ipsec vpn tunnel dies between ASA and Avaya hardphone
horvaia
I have built an environmnet where ASA firewalls terminte ipsec vpn connection for Avaya Hard Phones.
(Avaya Hard Phones have the ability to create vpn to other party and using this secure tunnel for voice
traffic.)
The vpn connection is working but sometimes unexpectedly terminiates and this is what I see on ASA log files:
Jan 17 13:33:31 10.36.200.61 %ASA-5-713068: Group = VpnPhone, Username = VpnPhoneUsername1, IP = 176.63.x.x, Received non-routine Notify message: Invalid Payload (1)
Jan 17 13:33:39 10.36.200.61 %ASA-5-713068: Group = VpnPhone, Username = VpnPhoneUsername1, IP = 176.63.x.x, Received non-routine Notify message: Invalid Payload (1)
Jan 17 13:33:47 10.36.200.61 %ASA-5-713068: Group = VpnPhone, Username = VpnPhoneUsername1, IP = 176.63.x.x, Received non-routine Notify message: Invalid Payload (1)
Jan 17 13:33:53 10.36.200.61 %ASA-6-602304: IPSEC: An outbound remote access SA (SPI= 0xE9D75704) between 195.56.x.x and 176.63.x.x (user= VpnPhoneUsername1) has been deleted.
Jan 17 13:33:53 10.36.200.61 %ASA-6-602304: IPSEC: An inbound remote access SA (SPI= 0x2BE03030) between 176.63.x.x and 195.56.x.x (user= VpnPhoneUsername1) has been deleted.
Jan 17 13:33:55 10.36.200.61 %ASA-3-713902: Group = VpnPhone, Username = VpnPhoneUsername1, IP = 176.63.x.x, QM FSM error (P2 struct &0x73e0f658, mess id 0x7510c1a9)!
Jan 17 13:33:55 10.36.200.61 %ASA-5-713259: Group = VpnPhone, Username = VpnPhoneUsername1, IP = 176.63.x.x, Session is being torn down. Reason: Lost Service
Jan 17 13:33:55 10.36.200.61 %ASA-6-713273: Group = VpnPhone, Username = VpnPhoneUsername1, IP = 176.63.x.x, Deleting static route for client address: 10.136.11.25
Jan 17 13:33:55 10.36.200.61 %ASA-4-113019: Group = VpnPhone, Username = VpnPhoneUsername1, IP = 176.63.x.x, Session disconnected. Session Type: IPsecOverNatT, Duration: 2d 0h:28m:12s, Bytes xmt: 29983482, Bytes rcv: 3864271, Reason: Lost Service
Jan 17 13:33:55 10.36.200.61 %ASA-6-737016: IPAA: Freeing local pool address 10.136.11.25
I do not find the cause of this error. Do you have any idea?
few info about vpn settings:
I am using main mode, no-pfs, xauth.
PH1: 3des-sha1-esp
PH2: 3des-sha1
Andras
m.kafka
Level 4
Level 4
If we could get more on this:
received from the Avaya we could tell you more.
Debug with a high level, e.g.255, includes the raw isakmp resp. ikev2 message.
If you can't do that you need to contact Avaya support.
hi,
ok. I attach the debug log when the disconnection happened.
debug settings:
logging list vpn-debug level debugging class vpn
logging trap vpn-debug
I checked the log but to be honest it did not help me too much.
Thanks for helping,
Andras
Message was edited by: Andras Horvai
Anybody? Any idea?
Andras
Hi Andras,
Were you ever able to resolve this? We are seeing similar invalid payload messages with the Avaya hard phones connecting to the VPN.
