08-01-2016 02:20 AM
Hello dudes
I have a problem with a VPN.
Here the architecture:
10.91.250.16 <<<<>>>> ASA <<<<>>>> TUNNEL<<<<>>>> CHECKPOINT <<<<>>>> 172.16.8.12
Before to enter in tunnel 10.91.250.16 is nated to 10.10.249.1.
When I try to ping, I get this error message:
5 | Aug 01 2016 | 11:07:50 | 305013 | 10.91.250.16 | 172.16.8.12 | Asymmetric NAT rules matched for forward and reverse flows; Connection for icmp src inside:10.91.250.16 dst outside:172.16.8.12 (type 8, code 0) denied due to NAT reverse path failure |
I'll attach my configuration.
Thanks for your help
Solved! Go to Solution.
08-01-2016 06:42 AM
To Be more specified, NAT should be like this:
nat (inside,outside) source static HOST_CAMPUS_LISSES_SERVEURS_ERPVIRTUEL NAT_CAMPUS<->CUSTOMER destination static LAN_CUSTOMER LAN_CUSTOMER
08-01-2016 02:57 AM
This is often caused by missing ICMP-inspection. You can add the following config to enable it:
policy-map global_policy class inspection_default inspect icmp
08-01-2016 03:03 AM
Hello Karsten Iwen
Thanks for your reply.
Unfortunately, the problem remains.
I've made a packet-tracer:
packet-tracer input inside icmp 10.91.250.16 0 0 172.16.8.12
Phase: 1
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Additional Information:
found next-hop 88.164.214.254 using egress ifc outside
Phase: 2
Type: NAT
Subtype:
Result: ALLOW
Config:
object network HOST_CAMPUS_LISSES_SERVEURS_ERPVIRTUEL
nat (inside,outside) static NAT_CAMPUS<->CUSTOMER
Static translate 10.91.250.16/0 to 10.10.249.1/0
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
inspect icmp
service-policy global_policy global
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 7
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
object network obj_any
nat (any,inside) dynamic interface
Result:
output-interface: outside
output-status: up
output-line-status: up
Action: drop
08-01-2016 03:19 AM
ok, what do you want to achieve with the following NAT-rule? Is that really what you want?
object network obj_any nat (any,inside) dynamic interface
If you wanted to add the dynamic NAT for all outgoing traffic, the interface is wrong. Then you could configure it as following and remove the above statement:
nat (any,outside) after-auto source dynamic any interface
08-01-2016 04:23 AM
Hey,
Thanks both of you.
To make it easier, here the architecture
With my computer (10.91.250.16) I want to reach all listed subnets in customer LAN.
In my firewall, my IP address is nated to 10.10.249.1 /32.
But, when I try to ping, i get that:
Thanks for help :)
08-01-2016 05:59 AM
Okay fine.
Create an object-group that should contain all the destination network "remote network". Then add the static NAT :
nat (inside,outside) source static HOST_CAMPUS_LISSES_SERVEURS_ERPVIRTUEL NAT_CAMPUS<->CUSTOMER destination static destination_obj destination_obj
Let us know if this will help
08-01-2016 06:09 AM
Hello Dina Odeh,
Thanks for you reply but it's not working. Same issue :'(
5 | Aug 01 2016 | 15:06:59 | 305013 | 10.91.250.16 | 172.16.8.12 | Asymmetric NAT rules matched for forward and reverse flows; Connection for icmp src inside:10.91.250.16 dst outside:172.16.8.12 (type 8, code 0) denied due to NAT reverse path failure |
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 2
Type: NAT
Result: ALLOW
Config:
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
inspect icmp
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 6
Type: VPN
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
Result:
output-status: up
Action: drop
Best regards.
Olivier.
08-01-2016 06:14 AM
Hi Oliver,
Send me please "show run nat" and this output:
"packet-tracer input inside icmp 10.91.250.16 8 0 172.16.8.12 det"
08-01-2016 06:35 AM
nat (inside,outside) source static HOST_CAMPUS_LISSES_SERVEURS_ERPVIRTUEL HOST_CAMPUS_LISSES_SERVEURS_ERPVIRTUEL destination static LAN_CUSTOMER NAT_CAMPUS<->CUSTOMER
nat (MANAGEMENT,outside) after-auto source dynamic any interface
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 2
Type: NAT
Result: ALLOW
Config:
Forward Flow based lookup yields rule:
in id=0x2aaac04fedd0, priority=0, domain=nat-per-session, deny=true
hits=890438, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, dscp=0x0
input_ifc=any, output_ifc=any
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in id=0x2aaac0fba920, priority=0, domain=inspect-ip-options, deny=true
hits=51627, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
input_ifc=inside, output_ifc=any
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
inspect icmp
in id=0x2aaac1c6ee80, priority=70, domain=inspect-icmp, deny=false
hits=2500, user_data=0x2aaac2d393e0, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
src ip/id=0.0.0.0, mask=0.0.0.0, icmp-type=0, tag=any
dst ip/id=0.0.0.0, mask=0.0.0.0, icmp-code=0, tag=any, dscp=0x0
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in id=0x2aaac0fba130, priority=66, domain=inspect-icmp-error, deny=false
hits=5906, user_data=0x2aaac0fb96a0, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 6
Type: VPN
Result: ALLOW
Config:
in id=0x2aaac1c79750, priority=13, domain=ipsec-tunnel-flow, deny=true
hits=3481, user_data=0x0, cs_id=0x0, flags=0x0, protocol=0
Phase: 7
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
out id=0x2aaac10cd210, priority=6, domain=nat-reverse, deny=false
hits=3636, user_data=0x2aaac10cb390, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Result:
output-status: up
Action: drop
Thanks for you help.
Best regards,
Olivier Chambelant
08-01-2016 06:39 AM
Oliver,
You put an incorrect NAT, not the one we mentioned above.
Destination_obj --- Is an object group that should have all the customer network in your graph above.
08-01-2016 06:42 AM
08-01-2016 06:53 AM
Hi again.
I confirm that this is the case.
Thanks again.
Olivier.
08-01-2016 07:22 AM
Nice.
You are welcome !!
08-01-2016 07:33 AM
Hey,
Sorry, but I still can't access to my CUSTOMER LAN :'(
Best regards.
Olivier.
08-01-2016 10:43 PM
Hello Olivier,
The RPF Check failure happens when a NAT rule is hit when traffic is going out, and a different NAT rule is hit when traffic is coming back in.
To try and avoid this configure the NAT rule on a higher sequence number for it to be taking precedence. Also add the route-lookup at the end of the command to make sure the path follows the nat rules based on the routing table (since the dynamic nat is configured (any,outside) it is normally used to make sure the nat rule is applied correctly).
Also check if there is a xlate entry "stuck" performing the dynamic nat.
you may "clear xlate local [local ip address]" if there is a conflicting xlate.
The example of the nat rule is:
nat (inside,outside) 1 source static HOST_SOLUTYS_LISSES_SERV EURS_SAGEVIRTUEL NAT_SOLUTYS<->SAMSE destination static LAN_SAMSE LAN_SAMSE no-proxy-arp route-lookup
