprietary and is subject to audit. The unauthorized access, use or modification of this or any other computer systems or networks or of the data contained therein or in transit thereto/therefrom is
Disconnect IMMEDIATELY if you are not an authorized user!
^C
line con 0
login local
transport output telnet
line aux 0
login local
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
ntp server 192.12.19.20
ntp server 164.67.62.194
end
Everyone's tags (6)
