Hi my friends,
I had a problem with my VPN connection, this message appears.
"Login denied. Your session has been terminated due to your machine's security posture".
Thanks!
You will need to talk to your administrator. They have applied a policy that your machine does not meet.
The ASA administrator has put in place a posture check which your machine is failing. A posture check can look for many different things - current AntiVirus software, specific AD group memberhsip, existence of a registry key, etc.
You need to contact the administrator to determine what specific requirement is finding you to be non-compliant.
