Highlighted
l2l VPN Connectivity issue between Cisco 2911 Router Cisco ASA 5505
I am having an issue connecting four remote office Cisco ASA 5505's to the base office Cisco 2911. This configuration is a static from the remote ASA's end to static to the 2911 end. The debug shows the following error as I attempt to initiate the tunnel from the remote end:
Dec 11 16:12:25 [IKEv1]: IP = 66.180.111.137, Error: Unable to remove PeerTblEntry
Dec 11 16:13:00 [IKEv1]: IP = 66.180.111.137, Removing peer from peer table failed, no match
ASA Version 7.2(2)
hostname Jenco-DMcOmber
domain-name default.domain.invalid
enable password 6qR.Z1XKp/ZjrtuB encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
no ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
boot system disk0:/asa825-k8.bin
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network Outside-VPN
description VPN Access
network-object 10.10.0.0 255.255.0.0
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit ip any any
access-list MY_VPN_100 remark ACL to encrypt traffic from home to office
access-list MY_VPN_100 extended permit ip 192.168.0.0 255.255.0.0 10.10.0.0 255.255.0.0
access-list inside_nat0_outbound remark NAT Exempt Policy for IPSec Encryption
access-list inside_nat0_outbound extended permit ip 192.168.0.0 255.255.0.0 10.10.0.0 255.255.0.0
access-list nonat extended permit ip 192.168.0.0 255.255.0.0 10.10.0.0 255.255.0.0
access-list outside_access_in_1 extended permit ip any any
access-list inside_access_in_1 extended permit ip any any
access-list outside_access_in_2 extended permit ip any any
access-list asdm_cap_selector_inside extended permit ip host 192.168.2.8 host 10.10.10.2
access-list asdm_cap_selector_inside extended permit ip host 10.10.10.2 host 192.168.2.8
access-list asdm_cap_selector_outside extended permit ip host 192.168.2.8 host 10.10.10.2
access-list asdm_cap_selector_outside extended permit ip host 10.10.10.2 host 192.168.2.8
pager lines 24
logging enable
logging list VPN level debugging
logging list VPN level debugging class vpn
logging console critical
logging trap VPN
logging history debugging
logging asdm VPN
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in_2 in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
username dmcomber password Ws/TWc.OQj6/T8YJ encrypted privilege 15
aaa authentication listener http inside port www redirect
aaa authentication listener https inside port 1443 redirect
http server enable
http 192.168.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set MY-TRANSFORM esp-aes-192 esp-sha-hmac
crypto map MY_VPN 100 match address MY_VPN_100
crypto map MY_VPN 100 set peer 66.180.111.137
crypto map MY_VPN 100 set transform-set MY-TRANSFORM
crypto map MY_VPN 100 set reverse-route
crypto map MY_VPN interface outside
crypto isakmp policy 100
authentication pre-share
encryption aes-192
hash sha
group 5
lifetime 86400
tunnel-group 66.180.111.137 type ipsec-l2l
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.2.2-192.168.2.254 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:95f7f6bb1c7148a05beaf846cfce857a
: end
I can ping this public IP from the ASA and ping my home public from the 2911. Below you will see my configs. Any assistance is much appreciated.
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.151-4.M1.bin
boot-end-marker
no logging queue-limit
logging buffered 9000
no logging rate-limit
no logging console
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authentication login sdm_vpn_xauth_ml_4 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa authorization network sdm_vpn_group_ml_4 local
aaa session-id common
clock timezone MST -7 0
clock summer-time MST recurring
no ipv6 cef
no ip source-route
ip traffic-export profile TAC mode capture
  bidirectional
ip cef
ip dhcp excluded-address 10.10.60.1 10.10.60.49
ip dhcp excluded-address 10.10.70.1 10.10.70.49
ip dhcp excluded-address 10.10.80.1 10.10.80.49
ip dhcp excluded-address 10.10.90.1 10.10.90.49
ip dhcp excluded-address 10.10.80.150 10.10.80.254
ip dhcp excluded-address 10.10.80.0 10.10.80.15
ip dhcp pool WIRELESS
network 10.10.70.0 255.255.255.0
default-router 10.10.70.1
dns-server 10.10.10.200
lease 2
ip dhcp pool VOIP
network 10.10.90.0 255.255.255.0
default-router 10.10.90.1
option 150 ip 10.10.90.1
lease 2
ip domain name jencotech.com
ip name-server 66.180.96.12
ctl-client
server capf 10.10.90.1 trustpoint cme_root
server tftp 10.10.90.1 trustpoint cme_root
server cme 10.10.90.1 username jadmin password 1 0521260B2C0D40
server cme-tftp 10.10.90.1 trustpoint cme_root
sast1 trustpoint cme_root
sast2 trustpoint cme_cert
capf-server
auth-mode auth-string
cert-enroll-trustpoint cme_root password 1 083343411D
trustpoint-label cme_root
source-addr 10.10.90.1
crypto pki server cme_root
database level complete
grant auto
lifetime certificate 7305
lifetime ca-certificate 7305
crypto pki trustpoint TP-self-signed-2494847547
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2494847547
revocation-check none
rsakeypair TP-self-signed-2494847547
crypto pki trustpoint cme_root
enrollment url
http://66.180.111.140:80
rsakeypair cme_root
crypto pki trustpoint cme_cert
enrollment url
crypto pki certificate chain TP-self-signed-2494847547
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32343934 38343735 3437301E 170D3131 31303235 31393131
  32315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 34393438
  34373534 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009E8A 26188720 62E67E50 2F2E8102 8A13E28D 774EC9B3 680558B8 00B5A4A9
  4CFF6C75 B56C3D62 3CB594F3 3AB5BEF3 5C5783DD E5D283E5 BBF78049 72E6E115
  064451F3 85816876 FAC8A2E3 3AEBD3CA 6BC22FD8 56DBC781 06E63A58 DF6F6CEF
  FD384FD8 6296B529 C17BED4B B68F2987 5CCC09C7 AC561822 E342E2A8 F5C22177
  2CA70203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14B0A413 AB0CDA39 74CE5A65 0E26C9E0 408E877D 09301D06
  03551D0E 04160414 B0A413AB 0CDA3974 CE5A650E 26C9E040 8E877D09 300D0609
  2A864886 F70D0101 05050003 81810043 1596FBB7 73CF5DC2 ED6EF63D 1575A18F
  37C3EC9C FC6E3065 3E83DD44 50702A78 DF18893D F7F1F342 FAD234D3 9A8359DE
  90595B08 77ECEA76 25887045 6631A72E F6DEA32D 3D99F044 2B95AC89 D9082DEC
  96D2F104 C1DE7F3B 2C02277D FB8BBA46 258CF747 67F0FA7B 6A5DCE03 BD5CA886
  257A8F39 4A07964E 6A42500F 7151FB
        quit
crypto pki certificate chain cme_root
certificate ca 01
  308201FF 30820168 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  13311130 0F060355 04030C08 636D655F 726F6F74 301E170D 31313130 32373037
  31343432 5A170D33 31313032 37303731 3434325A 30133111 300F0603 5504030C
  08636D65 5F726F6F 7430819F 300D0609 2A864886 F70D0101 01050003 818D0030
  81890281 8100B897 182A2F69 F8D7ECB7 3F2BED75 A4EB787F 9B5BFF09 64DF87CC
  48B240B0 9DCB68BB E51D5D00 93F9E6B5 6C448F62 8137BAAF 9F332A62 8CD1AFCB
  62489E17 2BAC5889 9D193AF9 9FE49C46 4F2E5FDF 9F33ED6C BC31B4B0 C2C7BD1C
  2A2E5F80 BD6DA0D2 4C1C1E54 817F0782 29182467 E0BEDC55 D2B1CE6A 0FBA9E46
  F9A01E7C 314F0203 010001A3 63306130 0F060355 1D130101 FF040530 030101FF
  300E0603 551D0F01 01FF0404 03020186 301F0603 551D2304 18301680 1436A77A
  961AA816 148A13DF C1BFA67F 0059E0E9 FC301D06 03551D0E 04160414 36A77A96
  1AA81614 8A13DFC1 BFA67F00 59E0E9FC 300D0609 2A864886 F70D0101 04050003
  81810063 75E8F736 D60C8CE5 838E3A2B F9DD381C AA148578 69B4C36C 7B00EC86
  9803B8A0 9598B2D5 33FB1C35 E755556C 284FED91 E02F32C3 181D45DE 35C7DC2B
  47A34E1D 3ECC7DA6 E37F979D 7779079D 4116ABD3 1E6A2731 D5ADFD57 24A899BB
  143A76ED 3092BC64 6B0AD687 9EECF75E 30DB5F7F 93A64EE5 933FF65C 8DFB771E B9BCF9
        quit
crypto pki certificate chain cme_cert
certificate 02
  30820200 30820169 A0030201 02020102 300D0609 2A864886 F70D0101 05050030
  31363436 5A170D33 31313032 37303731 3434325A 30283126 30240609 2A864886
  F70D0109 0216174A 656E636F 2D434D45 2E6A656E 636F7465 63682E63 6F6D3081
  9F300D06 092A8648 86F70D01 01010500 03818D00 30818902 8181009E C4C18608
  8ACC3DCF 269CD380 1AE18EF3 28F07E8F C260378C A4959623 5C296296 FB741554
  F6768C39 A125A170 623EC846 9560399B 673C5638 D1D3DC2C B7A4F330 F3528A6C
  0583F1D1 567F9438 1E54B9A4 A31A24E1 428105B5 1C2E782F 89C88EA6 A3AA0597
  2F0A89B2 4215B47F 88E12B1C B21D309D 5C71F4E9 10C83044 25C8F902 03010001
  A34F304D 300B0603 551D0F04 04030205 A0301F06 03551D23 04183016 801436A7
  7A961AA8 16148A13 DFC1BFA6 7F0059E0 E9FC301D 0603551D 0E041604 147D0E8A
  89377582 37E89CFE CB37CF50 37B00A82 15300D06 092A8648 86F70D01 01050500
  03818100 B0A6476F 5A0AF2FA 72A89C69 F5E81C9D B4FEE5C3 F7DEA18A 7D5B7F57
  D9FC7074 A02010EF 9B0588EA 098884E7 B30F3353 E251BFBD BC2E5E63 28923F8A
  8B61DCA1 F013437F 240CFF08 63FC0CCA 427DF951 BF793391 1E261CB9 56DBAE36
  BEFB685C 527BCF33 B9013F3E D7485080 3660680B 6BBA1783 3C0D9FA6 7EC4BA73 7DE2B777
        quit
certificate ca 01
        quit
voice-card 0
dspfarm
dsp services dspfarm
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
vpn-group 1
  vpn-gateway 1
https://66.180.111.140/SSLVPNphone
  vpn-trustpoint 1 trustpoint cme_cert root
  vpn-hash-algorithm sha-1
vpn-profile 1
  host-id-check disable
sip
  header-passing
  error-passthru
  registrar server expires max 3600 min 3600
  localhost dns:sipconnect.den0.cbeyond.net
  outbound-proxy dns:sip-proxy.den0.cbeyond.net
  early-offer forced
  midcall-signaling passthru
voice class codec 1
codec preference 1 g711ulaw
voice class custom-cptone leavetone
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice class custom-cptone jointone
dualtone conference
  frequency 600 900
voice hunt-group 1 parallel
final 5000
list 710,720,751,753,754
timeout 16
pilot 4000
voice hunt-group 10 parallel
final 5000
list 752,7999
timeout 16
pilot 4001
voice translation-rule 1
rule 1 /7194655810/ /5000/
rule 2 /7194711200/ /5001/
rule 3 /7194655829/ /4000/
voice translation-rule 9
rule 1 /^911$/ /911/
rule 2 /^9\(.*\)/ /\1/
rule 3 /^719\(.*\)/ /9\1/
rule 4 /\(..........\)/ /91\1/
voice translation-rule 10
rule 1 /^.*/ /7195340313/
voice translation-rule 99
rule 2 /\(^9\)\([2-9]......\)/ /\2/
rule 3 /\(^9\)\([2-9]..[2-9]......\)/ /\2/
rule 5 /^9\(.......\)$/ /719\1/
rule 6 /\(^.......\)$/ /9\1/
rule 7 /5000/ /7194655827/
rule 9 /5001/ /7194655828/
rule 11 /^911$/ /911/
rule 12 /^9911$/ /911/
rule 14 /^9\(.*\)/ /\1/
voice translation-rule 410
rule 1 /^9\(.......\)$/ /719\1/
rule 2 /5000/ /7194655810/
rule 3 /5001/ /7194655820/
rule 4 /^2\(..\)$/ /71939791\1/
rule 5 /^9\(.*\)/ /\1/
voice translation-profile CUE_Incoming
translate calling 9
translate called 1
voice translation-profile OUTBOUND_e164
translate calling 10
translate called 9
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_CallForwarding
license udi pid CISCO2911/K9 sn FCZ150427LS
license accept end user agreement
license boot module c2900 technology-package securityk9
license agent notify
http://10.10.10.202:8081/clm/servlet/HttpListenServlet
dummy dummy
hw-module ism 0
hw-module pvdm 0/0
username jadmin privilege 15 secret 5 $1$5FEp$XPj.yq39Rmnz1sLlhLkVe1
username Myra privilege 5 secret 5 $1$77V7$jl6RNSCtPxzCq4B1z4nFr0
username kcarlson privilege 15 secret 5 $1$GEst$V95.4bjl392foYqhtfPhP0
username dmcomber privilege 5 secret 5 $1$5Waj$a5/NWhzmlD/VPgQYBUZlM/
username srobbins privilege 5 secret 5 $1$r4XE$CS2YxYn8IawDnrp/XHJDt.
username bmcginn privilege 5 secret 5 $1$7piK$ukXztBQm8rKuiCqXhQ.Mq.
username jcarney privilege 5 secret 5 $1$atyL$z4AwwnBxgZbhjpZui.MSA0
username wrobbins privilege 5 secret 5 $1$xGnL$mje12Iyw2zN9cRDoEPKkx.
username kparsons privilege 15 secret 5 $1$JKVl$RBagk8FyZ5Gd6/LKKYDgt.
username dharris privilege 15 secret 5 $1$2Jp1$18qdkFkjm8uqgwZHYuzE40
redundancy
ip ftp username admin
ip ftp password admin
crypto keyring S2S
  pre-shared-key address 0.0.0.0 0.0.0.0 key jenco11
encr 3des
group 2
crypto isakmp policy 2
encr aes
hash md5
group 2
encr aes 192
group 5
crypto isakmp key jenco-en1 address 66.180.111.137
crypto isakmp client configuration group VPNusers
key jencovpn
dns 10.10.10.200
pool VPN
acl 107
include-local-lan
crypto isakmp profile VPNC
   match identity group VPNusers
   client authentication list sdm_vpn_xauth_ml_4
   isakmp authorization list sdm_vpn_group_ml_4
   client configuration address respond
   virtual-template 4
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA3 esp-3des esp-sha-hmac
crypto ipsec transform-set TRANSFORM esp-aes 192 esp-sha-hmac
crypto ipsec profile HUBSPOKE
set transform-set ESP-3DES-SHA3
crypto ipsec profile VPNclients
crypto dynamic-map dmap 10
crypto dynamic-map vpndynamic 100
set transform-set TRANSFORM
match address MY-VPN
reverse-route
crypto map dynamic-map 10 ipsec-isakmp dynamic dmap
crypto map mydymap 100 ipsec-isakmp dynamic vpndynamic
crypto map static-map 10 ipsec-isakmp
! Incomplete
set peer 66.180.111.140
interface Loopback0
ip address 10.1.10.2 255.255.255.0
interface Loopback10
ip address 66.180.111.139 255.255.255.255
no ip redirects
no ip unreachables
interface Loopback20
ip address 66.180.111.138 255.255.255.255
ip virtual-reassembly in
interface Loopback30
ip address 66.180.111.140 255.255.255.255
interface Loopback37
ip address 66.180.111.137 255.255.255.255
crypto map mydymap
interface Tunnel100
bandwidth 1440
ip address 10.20.100.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication jencovpn
ip nhrp map multicast dynamic
ip nhrp network-id 999
ip nhrp holdtime 450
ip tcp adjust-mss 1360
tunnel source 66.180.111.138
tunnel mode gre multipoint
tunnel protection ipsec profile HUBSPOKE
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
ip nbar protocol-discovery
ip flow ingress
ip flow egress
duplex full
speed 1000
vlan-id dot1q 999
  exit-vlan-config
interface GigabitEthernet0/0.10
description === Servers ===
encapsulation dot1Q 1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1412
interface GigabitEthernet0/0.60
description === Workstations ===
encapsulation dot1Q 60 native
ip address 10.10.60.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.70
description === Wireless ===
encapsulation dot1Q 70
ip address 10.10.70.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.80
description === VPN Clients ===
encapsulation dot1Q 80
ip address 10.10.80.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.90
description === VoIP ===
encapsulation dot1Q 90
ip address 10.10.90.1 255.255.255.0
ip nat inside
interface ISM0/0
ip unnumbered Loopback0
service-module ip address 10.1.10.1 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 10.1.10.2
no keepalive
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
description $ES_LAN$
ip address 64.207.43.92 255.255.255.248 secondary
ip address 64.207.43.91 255.255.255.248 secondary
ip address 64.207.43.90 255.255.255.248 secondary
ip address 66.180.111.130 255.255.255.252
no ip redirects
no ip unreachables
ip flow ingress
ip nat outside
ip verify unicast reverse-path
duplex auto
speed auto
no cdp enable
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
shutdown
interface Virtual-Template2
no ip address
interface Virtual-Template4 type tunnel
ip unnumbered GigabitEthernet0/2
tunnel mode ipsec ipv4
tunnel protection ipsec profile VPNclients
interface Vlan1
no ip address
ip local pool VPN 10.10.80.64 10.10.80.127
ip local pool REMOTE 10.10.70.64 10.10.70.127
ip local pool SSLVPNphone_pool 10.10.90.100 10.10.90.150
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash0:
ip flow-top-talkers
top 10
sort-by bytes
ip nat inside source static tcp 10.10.10.200 110 interface GigabitEthernet0/2 110
ip nat inside source static tcp 10.10.10.200 80 interface GigabitEthernet0/2 80
ip nat inside source static tcp 10.10.10.200 25 interface GigabitEthernet0/2 25
ip nat inside source static tcp 10.10.10.200 443 interface GigabitEthernet0/2 443
ip nat inside source route-map SDM_RMAP_3 interface GigabitEthernet0/2 overload
ip route 0.0.0.0 0.0.0.0 66.180.111.129
ip route 10.1.10.1 255.255.255.255 ISM0/0
ip route 10.20.10.0 255.255.255.0 10.20.100.20 name UTAH_DATA
ip route 10.20.90.0 255.255.255.0 10.20.100.20 name UTAH_VOIP
ip access-list extended DMVPN_ROUTING
permit ip any any
ip access-list extended MY-VPN
permit ip 10.10.0.0 0.0.255.255 192.168.0.0 0.0.255.255
ip access-list extended S2S_ROUTING
permit ip any any
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 69 permit any
access-list 100 remark CCP_ACL Category=4
access-list 100 permit ip 10.0.0.0 0.255.255.255 any
access-list 101 deny   ip 77.0.0.0 0.0.0.255 any
access-list 101 deny   ip 123.0.0.0 0.0.0.255 any
access-list 101 deny   ip 213.0.0.0 0.0.0.255 any
access-list 101 deny   ip 87.0.0.0 0.0.0.255 any
access-list 101 deny   ip 218.0.0.0 0.0.0.255 any
access-list 101 deny   ip 84.0.0.0 0.0.0.255 any
access-list 101 deny   ip 95.0.0.0 0.0.0.255 any
access-list 101 permit tcp any any established
access-list 101 permit icmp any host 64.207.43.90
access-list 101 permit tcp any host 64.207.43.90 eq 443
access-list 101 permit tcp any host 64.207.43.90 eq pop3
access-list 101 permit tcp any host 64.207.43.90 eq www
access-list 101 permit tcp any host 64.207.43.90 eq smtp
access-list 101 permit udp any host 64.207.43.90 eq non500-isakmp
access-list 101 permit udp any host 64.207.43.90 eq isakmp
access-list 101 permit esp any host 64.207.43.90
access-list 101 permit ahp any host 64.207.43.90
access-list 101 permit udp host 66.180.96.12 eq domain any
access-list 101 permit udp host 64.238.96.12 eq domain any
access-list 101 deny   ip any any log
access-list 103 permit ip 10.10.90.0 0.0.0.255 any
access-list 103 remark SDM_ACL Category=2
access-list 103 deny   ip any 10.10.30.128 0.0.0.127
access-list 103 deny   ip 10.10.20.0 0.0.0.255 10.10.30.128 0.0.0.127
access-list 103 deny   ip 10.10.10.0 0.0.0.255 10.10.30.128 0.0.0.127
access-list 103 deny   ip any 10.10.80.0 0.0.0.255
access-list 103 permit ip 10.10.10.0 0.0.0.255 any
access-list 103 deny   ip any 10.10.10.0 0.0.0.255
access-list 103 permit ip 10.10.70.0 0.0.0.255 any
access-list 103 deny   ip any 10.10.60.0 0.0.0.255
access-list 107 permit ip 10.10.10.0 0.0.0.255 any
access-list 107 permit ip 10.10.20.0 0.0.0.255 any
access-list 107 permit ip 10.10.30.0 0.0.0.255 any
access-list 107 permit ip 10.10.80.0 0.0.0.255 any
access-list 107 permit ip 10.10.90.0 0.0.0.255 any
access-list 107 permit ip 10.10.60.0 0.0.0.255 any
access-list 112 deny   ip 10.10.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 112 permit ip 10.10.0.0 0.0.255.255 any
route-map SDM-RMAP_2 permit 10
route-map S2S_ROUTE permit 5
match ip address S2S_ROUTING
set ip next-hop 64.207.43.92
route-map 107 permit 1
match ip address 107
route-map DMVPN_ROUTE permit 10
match ip address DMVPN_ROUTING
route-map SDM_RMAP_1 permit 1
match ip address 103
route-map SDM_RMAP_2 permit 1
match ip address 104
route-map SDM_RMAP_3 permit 1
route-map MY-VPN permit 15
match ip address MY-VPN
route-map nonat permit 15
match ip address 112
snmp-server community BUCKeyes RO
snmp-server community Ge7C&hw RO
snmp-server ifindex persist
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps envmon fan shutdown supply temperature
snmp-server enable traps config
snmp-server enable traps syslog
snmp-server host 10.10.10.202 version 2c BUCKeyes
snmp-server host 10.10.10.204 version 2c BUCKeyes
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:RingList.xml
tftp-server flash:Vibe.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:AreYouThereF.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Chime.raw
tftp-server flash:Classic1.raw
tftp-server flash:/Phones/7940-7960/v6.0.4/P00306000400.bin alias P00306000400.bin
tftp-server flash:/Phones/7940-7960/v6.0.4/P00306000400.sb2 alias P00306000400.sb2
tftp-server flash:/Phones/7940-7960/v6.0.4/P00306000400.sbn alias P00306000400.sbn
tftp-server flash:/Phones/7940-7960/v8.1.1/P00308010100.bin alias P00308010100.bin
tftp-server flash:/Phones/7940-7960/v8.1.1/P00308010100.loads alias P00308010100.loads
tftp-server flash:/Phones/7940-7960/v8.1.1/P00308010100.sb2 alias P00308010100.sb2
tftp-server flash:/Phones/7940-7960/v8.1.1/P00308010100.sbn alias P00308010100.sbn
tftp-server flash:/Phones/7940-7960/v8.1.2/P00308010200.bin alias P00308010200.bin
tftp-server flash:/Phones/7940-7960/v8.1.2/P00308010200.loads alias P00308010200.loads
tftp-server flash:/Phones/7940-7960/v8.1.2/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/Phones/7940-7960/v8.1.2/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:Phones/7942-7962/v8.5.2/apps42.8-5-2TH1-9.sbn alias apps42.8-5-2TH1-9.sbn
tftp-server flash:Phones/7942-7962/v8.5.2/cnu42.8-5-2TH1-9.sbn alias cnu42.8-5-2TH1-9.sbn
tftp-server flash:Phones/7942-7962/v8.5.2/cvm42sccp.8-5-2TH1-9.sbn alias cvm42sccp.8-5-2TH1-9.sbn
tftp-server flash:Phones/7942-7962/v8.5.2/dsp42.8-5-2TH1-9.sbn alias dsp42.8-5-2TH1-9.sbn
tftp-server flash:Phones/7942-7962/v8.5.2/jar42sccp.8-5-2TH1-9.sbn alias jar42sccp.8-5-2TH1-9.sbn
tftp-server flash:Phones/7942-7962/v8.5.2/SCCP42.8-5-2S.loads alias SCCP42.8-5-2S.loads
tftp-server flash:Phones/7975/v8.5.2/apps75.8-5-2TH1-9.sbn alias apps75.8-5-2TH1-9.sbn
tftp-server flash:Phones/7975/v8.5.2/cnu75.8-5-2TH1-9.sbn alias cnu75.8-5-2TH1-9.sbn
tftp-server flash:Phones/7975/v8.5.2/cvm75sccp.8-5-2TH1-9.sbn alias cvm75sccp.8-5-2TH1-9.sbn
tftp-server flash:Phones/7975/v8.5.2/dsp75.8-5-2TH1-9.sbn alias dsp75.8-5-2TH1-9.sbn
tftp-server flash:Phones/7975/v8.5.2/jar75sccp.8-5-2TH1-9.sbn alias jar75sccp.8-5-2TH1-9.sbn
tftp-server flash:Phones/7975/v8.5.2/SCCP75.8-5-2S.loads alias SCCP75.8-5-2S.loads
tftp-server flash:Phones/7975/v8.5.2SR1/apps75.8-5-2CA1-6.sbn alias apps75.8-5-2CA1-6.sbn
tftp-server flash:Phones/7975/v8.5.2SR1/cnu75.8-5-2CA1-6.sbn alias cnu75.8-5-2CA1-6.sbn
tftp-server flash:Phones/7975/v8.5.2SR1/cvm75sccp.8-5-2CA1-6.sbn alias cvm75sccp.8-5-2CA1-6.sbn
tftp-server flash:Phones/7975/v8.5.2SR1/dsp75.8-5-2CA1-6.sbn alias dsp75.8-5-2CA1-6.sbn
tftp-server flash:Phones/7975/v8.5.2SR1/jar75sccp.8-5-2CA1-6.sbn alias jar75sccp.8-5-2CA1-6.sbn
tftp-server flash:Phones/7975/v8.5.2SR1/SCCP75.8-5-2SR1S.loads alias SCCP75.8-5-2SR1S.loads
tftp-server flash:Phones/7975/v8.5.3/apps75.8-5-3TH1-6.sbn alias apps75.8-5-3TH1-6.sbn
tftp-server flash:Phones/7975/v8.5.3/cnu75.8-5-3TH1-6.sbn alias cnu75.8-5-3TH1-6.sbn
tftp-server flash:Phones/7975/v8.5.3/cvm75sccp.8-5-3TH1-6.sbn alias cvm75sccp.8-5-3TH1-6.sbn
tftp-server flash:Phones/7975/v8.5.3/dsp75.8-5-3TH1-6.sbn alias dsp75.8-5-3TH1-6.sbn
tftp-server flash:Phones/7975/v8.5.3/jar75sccp.8-5-3TH1-6.sbn alias jar75sccp.8-5-3TH1-6.sbn
tftp-server flash:Phones/7975/v8.5.3/SCCP75.8-5-3S.loads alias SCCP75.8-5-3S.loads
tftp-server flash:Phones/7975/v8.5.3SR1/apps75.8-5-3ES4.sbn alias apps75.8-5-3ES4.sbn
tftp-server flash:Phones/7975/v8.5.3SR1/cnu75.8-5-3ES4.sbn alias cnu75.8-5-3ES4.sbn
tftp-server flash:Phones/7975/v8.5.3SR1/cvm75sccp.8-5-3ES4.sbn alias cvm75sccp.8-5-3ES4.sbn
tftp-server flash:Phones/7975/v8.5.3SR1/dsp75.8-5-3ES4.sbn alias dsp75.8-5-3ES4.sbn
tftp-server flash:Phones/7975/v8.5.3SR1/jar75sccp.8-5-3ES4.sbn alias jar75sccp.8-5-3ES4.sbn
tftp-server flash:Phones/7975/v8.5.3SR1/SCCP75.8-5-3SR1S.loads alias SCCP75.8-5-3SR1S.loads
tftp-server flash:Phones/7975/v8.5.4/apps75.8-5-4TH1-6.sbn alias apps75.8-5-4TH1-6.sbn
tftp-server flash:Phones/7975/v8.5.4/cnu75.8-5-4TH1-6.sbn alias cnu75.8-5-4TH1-6.sbn
tftp-server flash:Phones/7975/v8.5.4/cvm75sccp.8-5-4TH1-6.sbn alias cvm75sccp.8-5-4TH1-6.sbn
tftp-server flash:Phones/7975/v8.5.4/dsp75.8-5-4TH1-6.sbn alias dsp75.8-5-4TH1-6.sbn
tftp-server flash:Phones/7975/v8.5.4/jar75sccp.8-5-4TH1-6.sbn alias jar75sccp.8-5-4TH1-6.sbn
tftp-server flash:Phones/7975/v8.5.4/SCCP75.8-5-4S.loads alias SCCP75.8-5-4S.loads
tftp-server flash:Phones/7975/v9.0.2SR1/apps75.9-0-2ES2.sbn alias apps75.9-0-2ES2.sbn
tftp-server flash:Phones/7975/v9.0.2SR1/cnu75.9-0-2ES2.sbn alias cnu75.9-0-2ES2.sbn
tftp-server flash:Phones/7975/v9.0.2SR1/cvm75sccp.9-0-2ES2.sbn alias cvm75sccp.9-0-2ES2.sbn
tftp-server flash:Phones/7975/v9.0.2SR1/dsp75.9-0-2ES2.sbn alias dsp75.9-0-2ES2.sbn
tftp-server flash:Phones/7975/v9.0.2SR1/jar75sccp.9-0-2ES2.sbn alias jar75sccp.9-0-2ES2.sbn
tftp-server flash:Phones/7975/v9.0.2SR1/SCCP75.9-0-2SR1S.loads alias SCCP75.9-0-2SR1S.loads
tftp-server flash:Phones/7975/v9.0.2SR2/apps75.9-0-2ES3.sbn alias apps75.9-0-2ES3.sbn
tftp-server flash:Phones/7975/v9.0.2SR2/cnu75.9-0-2ES3.sbn alias cnu75.9-0-2ES3.sbn
tftp-server flash:Phones/7975/v9.0.2SR2/cvm75sccp.9-0-2ES3.sbn alias cvm75sccp.9-0-2ES3.sbn
tftp-server flash:Phones/7975/v9.0.2SR2/dsp75.9-0-2ES3.sbn alias dsp75.9-0-2ES3.sbn
tftp-server flash:Phones/7975/v9.0.2SR2/jar75sccp.9-0-2ES3.sbn alias jar75sccp.9-0-2ES3.sbn
tftp-server flash:Phones/7975/v9.0.2SR2/SCCP75.9-0-2SR2S.loads alias SCCP75.9-0-2SR2S.loads
tftp-server flash:Phones/7975/v9.0.3/apps75.9-0-3TH1-22.sbn alias apps75.9-0-3TH1-22.sbn
tftp-server flash:Phones/7975/v9.0.3/cnu75.9-0-3TH1-22.sbn alias cnu75.9-0-3TH1-22.sbn
tftp-server flash:Phones/7975/v9.0.3/cvm75sccp.9-0-3TH1-22.sbn alias cvm75sccp.9-0-3TH1-22.sbn
tftp-server flash:Phones/7975/v9.0.3/dsp75.9-0-3TH1-22.sbn alias dsp75.9-0-3TH1-22.sbn
tftp-server flash:Phones/7975/v9.0.3/SCCP75.9-0-3S.loads alias SCCP75.9-0-3S.loads
tftp-server flash:Phones/7975/v9.1.1SR1/jar75sccp.9-1-1TH1-16.sbn alias jar75sccp.9-1-1TH1-16.sbn
tftp-server flash:Phones/7975/v9.1.1SR1/apps75.9-1-1TH1-16.sbn alias apps75.9-1-1TH1-16.sbn
tftp-server flash:Phones/7975/v9.1.1SR1/cnu75.9-1-1TH1-16.sbn alias cnu75.9-1-1TH1-16.sbn
tftp-server flash:Phones/7975/v9.1.1SR1/cvm75sccp.9-1-1TH1-16.sbn alias cvm75sccp.9-1-1TH1-16.sbn
tftp-server flash:Phones/7975/v9.1.1SR1/dsp75.9-1-1TH1-16.sbn alias dsp75.9-1-1TH1-16.sbn
tftp-server flash:Phones/7975/v9.1.1SR1/SCCP75.9-1-1SR1S.loads alias SCCP75.9-1-1SR1S.loads
tftp-server flash:Phones/7942-7962/v8.5.2/term62.default.loads alias term62.default.loads
tftp-server flash:Phones/7936/v3.3.21/cmterm-7936-sccp.3-3-21.cop.sgn alias cmterm-7936-sccp.3-3-21.cop.sgn
tftp-server flash:Phones/7942-7962/v9.1.1SR1/SCCP42.9-1-1SR1S.loads alias SCCP42.9-1-1SR1S.loads
tftp-server flash:Phones/7942-7962/v9.1.1SR1/apps42.9-1-1TH1-16.sbn alias apps42.9-1-1TH1-16.sbn
tftp-server flash:Phones/7942-7962/v9.1.1SR1/cnu42.9-1-1TH1-16.sbn alias cnu42.9-1-1TH1-16.sbn
tftp-server flash:Phones/7942-7962/v9.1.1SR1/cvm42sccp.9-1-1TH1-16.sbn alias cvm42sccp.9-1-1TH1-16.sbn
tftp-server flash:Phones/7942-7962/v9.1.1SR1/dsp42.9-1-1TH1-16.sbn alias dsp42.9-1-1TH1-16.sbn
tftp-server flash:Phones/7942-7962/v9.1.1SR1/jar42sccp.9-1-1TH1-16.sbn alias jar42sccp.9-1-1TH1-16.sbn
tftp-server flash:Phones/7940-7960/v8.1.1/cmterm-7940-7960-sccp.8-1-1.cop.sgn alias cmterm-7940-7960-sccp.8-1-1.cop.sgn
tftp-server flash:Phones/7940-7960/v7.2.4/P00307020400.loads alias P00307020400.loads
tftp-server flash:Phones/7940-7960/v7.2.4/P00307020400.sbn alias P00307020400.sbn
tftp-server flash:Phones/7940-7960/v7.2.4/P00307020400.sb2 alias P00307020400.sb2
tftp-server flash:Phones/7940-7960/v7.2.4/P00307020400.bin alias P00307020400.bin
tftp-server flash:Phones/7915-12/v1.0.4/cmterm-7915.1-0-4.cop.sgn alias cmterm-7915.1-0-4.cop.sgn
tftp-server flash:Phones/7975/v9.0.2SR1/term75.default.loads alias term75.default
tftp-server flash:Phones/7975/v9.0.2SR1/term75.default.loads alias term75.default.loads
control-plane
voice-port 0/0/0
voice-port 0/0/1
ccm-manager mgcp
mgcp profile default
sccp local GigabitEthernet0/0.90
sccp ccm 10.10.90.1 identifier 1 version 7.0
sccp
sccp ccm group 123
bind interface GigabitEthernet0/0.90
associate ccm 1 priority 1
associate profile 1 register confprof1
keepalive retries 5
dspfarm profile 1 conference
codec g711ulaw
maximum sessions 7
conference-leave custom-cptone leavetone
associate application SCCP
dial-peer cor custom
name internal
name local
name domestic
name international
name 900
name 719
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list call-900
member 900
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member internal
member local
dial-peer cor list user-domestic
member internal
member local
member domestic
dial-peer cor list user-international
member internal
member local
member domestic
dial-peer cor list user900-internal
member internal
member 900
member 719
dial-peer cor list user900-local
member internal
member local
member 900
member 719
dial-peer cor list user900-domestic
member internal
member local
member domestic
member 900
member 719
dial-peer cor list user900-international
member internal
member local
member domestic
member 900
member 719
dial-peer cor list call-719
member 719
dial-peer voice 100 voip
description ** Incoming call from SIP trunk **
translation-profile incoming CUE_Incoming
session protocol sipv2
session target sip-server
incoming called-number .T
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 101 voip
corlist outgoing call-local
description ** Outgoinging call to SIP trunk **
translation-profile outgoing OUTBOUND_e164
destination-pattern 9[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 102 voip
corlist outgoing call-domestic
destination-pattern 9[0-1][2-9]..[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 103 voip
description ** 911 outgoinging call to SIP trunk **
destination-pattern 911
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 104 voip
description ** emergency outgoinging call to SIP trunk **
destination-pattern 9911
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 105 voip
description ** 911/411 outgoinging call to SIP trunk **
destination-pattern 9[2-9]11
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 106 voip
corlist outgoing call-international
description ** International outgoinging call to SIP trunk **
destination-pattern 9011T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 107 voip
description ** star code to SIP trunk **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 25 voip
description ** cue voicemail pilot number **
destination-pattern 5000
b2bua
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 26 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 5001
b2bua
codec g711ulaw
no vad
dial-peer voice 27 voip
description ** cue prompt management **
destination-pattern 5002
b2bua
codec g711ulaw
no vad
dial-peer voice 28 voip
description ** cue direct transfer to voicemail script **
destination-pattern 5003
b2bua
codec g711ulaw
no vad
presence
presence call-list
sip-ua
credentials username 7195340313 password 7 02363C0F393637757E realm jencotech.com
authentication username 7195340313 password 7 12293D43203B345018
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:sipconnect.den0.cbeyond.net expires 3600
sip-server dns:sipconnect.den0.cbeyond.net
host-registrar
presence enable
gatekeeper
shutdown
credentials
ctl-service admin jadmin secret 1 062C2F25410F07
ip source-address 10.10.90.1 port 2445
trustpoint cme_root
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 3
sdspfarm transcode sessions 8
sdspfarm tag 1 confprof1
conference hardware
video
  maximum bit-rate 384
authentication credential admin admin
max-ephones 58
max-dn 300
ip source-address 10.10.90.1 port 2000 secondary 66.180.111.130
max-redirect 20
system message Jenco
url services
http://10.1.10.1/voiceview/common/login.do
url authentication
http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
user-locale US load CME-locale-en_US-English-8.6.2.4.tar
load 7915-12 cmterm-7915.1-0-4
load 7912 cmterm-7912-8.0.1-sccp
load 7936 cmterm-7936-sccp.3-3-21
load 7960-7940 cmterm-7940-7960-sccp.8-1-1
load 7962 SCCP42.9-1-1SR1S
load 7975 SCCP75.9-0-2SR1S
time-zone 6
voicemail 5000
max-conferences 8 gain -6
call-park system application
moh music-on-hold.au
multicast moh 239.10.10.10 port 2000 route 10.10.90.1
web admin system name jadmin secret 5 $1$Z9gz$fUHQDSr.22O2zmBF5QrOV.
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern 9.T
transfer-pattern 5...
secondary-dialtone 9
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn-template  1
hold-alert 15 originator
ephone-template  1
softkeys idle  Newcall Redial Cfwdall Pickup Gpickup Dnd
softkeys connected  Hold Trnsfer TrnsfVM Park Confrn Endcall
ephone-template  2
ephone-template  3
conference drop-mode local
conference admin
softkeys hold  Join Newcall Resume
softkeys idle  Cfwdall Newcall Redial Pickup Dnd
softkeys seized  Cfwdall Redial Pickup Endcall
softkeys connected  Hold Trnsfer TrnsfVM Park Confrn Endcall RmLstC
ephone-dn  1  dual-line
number 710 secondary 7193140552 no-reg primary
pickup-group 1
label Kent
name Kent Carlson
allow watch
call-forward busy 5000
call-forward noan 5000 timeout 20
ephone-dn  2  dual-line
number 720 secondary 7195340313 no-reg primary
label Dan
name Dan McOmber
allow watch
call-forward all 752
ephone-dn  3  dual-line
number 751 secondary 7194655811 no-reg primary
label Jim
name Jim Carney
allow watch
call-forward all 720
ephone-dn  4  dual-line
number 752 secondary 7194655812 no-reg primary
label Louise
name Louise Erasmus
allow watch
ephone-dn  5  dual-line
number 753 secondary 7194655813 no-reg primary
label Spare Desk
name Spare Desk
allow watch
call-forward noan 5000 timeout 10
ephone-dn  9  dual-line
number 770 secondary 8015761064 no-reg primary
label Stew
name Stew Robbins
allow watch
ephone-dn  10
number 771 no-reg primary
label Winston
name Winston Robbins
allow watch
ephone-dn  11  dual-line
number 790 no-reg primary
label Britt
name Britt McGinn
allow watch
call-forward all 916267168078
ephone-dn  12  octo-line
number 760
label Conference
name CONFERENCE PHONE
allow watch
ephone-dn  13
number 780
label Utah Lobby
name UTAH LOBBY
allow watch
ephone-dn  98
number 5098... no-reg primary
mwi off
ephone-dn  99
number 5099... no-reg primary
mwi on
ephone-dn  100  octo-line
number 888
label Spare Line
description OCTOLINE
ephone-dn  201  octo-line
number 2001 no-reg primary
description AD-HOC Conference Extension #1
conference ad-hoc
ephone-dn  202  octo-line
number 2002 no-reg primary
description AD-HOC Conference Extension #2
conference ad-hoc
ephone-dn  203  octo-line
number 2003 no-reg primary
description AD-HOC Conference Extension #3
conference ad-hoc
ephone-dn  204  octo-line
number 2004 no-reg primary
description AD-HOC Conference Extension #4
conference ad-hoc
ephone-dn  205  octo-line
number 2005 no-reg primary
description AD-HOC Conference Extension #5
conference ad-hoc
ephone-dn  206  octo-line
number 2006 no-reg primary
description AD-HOC Conference Extension #6
conference ad-hoc
ephone-dn  207  octo-line
number 2007 no-reg primary
description AD-HOC Conference Extension #7
conference ad-hoc
ephone-dn  208  octo-line
number 2008 no-reg primary
description AD-HOC Conference Extension #8
conference ad-hoc
ephone-dn  250
number 7194655810 no-reg primary
description VM Pilot DID
ephone-dn  251
number 7194711200
description AA Pilot DID
ephone-dn  299
number 7001
park-slot timeout 15 limit 4 recall
label Park 1
description park-slot for Jenco
ephone-dn  300
number 7000
label Park 2
ephone  1
device-security-mode none
headset auto-answer line 1
video
mac-address E804.62EB.1A24
ephone-template 3
presence call-list
speed-dial 1 93609503 label "Jen Cell"
speed-dial 2 751 label "Jim"
paging-dn 90
type 7975
button  1:1 2:299 3:300
ephone  2
video
mac-address 108C.CF75.CD2B
ephone-template 3
presence call-list
paging-dn 90
type 7975
button  1:2
ephone  3
video
mac-address ACA0.166F.5C81
ephone-template 3
presence call-list
paging-dn 90
type 7962
button  1:3
ephone  4
video
mac-address 0025.4593.3A77
ephone-template 3
presence call-list
paging-dn 90
type 7962 addon 1 7915-12
button  1:4 7w1 8w2 9w3
button  10w5 11w9 12w10 13w11
button  15w13
ephone  5
video
mac-address 0025.8417.1433
ephone-template 3
username "sparedesk" password sparedesk
presence call-list
paging-dn 90
type 7962
vpn-group 1
vpn-profile 1
button  1:5
ephone  9
video
mac-address 108C.CF75.D216
ephone-template 3
presence call-list
paging-dn 90
type 7975
button  1:9
ephone  10
video
mac-address 0015.F9C7.426D
ephone-template 3
presence call-list
paging-dn 90
type 7940
button  1:10
ephone  11
video
mac-address 0018.1843.915B
ephone-template 3
presence call-list
paging-dn 90
type 7940
button  1:11
ephone  12
mac-address 00E0.75F3.BE2A
ephone-template 3
paging-dn 90
type 7936
keep-conference endcall
button  1:12
ephone  13
mac-address 0016.9DC2.FA42
ephone-template 3
paging-dn 90
type 7912
button  1:13
ephone  50
video
mac-address 0025.4593.3A6C
ephone-template 1
presence call-list
paging-dn 90
type 7962
ephone  51
video
mac-address 0025.4593.3AB1
ephone-template 1
presence call-list
paging-dn 90
type 7962
vpn-group 1
vpn-profile 1
button  1:2
ephone  52
video
mac-address 0017.957B.CDE8
ephone-template 1
presence call-list
paging-dn 90
type 7940
button  1:3
ephone  299
line con 0
exec-timeout 0 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 131
no exec
transport input all
stopbits 1
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
scheduler allocate 20000 1000
webvpn gateway sslvpn_gw
ip interface Loopback30 port 443
ssl encryption 3des-sha1 aes-sha1
ssl trustpoint cme_cert
logging enable
inservice
webvpn gateway GW1
ssl trustpoint TP-SELF-SIGNED
no inservice
webvpn install svc flash0:/webvpn/anyconnect-dart-win-2.5.3055-k9.pkg sequence 1
webvpn context sslvpn_context
ssl authenticate verify all
policy group SSLVPNphone
   functions svc-enabled
   hide-url-bar
   svc address-pool "SSLVPNphone_pool"
   svc default-domain "jencotech.com"
default-group-policy SSLVPNphone
aaa authentication list ciscocp_vpn_xauth_ml_1
gateway sslvpn_gw domain SSLVPNphone
inservice
end
boot-start-marker
boot-end-marker
no logging console
aaa new-model
no ipv6 cef
no ip source-route
  bidirectional
ip cef
lease 2
ip dhcp pool VOIP
lease 2
ctl-client
capf-server
grant auto
enrollment url http://66.180.111.140:80
rsakeypair cme_root
enrollment url
        quit
certificate ca 01
        quit
certificate 02
        quit
certificate ca 01
        quit
voice-card 0
dspfarm
voice rtp send-recv
voice service voip
vpn-group 1
  vpn-gateway 1 https://66.180.111.140/SSLVPNphone
vpn-profile 1
sip
  header-passing
  error-passthru
  early-offer forced
voice class codec 1
dualtone conference
  frequency 600 900
dualtone conference
  frequency 600 900
final 5000
timeout 16
pilot 4000
final 5000
list 752,7999
timeout 16
pilot 4001
translate calling 9
translate called 1
translate called 9
http://10.10.10.202:8081/clm/servlet/HttpListenServlet dummy dummy
hw-module ism 0
hw-module pvdm 0/0
redundancy
crypto keyring S2S
encr 3des
group 2
encr aes
hash md5
group 2
encr aes 192
group 5
key jencovpn
dns 10.10.10.200
pool VPN
acl 107
include-local-lan
   virtual-template 4
reverse-route
! Incomplete
interface Loopback0
no ip redirects
no ip unreachables
crypto map mydymap
interface Tunnel100
bandwidth 1440
no ip redirects
ip mtu 1400
no ip address
shutdown
no ip address
ip flow ingress
ip flow egress
duplex full
speed 1000
vlan-id dot1q 999
  exit-vlan-config
ip nat inside
ip nat inside
ip nat inside
ip nat inside
ip nat inside
interface ISM0/0
no keepalive
no ip address
shutdown
duplex auto
speed auto
no ip redirects
no ip unreachables
ip flow ingress
ip nat outside
duplex auto
speed auto
no cdp enable
interface ISM0/1
no ip address
shutdown
no ip address
interface Vlan1
no ip address
ip http server
ip flow-top-talkers
top 10
sort-by bytes
permit ip any any
permit ip any any
control-plane
voice-port 0/0/0
voice-port 0/0/1
ccm-manager mgcp
sccp
sccp ccm group 123
keepalive retries 5
codec g711ulaw
maximum sessions 7
name internal
name local
name domestic
name international
name 900
name 719
member internal
member local
member domestic
member 900
member internal
member internal
member local
member internal
member local
member domestic
member internal
member local
member domestic
member internal
member 900
member 719
member internal
member local
member 900
member 719
member internal
member local
member domestic
member 900
member 719
member internal
member local
member domestic
member 900
member 719
member 719
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
b2bua
codec g711ulaw
no vad
b2bua
codec g711ulaw
no vad
b2bua
codec g711ulaw
no vad
b2bua
codec g711ulaw
no vad
presence
presence call-list
sip-ua
no remote-party-id
retry invite 2
retry register 10
timers connect 100
host-registrar
presence enable
gatekeeper
shutdown
credentials
trustpoint cme_root
telephony-service
sdspfarm units 3
conference hardware
video
max-ephones 58
max-dn 300
max-redirect 20
url services
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file perphone
time-zone 6
voicemail 5000
dn-webedit
time-webedit
transfer-pattern .T
fac standard
ephone-template  1
ephone-template  2
ephone-template  3
conference admin
pickup-group 1
label Kent
name Kent Carlson
allow watch
label Dan
name Dan McOmber
allow watch
label Jim
name Jim Carney
allow watch
label Louise
name Louise Erasmus
allow watch
label Spare Desk
name Spare Desk
allow watch
label Stew
name Stew Robbins
allow watch
ephone-dn  10
label Winston
allow watch
label Britt
name Britt McGinn
allow watch
number 760
label Conference
allow watch
ephone-dn  13
number 780
label Utah Lobby
name UTAH LOBBY
allow watch
ephone-dn  98
mwi off
ephone-dn  99
mwi on
number 888
label Spare Line
conference ad-hoc
conference ad-hoc
conference ad-hoc
conference ad-hoc
conference ad-hoc
conference ad-hoc
conference ad-hoc
conference ad-hoc
ephone-dn  250
ephone-dn  251
number 7194711200
ephone-dn  299
number 7001
label Park 1
ephone-dn  300
number 7000
label Park 2
ephone  1
video
ephone-template 3
presence call-list
paging-dn 90
type 7975
ephone  2
video
ephone-template 3
presence call-list
paging-dn 90
type 7975
button  1:2
ephone  3
video
ephone-template 3
presence call-list
paging-dn 90
type 7962
button  1:3
ephone  4
video
ephone-template 3
presence call-list
paging-dn 90
button  15w13
ephone  5
video
ephone-template 3
presence call-list
paging-dn 90
type 7962
vpn-group 1
vpn-profile 1
button  1:5
ephone  9
video
ephone-template 3
presence call-list
paging-dn 90
type 7975
button  1:9
ephone  10
video
ephone-template 3
presence call-list
paging-dn 90
type 7940
button  1:10
ephone  11
video
ephone-template 3
presence call-list
paging-dn 90
type 7940
button  1:11
ephone  12
ephone-template 3
paging-dn 90
type 7936
button  1:12
ephone  13
ephone-template 3
paging-dn 90
type 7912
button  1:13
ephone  50
video
ephone-template 1
presence call-list
paging-dn 90
type 7962
ephone  51
video
ephone-template 1
presence call-list
paging-dn 90
type 7962
vpn-group 1
vpn-profile 1
button  1:2
ephone  52
video
ephone-template 1
presence call-list
paging-dn 90
type 7940
button  1:3
ephone  299
line con 0
exec-timeout 0 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line 131
no exec
transport input all
stopbits 1
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
logging enable
inservice
webvpn gateway GW1
no inservice
   hide-url-bar
inservice
end
