Community Helping Community
2746
Beginner
IPSec VPN MTU issue over ADSL
Hello Guys,
I am deploying IPSec VPN over MPLS L3 ADSL link between HeadOffice and different branch locations. VPN tunnels are up and running i can successfully ping both sides. But the browsing is very very slow. Users at remote sites cannot browse the servers at headoffice as well as internet. I have tried following things:
1) Setting MTU in outside interface
2) Setting ip tcp adjust-mss in outside interface
3) Crypto ipsec df-bit clear (both locations)
3) Route-map clearing df-bit
Still browsing is same. I cant figure out where the problem is? In my configuration or at ISP side??
Devices used for this configuration are:
Head Office: Cisco C3945 Software (C3900-UNI​VERSALK9-M), Version 15.2(4)M3
Branch Office: Cisco C2911 Software (C2900-UNI​VERSALK9-M), Version 15.3(2)T
I have attached configuration below:
Thank you
Sudan Dhakal
10 REPLIES 10
Re:IPSec VPN MTU issue over ADSL
How much you adjust the tcp mss ?
Sent from Cisco Technical Support Android App
Beginner
Hello Bader,
After testing different size ping packet from a remote location windows machine
>ping x.x.x.x
  reply success
>ping x.x.x.x -l 1500 -f
packet needs to be fragmentated but df set
>ping x.x.x.x -l 1350 -f
>ping x.x.x.x -l 1340 -f
reply success
reply success
I set different mss value to test but nothing worked. The running-configuration has the ip tcp adjust-mss 1300 value.
Sudan Dhakal
Contributor
Perform some packet captures on client and server.
Beginner
Hello Peter,
Wireshark captures at branch location shows almost every packets "TCP segment of a reassembled PDU" and lots of bad Checksums.
Sudan Dhakal
Beginner
Re: IPSec VPN MTU issue over ADSL
Hi Sudan
You have some onE of the two issues:
A) MTU path discovery issues where the clients can't find the MTU and defaults to a very low MTU
Solution: use a tool like MTU path to find if the is any device not replying to the MTUP discovery http://www.iea-software.com/products/mtupath.cfm
B) TCP MSS values are still high. Try to lower this to 1260
Take care
Contributor
It does not affect TCP as traffic on outside is already encapsulated in IPsec. Put that command on inside inteface.
Beginner
Peter,
Are you sure about that?
Contributor
Actually, I'm not entirely positive. Haven't tested it.
I would say if you put it on inside interface, it's guaranteed.
Highlighted
Beginner
Peter
You are correct. It will also work but..... That also means you need to apply the command to each internal interface and it will also change the MSS to the internal traffic which is not required.
Applying in the outside interface will guarantee that only VPN traffic will have a lower MSS.
Contributor
Sudan, is it solved?
Let me see the captures, the MSS values and packet/segment sizes should be checked.
Content for Community-Ad
FusionCharts will render here
