Ask the Expert- SD-WAN
780
Beginner
IPsec VPN site-to-site between ASA and Cisco Router problem. Please help
Hi community,
I get stuck in site-to-site VPN configuration between ASA (OS 9.1) and Cisco IOS Router (IOS 15.2-4.M4)
Attachment is ASA and Router configuration. I also include the debug router output.
It seemed that the two sides have configuration isakmp missmatch, but I already disabled keepalives settings. I also disable PFS setting on both sides. But it doesn't work. I have no idea about this trouble.
Please help me. Any helps be appreciated.
1 ACCEPTED SOLUTION
VIP Mentor
I didn't look any further,
I didn't look any further, but this can be a reason:
crypto map mymap 1 ipsec-isakmp dynamic dyn1
The dynamic CM always has to be the last sequence in a crypto map:
no crypto map mymap 1 ipsec-isakmp dynamic dyn1
crypto map mymap 65000 ipsec-isakmp dynamic dyn1
Try this first, then we can look further.
6 REPLIES 6
VIP Mentor
Beginner
Hi Iwen,The site-2-site VPN
Hi Iwen,
The site-2-site VPN works now. But my remote access vpn is down. I cannot reconnect to the site behind ASA device.
Please advices me.
Highlighted
Beginner
Hi Iwen,Last time I did "no
Hi Iwen,
Last time I did "no crypto dynamic" some command related to dynamic vpn disappear also. I have to reconfig them, and now two vpns are working. Thanks for your support.
One more question please: The site behind router can ping/telnet to site behind ASA, but the site behind ASA cannot connect to site behind router. What can cause this problem?
Please advice.
VIP Mentor
Some more potential problems:
1) This NAT-line should always be the last:
nat (inside,outside) source dynamic Allow_Go_Internet interface
Change it to:
no nat (inside,outside) source dynamic Allow_Go_Internet interface
nat (inside,outside) after-auto source dynamic Allow_Go_Internet interface
NAT-mistakes can cause communitation problems in VPN.
2) Your VPN-crypto is from the last century. 3DES/MD5/DH2 are legacy algorithms that shouldn't be used any more if not needed for some reason. And DES/RC4 is broken and should be removed completely.
Beginner
Hi Iwen,Thanks for your help.
Hi Iwen,
Thanks for your help. I did all work now.
Below is the final configuration for encryption and authentication method for remote access VPN and Site-2-site VPN
crypto ipsec ikev1 transform-set myset esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES256-SHA esp-aes-256 esp-sha-hmac
crypto ikev1 policy 1
 authentication pre-share
 encryption aes
 hash sha
 group 2
 lifetime 43200
crypto ikev1 policy 5
 encryption aes-256
 hash sha
 group 5
 lifetime 28800
In the policy 1 for remote access VPN, if I change the group to 5, the VPN will fail, and log out put show that "Miss-match in SA proposal: received 2 but configured 5". I wonder whether Cisco VPN client support diffie hellman 5?
VIP Mentor
The more secure ike policy
The more secure ike policy should have the higher priority which is a smaller number. So I would configure there the following way (policy 30 only if really needed):
crypto ikev1 policy 10
 encryption aes-256
 hash sha
 group 5
 lifetime 28800
crypto ikev1 policy 20
 encryption aes-256
 hash sha
 group 2
 lifetime 28800
crypto ikev1 policy 30
 encryption aes
 hash sha
 group 2
 lifetime 43200
The Cisco VPN Client is EOL and not supported any longer. And yes, by default DH group 2 is used. But that can be configured by a parameter in the PCF-file.
There are two (three) better options:
  1. Best option with very little needed configuration:
    Move to AnyConnect with TLS. AnyConnect is the actual Cisco client that is also supported with Windows 8.x. The legacy IPsec client isn't.
  2. Best option with a little stronger crypto but more configuration:
    Move to AnyConnect with IPsec/IKEv2.
  3. Move to a third-party client like shrew.net. I didn't use that client since a couple of years any more, but it's quite flexible and also has a config for a better DH-group.
For option 1) and 2) there is an extra license needed, but thats not very expensive.
