Need help with ASA 5515-X (8.6) Anyconnect VPN configuration
KUNAL HANS
I'm trying to configure Anyconnect SSL RA VPN. I have followed the config guide for 8.4 & 8.6 but can't even get the Anyconnect page to load. I'm pasting the config below. Plz check and let me know what I have missed. Objectives are:
1. The user simply opens https://<outside-ip> and is prompted to install the anyconnect vpn client.
2. Is able to access internal LAN resources and browse the internet simultaneously (is split-tunneling required?)
ASA Version 8.6(1)
hostname Harpoon
domain-name xxxxx.com
enable password xxxxxxxxxx encrypted
passwd xxxxxxxxxxxx encrypted
names
interface GigabitEthernet0/0
speed 100
duplex full
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.252
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 172.29.0.100 255.255.0.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
banner motd -----------------------------------------------------------------------------
banner motd This system is solely for the use of authorised users for official purposes.
banner motd You have no expectation of privacy in its use and to ensure that the system
banner motd is functioning properly, individuals using this computer system are subject
banner motd to having all their activities monitored and recorded by system personell.
banner motd Use of this system evidence an express consent to such monitoring and
banner motd agreement that if such monitoring reveals evidence of possible abuse or
banner motd criminal activity, system personnel may provide the result of such
banner motd monitoring to appropiate officials.
boot system disk0:/asa861-smp-k8.bin
ftp mode passive
clock timezone IST 5 30
dns server-group DefaultDNS
object network obj-172.29.0.0
subnet 172.29.0.0 255.255.0.0
object network obj-172.28.0.0
subnet 172.28.0.0 255.255.254.0
object network obj-172.28.2.0
subnet 172.28.2.0 255.255.254.0
object network obj-172.28.6.0
subnet 172.28.6.0 255.255.254.0
access-list 101 extended permit icmp any any
access-list 101 extended permit udp host x.x.x.x any
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool anyconnect-vpn 172.28.6.0-172.28.7.254 mask 255.255.254.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-66114.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static obj-172.29.0.0 obj-172.29.0.0 destination static obj-172.28.6.0 obj-172.28.6.0
nat (inside,outside) dynamic interface
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
route inside 172.28.0.0 255.255.254.0 172.29.0.1 1
route inside 172.28.2.0 255.255.254.0 172.29.0.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 0.0.0.0 0.0.0.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
no crypto isakmp nat-traversal
telnet 172.29.0.0 255.255.0.0 inside
telnet 172.28.0.0 255.255.254.0 inside
telnet timeout 7
ssh 0.0.0.0 0.0.0.0 inside
ssh 172.29.0.0 255.255.0.0 inside
ssh timeout 10
ssh version 2
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl encryption des-sha1
webvpn
enable outside
enable inside
anyconnect image disk0:/anyconnect-win-2.5.2014-k9.pkg 1
anyconnect image disk0:/anyconnect-macosx-i386-2.5.2014-k9.pkg 2
anyconnect image disk0:/anyconnect-linux-2.5.2014-k9.pkg 3
anyconnect enable
tunnel-group-list enable
group-policy anyconnect-vpn-policy internal
group-policy anyconnect-vpn-policy attributes
dns-server value 172.29.0.116 172.29.0.127
vpn-tunnel-protocol ikev1 ikev2 ssl-client ssl-clientless
address-pools value anyconnect-vpn
username testvpn password xxxxxxxxxxxxxxxx encrypted
username testvpn attributes
service-type remote-access
username mak password xxxxxxxxxxxx encrypted
tunnel-group anyconnect-vpn type remote-access
tunnel-group anyconnect-vpn general-attributes
default-group-policy anyconnect-vpn-policy
tunnel-group anyconnect-vpn webvpn-attributes
group-alias anyconnect-vpn-client enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect ipsec-pass-thru
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:8ea4cde746169523b128c2a306d0ce1f
: end
KUNAL HANS
Could this be the reason?
https://supportforums.cisco.com/docs/DOC-24550
Haven't had a chance to test it out yet.
