10-16-2012 01:27 PM
This is my first time posting in this forum. I am having trouble getting Mac computers (my test is OSX 10.8.2) to properly connect to our company's VPN. We have a Cisco ASA5510 which handles the VPN requests. Here are some details:
--Windows computers, running Cisco VPN Client (not Anyconnect) are able to connect to the VPN and access internal computers/fileserver etc, just as we'd like them to.
--Mac's can establish a VPN connection, but cannot communicate with internal machines or servers. I cannot connect to or ping the fileserver using its IP address. I also cannot ping my personal work computer.
--BUT, from my work computer I CAN ping the Mac's ip address which it received after connecting via VPN. So, internal Windows PC can ping external VPN'd Mac, but Mac cannot ping internal Windows pc.
Using ASDM I was able to start up Packet Tracer. I had it trace a ping from the Windows machine address 192.168.0.52 /23 to the Mac's VPN address 192.168.5.33 /24. This was successful.
Using Packet Tracer to trace a ping from the Mac's VPN address of 192.168.5.33 /24 to the Windows address of 192.168.0.52 /23 is not successful. The packet goes through the following phases: "Capture", "Access-list", "Route-Lookup", "Access-List", "IP Options", "Inspect", "Inspect", "Debug-ICMP", "NAT-Exempt", until it reaches "NAT" where I get this message:
Type - NAT Action - Drop
Config
nat (inside1) 1 0.0.0.0 0.0.0.0
match ip inside1 any inside1 any
dynamic translation to pool 1 (192.168.1.1 [Interface PAT])
translate_hits = 913403, untranslate_hits = 27
Result is the packet is dropped.
Info: (acl-drop) Flow is denied by configured rule
I'm not super familiar with ACL's or NAT configuration, so I am not sure what change I need to make to get this to work properly. I also find it strange that the Windows pc's using the Cisco client have no problem communicating internally after connecting, but Mac's using the Mac integrated Cisco IPSEC VPN are unsuccessful.
Any help would be greatly appreciated.
-Ramai
P.s. I included a screenshot of the Packet Tracer screen.
Solved! Go to Solution.
10-22-2012 02:15 PM
Is your home wireless happened to be in the 192.168.1.0/24 subnet? if it is, try to change them to a different subnet as you have suggested earlier and see if it works.
10-17-2012 12:39 AM
Can you pls share your ASA config, and also advise if you are using different VPN pool address for your Windows and MACs, and if they are using the same group to connect.
10-17-2012 09:49 AM
Hi Jennifer,
Thanks for your response. Windows and Mac computers use the same pool of addresses for VPN connections, they are also part of the same group. Here is the running-configuration:
**Note: I have replaced some sensitive data with *** but left the beginning and ending characters to give an idea of what kind of information is present.
Result of the command: "show running-config"
: Saved
ASA Version 8.2(5)
hostname ciscoasa
enable password 8Ry*********XU24 encrypted
passwd c/Z**********wMi encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 98.***.***.57 255.255.255.192
interface Ethernet0/1
nameif inside1
security-level 100
ip address 192.168.1.1 255.255.254.0
interface Ethernet0/2
nameif inside2
security-level 99
ip address 192.168.2.1 255.255.255.0
interface Ethernet0/3
nameif inside3
security-level 98
ip address 192.168.3.1 255.255.255.0
interface Management0/0
nameif management
security-level 100
ip address 192.168.10.1 255.255.255.0
management-only
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list 101 extended permit tcp any host 98.***.***.57 eq ftp
access-list cap extended permit ip host 192.168.3.2 host 192.168.1.50
access-list cap extended permit ip host 192.168.3.2 host 192.168.1.75
access-list test extended permit ip host 192.168.2.27 host 192.168.1.20
access-list test extended permit ip host 192.168.1.20 host 192.168.2.27
access-list test extended permit ip any host 192.168.1.20
access-list test extended permit ip host 192.168.1.20 any
access-list split standard permit 192.168.0.0 255.255.254.0
access-list split standard permit 192.168.2.0 255.255.255.0
access-list split standard permit 192.168.3.0 255.255.255.0
access-list split standard permit 192.168.4.0 255.255.255.0
access-list nonat extended permit ip 192.168.0.0 255.255.254.0 192.168.5.0 255.255.255.0
access-list nonat extended permit ip any 192.168.5.0 255.255.255.0
access-list nonat1 extended permit ip 192.168.2.0 255.255.255.0 192.168.5.0 255.255.255.0
access-list nonat2 extended permit ip 192.168.3.0 255.255.255.0 192.168.5.0 255.255.255.0
access-list new extended permit ip host 192.168.1.50 host 192.168.2.131
access-list new extended permit ip host 192.168.2.131 host 192.168.1.50
access-list inside_access_in extended permit tcp any any
access-list inside_access_in extended permit tcp any any eq ftp
access-list capin extended permit tcp host 192.168.2.131 host 192.168.2.1
access-list capin extended permit tcp host 192.168.2.1 host 192.168.2.131
access-list capin extended permit tcp host 192.168.1.1 host 192.168.1.50
access-list capin extended permit tcp host 192.168.1.50 host 192.168.1.1
access-list capin extended permit tcp any host 98.***.***.57
access-list capin extended permit tcp host 98.***.***.57 any
access-list capin extended permit tcp host 192.168.1.50 host 192.168.2.131
access-list capin extended permit tcp host 192.168.3.2 host 192.168.3.1
access-list capin extended permit tcp host 192.168.3.1 host 192.168.3.2
access-list tcpstatebypass extended permit tcp host 192.168.2.131 host 192.168.1.50
access-list inside1 extended permit ip any any
access-list inside2 extended permit ip any any
pager lines 15
logging enable
logging buffered debugging
logging asdm informational
logging from-address ciscoasa@ourdomain.com
logging recipient-address myemail@ourdomain.com level critical
mtu outside 1500
mtu inside1 1500
mtu inside2 1500
mtu inside3 1500
mtu management 1500
ip local pool VPNPOOL 192.168.5.1-192.168.5.254 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-645.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (inside1) 1 interface
global (inside2) 1 interface
nat (inside1) 0 access-list nonat
nat (inside2) 0 access-list nonat1
nat (inside2) 1 0.0.0.0 0.0.0.0
nat (inside3) 0 access-list nonat2
nat (inside3) 1 0.0.0.0 0.0.0.0
static (inside1,outside) tcp interface ftp 192.168.1.50 ftp netmask 255.255.255.255 dns
static (inside1,inside2) tcp 98.***.***.57 ftp 192.168.1.50 ftp netmask 255.255.255.255
static (inside1,inside3) tcp 98.***.***.57 ftp 192.168.1.50 ftp netmask 255.255.255.255
static (inside1,inside1) tcp 98.***.***.57 ftp 192.168.1.50 ftp netmask 255.255.255.255
static (inside2,inside3) 192.168.2.0 192.168.2.0 netmask 255.255.255.0
static (inside3,inside1) 192.168.3.0 192.168.3.0 netmask 255.255.255.0
static (inside3,inside2) 192.168.3.0 192.168.3.0 netmask 255.255.255.0
static (inside3,inside1) 192.168.4.0 192.168.4.0 netmask 255.255.255.0
static (inside3,inside2) 192.168.4.0 192.168.4.0 netmask 255.255.255.0
static (inside1,inside3) 192.168.0.0 192.168.0.0 netmask 255.255.254.0
static (inside1,inside2) 192.168.0.0 192.168.0.0 netmask 255.255.254.0
access-group 101 in interface outside
access-group inside1 in interface inside2
access-group inside2 in interface inside3
route outside 0.0.0.0 0.0.0.0 98.***.***.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 0.0.0.0 0.0.0.0 inside1
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt connection timewait
sysopt connection tcpmss 0
sysopt noproxyarp inside1
crypto ipsec transform-set ESP-3DES esp-3des esp-md5-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map dynmap 1 set pfs group1
crypto dynamic-map dynmap 1 set transform-set ESP-3DES
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-
128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-
MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside-map 65535 ipsec-isakmp dynamic dynmap
crypto map outside-map interface outside
crypto isakmp enable outside
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
telnet 0.0.0.0 0.0.0.0 inside1
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside1
ssh timeout 20
console timeout 0
management-access inside2
dhcpd dns 208.***.***.222 208.***.***.220
dhcpd address 192.168.0.1-192.168.0.254 inside1
dhcpd enable inside1
dhcpd address 192.168.2.11-192.168.2.254 inside2
dhcpd enable inside2
dhcpd address 192.168.3.2-192.168.3.254 inside3
dhcpd enable inside3
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
enable inside1
enable inside2
enable inside3
group-policy VPNPOOL internal
group-policy VPNPOOL attributes
vpn-tunnel-protocol IPSec l2tp-ipsec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split
username c******r password wZ************an encrypted
username s******w password 91************/3 encrypted
username c******s password pF************HQ.JP encrypted
username a******n password Bi************H7K encrypted
username m******el password mv6************5uj encrypted
username L******s password TY***************xl encrypted
username r******n password EA***************M11 encrypted
username V******n password 2DV**************4a encrypted
username e******r password .e6***************Hy encrypted
username F******y password Lke***************hV0 encrypted
username F******y attributes
group-lock value VPNPOOL
memberof VPNPOOL
username c******n password 6K***************Xf encrypted
username a******n password be***************Lyt encrypted privilege 15
username R******k password j.5Z***************4Vr encrypted
username R******k attributes
service-type admin
memberof VPNPOOL
username e******s password FN***************Z5 encrypted
username j******a password uor***************Ch encrypted
username K******z password 1a***************zw encrypted
username d******s password OC***************/8 encrypted
username P******z password XG***************Sp encrypted
username l******l password 9k***************q2 encrypted
username r******r password rP***************OC encrypted
username c******o password Uq***************5X encrypted privilege 15
username h******r password HD***************jw encrypted
username K******s password Sb***************0D encrypted
username j******d password ub***************oZ encrypted
username J******n password 2y***************== nt-encrypted
username m******n password oJ***************3v encrypted
username r******u password R/***************A5c encrypted
username J******i password Iu***************2g encrypted
username J******i attributes
memberof VPNPOOL
tunnel-group DefaultRAGroup general-attributes
address-pool VPNPOOL
default-group-policy VPNPOOL
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *****
tunnel-group DefaultRAGroup ppp-attributes
authentication ms-chap-v2
tunnel-group VPNPOOL type remote-access
tunnel-group VPNPOOL general-attributes
tunnel-group VPNPOOL ipsec-attributes
class-map tcpstatebypass
match access-list tcpstatebypass
class-map inspection_default
match default-inspection-traffic
class-map new
match access-list new
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
class new
set connection random-sequence-number disable
set connection advanced-options tcp-state-bypass
policy-map tcpstatebypass
class tcpstatebypass
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:10d***************************43c
: end
10-18-2012 06:28 AM
If they are connecting to the same group and using the same pool, it is unlikely that it is something on the ASA that is causing the issue. It's most probably something on the MAC itself.
Are you able to ping 192.168.2.1 from the MAC?
How is the MAC connected? wired, or wireless, or something else? What is the local subnet that the MAC is connected at?
Pls share the output of "show cry ipsec sa peer
10-18-2012 08:33 AM
Mac's are connecting to the VPN using their built in VPN client, located within Network Preferences.
Most local computers are located on the 192.168.0.0/23 network. When clients VPN in they are assigned a 192.168.5.0 address. I don't see the 192.168.5.0 address being tied to any specific interface, is that necessary for VPN?
These are the addresses I tried pinging:
From my local work machine (192.168.0.240) I pinged the VPN'd Mac which had been assigned an address of 192.168.5.30. This ping was successful. I then tried in the opposite direction, pinging from the Mac to my local machine, this ping timed out.
I just tested pinging 192.168.2.1 from my local machine (192.168.0.240) and it timed out. I then tested pinging from the Mac (192.168.5.30) to 192.168.2.1 and it was successful. Using ASDM's packet tracer, I had the same results. Interesting.
So it would seem there is some internal routing issue?
10-18-2012 01:14 PM
Ah, if you can ping 2.1 from MAC (5.30), that is a good sign.
On the local work machine (0.240) that you are trying to ping from the MAC, does the local machine has any Windows firewall that might be blocking inbound connection from remote subnet?
10-18-2012 01:48 PM
Hey Jennifer,
So we are making progress. I turned off my local machine's firewall and was able to ping it (0.240) from the mac (5.30), so we know that is working. I created a rule on my local machine allowing access through the firewall from any 192.168.5.* address and now with the firewall on I can still be pinged by the mac.
Unfortunately, I checked the server machine and the Windows firewall for private networks is not even on, so that isn't what is stopping the Mac from pinging it. The server has an address of 192.168.1.50, so it is on the same subnet as my local machine which is 192.168.0.240 /23. What is weird is that I can ping the server (1.50) from my machine (0.240), though the mac can't. There must be some firewall snagging it somewhere, I'll have to investigate further. I can't believe this ended up being a firewall issue, I was so sure it was something much more complex. Anyway, it still might turn out to be something complicated, we'll see if I can find what is blocking it. Any suggestions of where to look?
Thanks for your help.
*EDIT*
The server actually had the firewall off, for when connected to a local network, but not for public networks. Normally when I ping (1.50) from the mac I get this response every ping "Request timeout for icmp_seq 0" etc.
After turning off every aspect of windows firewall I get:
"ping: sendto: No route to host" (only on first ping)
"ping: sendto: Host is down" (every ping)
"Request timeout for icmp_seq 0" (1, 2, etc)
10-18-2012 06:26 PM
Excellent, great findings, and thanks for the update.
In regards to the server, does it have just 1 NIC, or 2 NICs? If it has 2 NICs, then you would need either access it via its other NIC as it probably has default route going that other NIC, or if you want to access it via its 1.50 address, then configure a static route on that server for 192.168.5.0/24 pointing towards the ASA interface (192.168.1.1)
10-19-2012 06:28 AM
I checked the server and it only has 1 physical NIC, also no virtual NIC's except for something listed in "Network Connections" related to having people Remote into the server.
I don't think the server needs a route to the 192.168.5.0/24 network, because it can ping the VPN'd Mac, but the Mac can't ping back. Wouldn't' that indicate that the server has a proper route to the VPN subnet? I will still look into the route thing while I wait for your reply.
-Ramai
**EDIT**
Also, the default gateway for the server is 192.168.1.1, so isn't that essentially the default route?
10-19-2012 12:54 PM
Yes, you are correct. My previous comment was just if the server has 2 NICs. Otherwise, you only need the default gateway configured on the server.
BTW, it's weird that when you disable all windows firewall, you have those error message.
Can you pls reenable the firewall, and on the public networks, add the rule to allow ICMP, as well as any other services that you would like access from the VPN.
10-19-2012 01:58 PM
I already added an inbound and outbound rule for the server to allow all traffic to and from the 192.168.5.0 range. The same rule that I implemented on my personal machine, which has been allowing the Mac to ping me.
The messages:
Actually appear any time I ping I have noticed. It's just that they don't pop up until after the 4th or 5th ping. Where as for some reason, when I would disable the public firewall completely, it would show the messages after the first ping, instead of the 4th or 5th. Strange stuff.
I have looked to see if for some reason there was some additional program installed or service running that may be interfering, but nothing obvious stands out.
I still feel like it's some ACL or NAT rule on the ASA that is blocking this communication, but I am not expert enough to know.
10-19-2012 04:56 PM
Well, if you can ping your local machine (0.240) which is in the same subnet as the server (1.50) as well as able to ping the ASA inside interface (1.1) from the VPN Client MAC machine (192.168.5.x), that means it is not an ACL or NAT rule on the ASA as they are configured per subnet.
What about any other machine in the 192.168.0.0 subnet? Can you ping them from the VPN Client MAC machine?
Also, your server, what is the subnet mask (is it 255.255.254.0)
10-22-2012 08:23 AM
The server's subnet mask is 255.255.254.0. By looking at the configuration, it seems that the VPNPOOL gives out 192.168.5.X addresses with a 255.255.255.0 subnet mask, that should be fine though correct?
Yes, I am able to ping other machines on the 192.168.0.0 subnet (after turning off the firewall).
I am going to try connecting the Mac at my home to a wired connection instead of wireless and see if that fixes things, and maybe change the network address the computer is assigned, maybe it's conflicting.
10-22-2012 10:48 AM
Hmmm, I don't seem to be able to connect to the ASA any more, I don't know if I accidentally changed something to cause this...
I cannot ping 192.168.1.1 from any computer on the network. I cannot SSH in using Putty. I cannot connect using ASDM. I also cannot connect using a console cable in the network closet. All the functions still work properly (people getting DHCP, able to VPN in, etc.) but I cannot login to configure anything. Any idea what I may have changed or can do to get in? I am thinking to restart, since I previously saved the running-config to the startup-config before changing things. I don't know if ASDM automatically saves things to the startup config though.
Breaking more things than I am fixing it seems lol.
***EDIT***
As noted before, the mac could ping my personal computer with a 192.168.0.X address. I just manually configured a desktop here to have an address of 192.168.1.28 and the Mac is unable to ping it, getting the same messages as when trying to ping the server. I am really starting to think that it has to do with the local address the computer is assigned, before establishing a VPN connection. The Mac Cisco Ipsec configuration does not give any option to configure split tunneling or not. Once I go home I'll change my wireless router to assign something like 192.168.8.5 and have the default gateway also be 192.168.8.1, then see if it can ping the server here properly.
10-22-2012 02:15 PM
