MPLS To DMVPN Failover Issue
NETAD
Level 4
Level 4
Hello, I'm working on an issue with a customer failing to failover from MPLS to their DMVPN cloud. It's a single router that has both an MPLS and internet connection. On the MPLS line they're running BGP and on the DMVPN tunnels they're running EIGRP.
For some reason the routes between the spokes are being exchanged. DMVPN is running is phase 3 and here's the config for the hub and the 2 spokes. Can you please take and look to see if I'm missing anything. Thank you so much.
HUB
interface Tunnel2000
 description DMVPN Tunnel over the Internet.
 bandwidth 200000
 ip address 172.26.1.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 no ip split-horizon eigrp 1
 ip nhrp map multicast dynamic
 ip nhrp network-id 2000
 ip nhrp holdtime 450
 ip nhrp shortcut
 ip nhrp redirect
 ip tcp adjust-mss 1360
 delay 1000
 tunnel source GigabitEthernet0/0/0
 tunnel mode gre multipoint
 tunnel key 2000
 tunnel protection ipsec profile Profile.DMVPN.Internet
end
MADISON
 bandwidth 20000
 ip address 172.26.1.18 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp map multicast X.X.X.X
 ip nhrp map 172.26.1.1 X.X.X.X
 ip nhrp nhs 172.26.1.1
 ip nhrp shortcut
 ip nhrp redirect
 delay 1000
 tunnel key 2000
end
NOGALAS
Current configuration : 446 bytes
 bandwidth 30000
 ip address 172.26.1.10 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp map 172.26.1.1 198.35.58.198
 ip nhrp shortcut
 ip nhrp redirect
 delay 1000
 tunnel key 2000
end
14 Replies 14
NETAD
Level 4
Level 4
Can someone chime in here please. We're attempting the failover again today.
Can you clarify the issue for me please? You said "For some reason the routes between the spokes are being exchanged" < do you mean to say that each spoke router has the other spoke routers routes in it's routing table? Learnt via EIGRP?
I'm sorry. I meant to say that the spokes aren't seeing each others routes.
Ok, do they have an adjacency to the hub? What is the configuration of eigrp? Can you post
yes adjacency is there with the hub and the spokes are advertising their networks.
HUB
router eigrp x
address-family ipv4 unicast autonomous-system 1
af-interface Tunnel200
hello-interval 20
hold-time 60
exit-af-interface
topology base
distribute-list route-map DMVPN2-INET-IN in Tunnel200
distribute-list route-map BLOCK-LEARNED out Tunnel200
redistribute ospf 1 match internal metric 10000 100 255 1 1500
exit-af-topology
network 10.8.148.254 0.0.0.0
network 10.8.253.0 0.0.0.255
network 10.8.254.0 0.0.0.255
network 10.8.255.148 0.0.0.0
network 172.26.1.0 0.0.0.255
eigrp router-id 10.8.255.148
exit-address-family
spoke 1
router eigrp x
topology base
exit-af-topology
network 10.8.150.0 0.0.0.255
network 10.8.156.0 0.0.0.255****************************
network 172.26.1.0 0.0.0.255****************************
spoke2
router eigrp x
topology base
exit-af-topology
network 10.8.255.254 0.0.0.0
network 10.31.71.12 0.0.0.0
eigrp router-id 10.8.255.254
exit-address-family
What routes are in the spokes routing table? Can you provide an output?
In your eigrp configuration you are referencing Tunnel 200 but the Tunnel interface is actually 2000, typo?
What is the configuration and purpose of the route-maps? What are they filtering?
tun200 is an old tunnel that was setup for IWAN but it's shutdown. Same for the route-maps. They shouldn't be in play here. The new tunnels are on the 172.26.1.0/24 network. I will provide the output momentarily. Thanks for your assistance on this.
Is no ip next-hop eigrp 1 needed on the hub?
Here's the requested commands RJI. one of the main subnets that we need the NOGA spoke to see is the 10.31.71.0/24 that Madison is advertising in EIGRP and if you look it's in the hub top table.
The output is slightly confusing without a diagram, do you have one?
Nog_Internet is a spoke? This has the route 10.31.71.0/24 in it's routing table, but learnt from BGP - it has a lower AD than EIGRP, which is why it's in the routing table.
NOG is a spoke correct. Correct it has a bgp route for 10.31.71.0/24 because of the lower AD but that route isn't in the eigrp topology table even when we disconnected the MPLS circuit from the router.
Hi RJI, I took another stab at this but this time one of the spokes is resolving the nbma address of the other spoke incorrectly it’s resolving it to the hub. While the other spoke is resolving the nbma address to the correct address of the tunnel. What should I try to resolve this. Note that I can ping the hubs tunnel interface but the spokes arent able to ping each others tunnel intrface.
Hi, Can you provide the output of those tests you run in a text file? Can you also provide the output of "show ip nhrp" from the hub and spokes. Can you also indicate the NBMA and Tunnel IP addresses of each router (hub and spokes). I'll have a look.
Hi RJI, the customer has an existing DMVPN cloud but we're trying to migrate them to another one. There are 2 tunnels per router and each point to a different hub. We're trying to remove one of the tunnels but they're some dependencies on it still. Do you think this conflict is what's causing the spokes routes not to appear at each other?
