05-22-2018 08:12 PM - edited 03-12-2019 05:18 AM
Hello, I'm working on an issue with a customer failing to failover from MPLS to their DMVPN cloud. It's a single router that has both an MPLS and internet connection. On the MPLS line they're running BGP and on the DMVPN tunnels they're running EIGRP.
For some reason the routes between the spokes are being exchanged. DMVPN is running is phase 3 and here's the config for the hub and the 2 spokes. Can you please take and look to see if I'm missing anything. Thank you so much.
HUB
interface Tunnel2000
description DMVPN Tunnel over the Internet.
bandwidth 200000
ip address 172.26.1.1 255.255.255.0
no ip redirects
ip mtu 1400
no ip split-horizon eigrp 1
ip nhrp map multicast dynamic
ip nhrp network-id 2000
ip nhrp holdtime 450
ip nhrp shortcut
ip nhrp redirect
ip tcp adjust-mss 1360
delay 1000
tunnel source GigabitEthernet0/0/0
tunnel mode gre multipoint
tunnel key 2000
tunnel protection ipsec profile Profile.DMVPN.Internet
end
MADISON
bandwidth 20000
ip address 172.26.1.18 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast X.X.X.X
ip nhrp map 172.26.1.1 X.X.X.X
ip nhrp nhs 172.26.1.1
ip nhrp shortcut
ip nhrp redirect
delay 1000
tunnel key 2000
end
NOGALAS
Current configuration : 446 bytes
bandwidth 30000
ip address 172.26.1.10 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 172.26.1.1 198.35.58.198
ip nhrp shortcut
ip nhrp redirect
delay 1000
tunnel key 2000
end
05-23-2018 05:54 AM
05-23-2018 06:01 AM
05-23-2018 06:04 AM
05-23-2018 06:08 AM
05-23-2018 06:21 AM
05-23-2018 06:37 AM
05-23-2018 06:41 AM
05-23-2018 08:17 AM
05-23-2018 06:58 AM
05-23-2018 01:05 PM
05-23-2018 01:18 PM
05-23-2018 08:10 PM
05-24-2018 01:56 AM
05-25-2018 07:46 AM
