1644
Highlighted
Beginner
IPsec xauth & L2TP/IPsec on same interface
I try to configure a Cisco 892 Integrated Service Router for IPsec xauth & L2TP/IPsec on the same interface. The config is actually for a test setup (test ips, accounts etc), but it shoud go in production setup.
If I reboot the router I just can connect over L2TP/IPsec. Over IPsec xauth I get the message "Mar 19 14:59:19.807: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Aggressive mode failed with peer at 10.28.100.3"
When I remote the line "crypto isakmp key keygeheim address 0.0.0.0         no-xauth" make a IPsec xauth connection and add the line again, everything works as it should. Why?
Maybe one of you can see something in this configuration
startup-config:
Current configuration : 6368 bytes
! Last configuration change at 15:00:49 UTC Mon Mar 19 2012 by elvis
version 15.2
hostname testvpn
boot-start-marker
boot config usbflash0:CVO-BOOT.CFG
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa authorization exec default local
aaa authorization network groupauthor local
aaa session-id common
crypto pki trustpoint TP-self-signed-3079241446
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3079241446
revocation-check none
rsakeypair TP-self-signed-3079241446
crypto pki certificate chain TP-self-signed-3079241446
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326
  5BD8935C AAB214EA A12323A3
  0A8C3DF1 2B4F5ECE E2DC20C9 D00646
        quit
no ip domain lookup
ip domain name example.com
ip name-server 10.28.1.1
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip cef
no ipv6 cef
vpdn enable
vpdn-group L2TP
! Default L2TP VPDN group
accept-dialin
  protocol l2tp
  virtual-template 1
no l2tp tunnel authentication
license udi pid CISCO892-K9 sn FCZ1543C1AQ
username elvis privilege 15 secret 5 geheim
username Tester password 0 geheim
ip ssh version 2
crypto isakmp policy 10
encr aes 256
authentication pre-share
group 2
crypto isakmp policy 20
encr 3des
group 2
crypto isakmp policy 50
encr aes 256
group 5
crypto isakmp nat keepalive 20
crypto isakmp client configuration address-pool local vpnpool
crypto isakmp client configuration group MyGroup
key 12345678
dns 10.28.1.1 10.28.1.2
save-password
crypto ipsec transform-set 3des-sha esp-3des esp-sha-hmac
crypto ipsec transform-set aessha esp-aes 256 esp-sha-hmac
crypto ipsec transform-set l2tpconfig esp-3des esp-sha-hmac
mode transport
crypto dynamic-map MyGroup 10
set ip access-group vpntraffic in
set transform-set aessha
match address vpnlist
crypto dynamic-map MyGroup 20
set transform-set 3des-sha
crypto dynamic-map l2tpconfig-map 30
set nat demux
set transform-set l2tpconfig
crypto map vpn client authentication list userauthen
crypto map vpn isakmp authorization list groupauthor
crypto map vpn client configuration address respond
crypto map vpn 998 ipsec-isakmp dynamic MyGroup
crypto map vpn 999 ipsec-isakmp dynamic l2tpconfig-map
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
spanning-tree portfast
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
ip address 10.28.1.97 255.255.255.0
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered GigabitEthernet0
peer default ip address pool vpnpool
ppp encrypt mppe auto
ppp authentication ms-chap-v2
interface GigabitEthernet0
description WAN Port
ip address 10.28.100.1 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
crypto map vpn
interface Vlan1
no ip address
shutdown
ip local pool vpnpool 192.168.252.20 192.168.252.30
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.28.1.100
ip access-list extended vpnlist
permit ip any 192.168.252.0 0.0.0.255
ip access-list extended vpntraffic
permit ip 192.168.252.0 0.0.0.255 10.28.1.0 0.0.0.255
no cdp run
control-plane
mgcp profile default
banner login ^C
Hostname: testvpn
Description: Test L2TP/IPsec and IPsec with xauth
^C
line con 0
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
end
Everyone's tags (3)
