07-18-2019 08:59 AM - edited 02-21-2020 09:42 PM
We use Anyconnect to access our network from remote locations. I am trying to ping from my laptop (172.16.95.181) that is connected via Anyconnect to a device (192.168.3.200) that is on the inside network. This is not working. Looking at the packet trace, I see it is saying it is being dropped here:
Phase: 10 Type: VPN Subtype: ipsec-tunnel-flow
What I can't figure out is why. I know packet tracer sometimes is a little weird when it comes to testing packets in/out VPN, so maybe it is not really telling me where the error is.
I have tried a capture but I don't see any packets at all when I ping from my laptop to the device.
# capture myping interface internet_outside real-time match icmp host 172.16.95.181 host 192.168.3.200
However, if I watch the hitcnt on the ACL, it increments
access-list internet_outside_access_in line 1 extended permit icmp object-group ANYCONNECT_VPN_POOL any (hitcnt=6528) 0x536e52c1
If I run a capture on the inside interface looking for all ICMP from the device, I see the request come in, but no echo replies (notice the inside_access_in has permit icmp any any at the very top)
# capture myping interface inside real-time match icmp host 192.168.3.200 any Warning: using this option with a slow console connection may result in an excessive amount of non-displayed packets due to performance limitations. Use ctrl-c to terminate real-time capture 1: 15:56:52.416253 802.1Q vlan#2 P0 192.168.3.200 > 172.16.95.181 icmp: echo request 2: 15:56:57.039899 802.1Q vlan#2 P0 192.168.3.200 > 172.16.95.181 icmp: echo request 3: 15:57:02.036115 802.1Q vlan#2 P0 192.168.3.200 > 172.16.95.181 icmp: echo request 4: 15:57:07.045407 802.1Q vlan#2 P0 192.168.3.200 > 172.16.95.181 icmp: echo request
I have included the entire packet trace and sanitized configuration as attachments. Any help would be greatly appreciated...
07-18-2019 10:13 AM
07-18-2019 11:20 AM
Here you go...
# packet-tracer input inside icmp 192.168.3.200 8 0 172.16.95.181 WARNING: 5 sec waittime expire start 6363473, end 6363474,flags 0, trace 0x0000000008cdae77/0x0000000008cdae77 Phase: 1 Type: ACCESS-LIST Subtype: Result: ALLOW Config: Implicit Rule Additional Information: MAC Access list Phase: 2 Type: ROUTE-LOOKUP Subtype: Resolve Egress Interface Result: ALLOW Config: Additional Information: found next-hop 172.16.95.181 using egress ifc internet_outside Phase: 3 Type: UN-NAT Subtype: static Result: ALLOW Config: nat (inside,internet_outside) source static any any destination static NETWORK_OBJ_172.16.95.0_24 NETWORK_OBJ_172.16.95.0_24 no-proxy-arp route-lookup Additional Information: NAT divert to egress interface internet_outside Untranslate 172.16.95.181/0 to 172.16.95.181/0 Phase: 4 Type: ACCESS-LIST Subtype: log Result: ALLOW Config: access-group inside_access_in in interface inside access-list inside_access_in extended permit icmp any any Additional Information: Phase: 5 Type: NAT Subtype: Result: ALLOW Config: nat (inside,internet_outside) source static any any destination static NETWORK_OBJ_172.16.95.0_24 NETWORK_OBJ_172.16.95.0_24 no-proxy-arp route-lookup Additional Information: Static translate 192.168.3.200/0 to 192.168.3.200/0 Phase: 6 Type: NAT Subtype: per-session Result: ALLOW Config: Additional Information: Phase: 7 Type: IP-OPTIONS Subtype: Result: ALLOW Config: Additional Information: Phase: 8 Type: INSPECT Subtype: np-inspect Result: ALLOW Config: class-map inspection_default match default-inspection-traffic policy-map global_policy class inspection_default inspect icmp service-policy global_policy global Additional Information: Phase: 9 Type: INSPECT Subtype: np-inspect Result: ALLOW Config: Additional Information: Phase: 10 Type: VPN Subtype: encrypt Result: DROP Config: Additional Information: Result: input-interface: inside input-status: up input-line-status: up output-interface: internet_outside output-status: up output-line-status: up Action: drop Drop-reason: (acl-drop) Flow is denied by configured rule
07-18-2019 03:11 PM
07-19-2019 01:04 PM
07-19-2019 02:56 PM
07-23-2019 10:49 AM
Hi Francesco,
I haven't forgotten about this, we just have a bit of another fire I am dealing with at the moment.
To answer your question, there is another line in the ACL that allows RDP to the inside host from the VPN and it is working fine. I also tried pinging the host from a different subnet, but that does not go through the FW and it is able to ping fine, therefore there is no FW on the host that should be blocking the ping...
Once this fire settles I will send you a PM and we can troubleshoot further. It will probably be next week before I get back to you...
I appreciate the help!
-Brian
06-25-2020 05:38 AM
packet tracer with VPN only works with the "detailed encrypted" command argument, and that only works on ASA version 9.9 and above. I have not tried it myself, but I see others have.
