Problem : ASA VPN issue can't resolve name from local DNS
khahodeka
Cisco ASA VPN issue can't resolve name from local DNS
If i connect via LAN i can resolve name from DNS server normaly but when i connect vpn via internet
case 1 connect vpn use split tunnel for internal ip connect to tunnel and internet serf via local internet [can resolve form dns of connected internet ]
C:\>nslookup normanxak.local
*** Can't find server name for address 192.168.1.2: Non-existent domain
*** Can't find server name for address 192.168.1.18: Non-existent domain
Default Server:  dns1.asianet.co.th
Address:  203.144.207.29
*** dns1.asianet.co.th can't find normanxak.local: Non-existent domain
case 2 connect vpn no use split tunnel
C:\>nslookup
> normanxak.local
Addresses:  192.168.1.18, 192.168.1.17, 192.168.1.2
thank u for best support
5 Replies 5
hdashnau
In the group-policy you have split-dns setup as "split-dns value 192.168.1.2 192.168.1.18" This is incorrect.The values for the split-dns setting should not be IP addresses -- they need to be the internal domain name that you want to resolve over the tunnel. For example if I wanted my dns request for myhost.cisco.com to go over the tunnel and everything else (like xxxx.google.com or xxxx.yahoo.com) to use my normal Internet DNS server, in the group policy I would have "split-dns value cisco.com"
-heather
now i remove "
split-dns value 192.168.1.2 192.168.1.18 "
but i can't solve name same...
group-policy BO2VPN internal
group-policy BO2VPN attributes
dns-server value 192.168.1.2 192.168.1.18
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value BO2VPN_splitTunnelAcl
group-policy BO3VPN internal
group-policy BO3VPN attributes
khahodeka wrote:
now i remove "
I don't think he meant for you to remove the statement, but instead replace it with:
"split-dns value domain1.local domain2.local"
KimEriksen
Try set "asianet.co.th" to default domain under your vpn policy
Kim Eriksen
Field Engineer
Infolink ApS
Kim Eriksen, the solution worked wor me thanks
Nitin Mohan
