Problem with Remote Access VPN on ASA 5505
matt020191
I am currently having an issue configuring an ASA 5505 to connect via remote access VPN using the Cisco VPN Client 5.0.07.0440 running on Windows 8 Pro x64. The VPN client prompts for the username and password during the connect process, but fails soon after.
The VPN client logs are as follows:
Cisco Systems VPN Client Version 5.0.07.0440
Copyright (C) 1998-2010 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 6.2.9200
2      15:09:21.240  12/11/12  Sev=Info/4    CM/0x63100002
Begin connection process
3      15:09:21.287  12/11/12  Sev=Info/4    CM/0x63100004
Establish secure connection
4      15:09:21.287  12/11/12  Sev=Info/4    CM/0x63100024
Attempt connection with server "**.**.***.***"
5      15:09:21.287  12/11/12  Sev=Info/6    IKE/0x6300003B
Attempting to establish a connection with **.**.***.***.
6      15:09:21.287  12/11/12  Sev=Info/4    IKE/0x63000001
Starting IKE Phase 1 Negotiation
7      15:09:21.303  12/11/12  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to **.**.***.***
8      15:09:21.365  12/11/12  Sev=Info/6    GUI/0x63B00012
Authentication request attributes is 6h.
9      15:09:21.334  12/11/12  Sev=Info/5    IKE/0x6300002F
Received ISAKMP packet: peer = **.**.***.***
10     15:09:21.334  12/11/12  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, KE, NON, ID, HASH, VID(Unity), VID(Xauth), VID(dpd), VID(Nat-T), NAT-D, NAT-D, VID(Frag), VID(?)) from **.**.***.***
11     15:09:21.334  12/11/12  Sev=Info/5    IKE/0x63000001
Peer is a Cisco-Unity compliant peer
12     15:09:21.334  12/11/12  Sev=Info/5    IKE/0x63000001
Peer supports XAUTH
13     15:09:21.334  12/11/12  Sev=Info/5    IKE/0x63000001
Peer supports DPD
14     15:09:21.334  12/11/12  Sev=Info/5    IKE/0x63000001
Peer supports NAT-T
15     15:09:21.334  12/11/12  Sev=Info/5    IKE/0x63000001
Peer supports IKE fragmentation payloads
16     15:09:21.334  12/11/12  Sev=Info/6    IKE/0x63000001
IOS Vendor ID Contruction successful
17     15:09:21.334  12/11/12  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, NAT-D, NAT-D, VID(?), VID(Unity)) to **.**.***.***
18     15:09:21.334  12/11/12  Sev=Info/6    IKE/0x63000055
Sent a keepalive on the IPSec SA
19     15:09:21.334  12/11/12  Sev=Info/4    IKE/0x63000083
IKE Port in use - Local Port =  0xFBCE, Remote Port = 0x1194
20     15:09:21.334  12/11/12  Sev=Info/5    IKE/0x63000072
Automatic NAT Detection Status:
   Remote end is NOT behind a NAT device
   This   end IS behind a NAT device
21     15:09:21.334  12/11/12  Sev=Info/4    CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
22     15:09:21.365  12/11/12  Sev=Info/5    IKE/0x6300002F
23     15:09:21.365  12/11/12  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from **.**.***.***
24     15:09:21.365  12/11/12  Sev=Info/4    CM/0x63100015
Launch xAuth application
25     15:09:21.474  12/11/12  Sev=Info/4    IPSEC/0x63700008
IPSec driver successfully started
26     15:09:21.474  12/11/12  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
27     15:09:27.319  12/11/12  Sev=Info/4    CM/0x63100017
xAuth application returned
28     15:09:27.319  12/11/12  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to **.**.***.***
29     15:09:27.365  12/11/12  Sev=Info/5    IKE/0x6300002F
30     15:09:27.365  12/11/12  Sev=Info/4    IKE/0x63000014
31     15:09:27.365  12/11/12  Sev=Info/4    IKE/0x63000013
32     15:09:27.365  12/11/12  Sev=Info/4    CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system
33     15:09:27.365  12/11/12  Sev=Info/5    IKE/0x6300005E
Client sending a firewall request to concentrator
34     15:09:27.365  12/11/12  Sev=Info/4    IKE/0x63000013
35     15:09:27.397  12/11/12  Sev=Info/5    IKE/0x6300002F
36     15:09:27.397  12/11/12  Sev=Info/4    IKE/0x63000014
37     15:09:27.397  12/11/12  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_ADDRESS: , value = 192.168.2.70
38     15:09:27.397  12/11/12  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_NETMASK: , value = 255.255.255.0
39     15:09:27.397  12/11/12  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_DNS(1): , value = 192.168.2.1
40     15:09:27.397  12/11/12  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_DNS(2): , value = 8.8.8.8
41     15:09:27.397  12/11/12  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SAVEPWD: , value = 0x00000001
42     15:09:27.397  12/11/12  Sev=Info/5    IKE/0x6300000E
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_DEFDOMAIN: , value = NCHCO
43     15:09:27.397  12/11/12  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_PFS: , value = 0x00000000
44     15:09:27.397  12/11/12  Sev=Info/5    IKE/0x6300000E
MODE_CFG_REPLY: Attribute = APPLICATION_VERSION, value = Cisco Systems, Inc ASA5505 Version 8.2(5) built by builders on Fri 20-May-11 16:00
45     15:09:27.397  12/11/12  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SMARTCARD_REMOVAL_DISCONNECT: , value = 0x00000001
46     15:09:27.397  12/11/12  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = Received and using NAT-T port number , value = 0x00001194
47     15:09:27.397  12/11/12  Sev=Info/4    CM/0x63100019
Mode Config data received
48     15:09:27.412  12/11/12  Sev=Info/4    IKE/0x63000056
Received a key request from Driver: Local IP = 192.168.2.70, GW IP = **.**.***.***, Remote IP = 0.0.0.0
49     15:09:27.412  12/11/12  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK QM *(HASH, SA, NON, ID, ID) to **.**.***.***
50     15:09:27.444  12/11/12  Sev=Info/5    IKE/0x6300002F
51     15:09:27.444  12/11/12  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:STATUS_RESP_LIFETIME) from **.**.***.***
52     15:09:27.444  12/11/12  Sev=Info/5    IKE/0x63000045
RESPONDER-LIFETIME notify has value of 86400 seconds
53     15:09:27.444  12/11/12  Sev=Info/5    IKE/0x63000047
This SA has already been alive for 6 seconds, setting expiry to 86394 seconds from now
54     15:09:27.459  12/11/12  Sev=Info/5    IKE/0x6300002F
55     15:09:27.459  12/11/12  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:NO_PROPOSAL_CHOSEN) from **.**.***.***
56     15:09:27.459  12/11/12  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DEL) to **.**.***.***
57     15:09:27.459  12/11/12  Sev=Info/4    IKE/0x63000049
Discarding IPsec SA negotiation, MsgID=CE99A8A8
58     15:09:27.459  12/11/12  Sev=Info/4    IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=A3A341F1C7606AD5 R_Cookie=F1F403018625E924) reason = DEL_REASON_IKE_NEG_FAILED
59     15:09:27.459  12/11/12  Sev=Info/5    IKE/0x6300002F
60     15:09:27.459  12/11/12  Sev=Info/4    IKE/0x63000058
Received an ISAKMP message for a non-active SA, I_Cookie=A3A341F1C7606AD5 R_Cookie=F1F403018625E924
61     15:09:27.459  12/11/12  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(Dropped) from **.**.***.***
62     15:09:27.490  12/11/12  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
63     15:09:30.475  12/11/12  Sev=Info/4    IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=A3A341F1C7606AD5 R_Cookie=F1F403018625E924) reason = DEL_REASON_IKE_NEG_FAILED
64     15:09:30.475  12/11/12  Sev=Info/4    CM/0x63100012
Phase 1 SA deleted before first Phase 2 SA is up cause by "DEL_REASON_IKE_NEG_FAILED".  0 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
65     15:09:30.475  12/11/12  Sev=Info/5    CM/0x63100025
Initializing CVPNDrv
66     15:09:30.475  12/11/12  Sev=Info/6    CM/0x63100046
Set tunnel established flag in registry to 0.
67     15:09:30.475  12/11/12  Sev=Info/4    IKE/0x63000001
IKE received signal to terminate VPN connection
68     15:09:30.475  12/11/12  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
69     15:09:30.475  12/11/12  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
70     15:09:30.475  12/11/12  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
71     15:09:30.475  12/11/12  Sev=Info/4    IPSEC/0x6370000A
IPSec driver successfully stopped
The running configuration is as follows (there is a site-to-site VPN set up as well to another ASA 5505, but that is working flawlessly):
: Saved
ASA Version 8.2(5)
hostname NCHCO
enable password hTjwXz/V8EuTw9p9 encrypted
passwd hTjwXz/V8EuTw9p9 encrypted
names
name 192.168.2.0 NCHCO description City Offices
name 192.168.2.80 VPN_End
name 192.168.2.70 VPN_Start
interface Ethernet0/0
switchport access vlan 2
speed 100
duplex full
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address **.**.***.*** 255.255.255.248
boot system disk0:/asa825-k8.bin
ftp mode passive
access-list outside_nat0_outbound extended permit ip NCHCO 255.255.255.0 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip NCHCO 255.255.255.0 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip any 192.168.2.64 255.255.255.224
access-list outside_1_cryptomap extended permit ip NCHCO 255.255.255.0 192.168.1.0 255.255.255.0
access-list outside_1_cryptomap_1 extended permit ip NCHCO 255.255.255.0 192.168.1.0 255.255.255.0
access-list LAN_Access standard permit NCHCO 255.255.255.0
access-list LAN_Access standard permit 0.0.0.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool VPN_Pool VPN_Start-VPN_End mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-645.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
nat (outside) 0 access-list outside_nat0_outbound
route outside 0.0.0.0 0.0.0.0 74.219.208.49 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
network-acl outside_nat0_outbound
webvpn
  svc ask enable default svc
http server enable
http 192.168.1.0 255.255.255.0 inside
http **.**.***.*** 255.255.255.255 outside
http 74.218.158.238 255.255.255.255 outside
http NCHCO 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set l2tp-transform esp-3des esp-sha-hmac
crypto ipsec transform-set l2tp-transform mode transport
crypto ipsec transform-set vpn-transform esp-aes-256 esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec transform-set TRANS_ESP_3DES_MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set TRANS_ESP_3DES_MD5 mode transport
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map dyn-map 10 set pfs group1
crypto dynamic-map dyn-map 10 set transform-set l2tp-transform vpn-transform
crypto dynamic-map dyn-map 10 set reverse-route
crypto dynamic-map outside_dyn_map 20 set transform-set TRANS_ESP_3DES_MD5
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 74.219.208.50
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 20 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto map inside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map interface inside
crypto map vpn-map 1 match address outside_1_cryptomap_1
crypto map vpn-map 1 set pfs group1
crypto map vpn-map 1 set peer 74.219.208.50
crypto map vpn-map 1 set transform-set ESP-3DES-SHA
crypto map vpn-map 10 ipsec-isakmp dynamic dyn-map
crypto isakmp identity address
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 15
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 35
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp ipsec-over-tcp port 10000
client-update enable
telnet 192.168.1.0 255.255.255.0 inside
telnet NCHCO 255.255.255.0 inside
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh NCHCO 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd address 192.168.2.150-192.168.2.225 inside
dhcpd dns 216.68.4.10 216.68.5.10 interface inside
dhcpd lease 64000 interface inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
dns-server value 192.168.2.1
vpn-tunnel-protocol IPSec l2tp-ipsec
default-domain value nchco.local
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
password-storage enable
ipsec-udp enable
intercept-dhcp 255.255.255.0 enable
address-pools value VPN_Pool
group-policy NCHVPN internal
group-policy NCHVPN attributes
dns-server value 192.168.2.1 8.8.8.8
default-domain value NCHCO
username admin password LbMiJuAJjDaFb2uw encrypted privilege 15
username 8njferg password yB1lHEVmHZGj5C2Z encrypted privilege 15
username NCHvpn99 password QhZZtJfwbnowceB7 encrypted
tunnel-group DefaultRAGroup general-attributes
address-pool (inside) VPN_Pool
address-pool VPN_Pool
authentication-server-group (inside) LOCAL
authentication-server-group (outside) LOCAL
authorization-server-group LOCAL
authorization-server-group (inside) LOCAL
authorization-server-group (outside) LOCAL
default-group-policy DefaultRAGroup
strip-realm
strip-group
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *****
peer-id-validate nocheck
tunnel-group DefaultRAGroup ppp-attributes
no authentication chap
no authentication ms-chap-v1
authentication ms-chap-v2
tunnel-group DefaultWEBVPNGroup ppp-attributes
authentication pap
tunnel-group 74.219.208.50 type ipsec-l2l
tunnel-group 74.219.208.50 ipsec-attributes
tunnel-group NCHVPN type remote-access
tunnel-group NCHVPN general-attributes
default-group-policy NCHVPN
tunnel-group NCHVPN ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:15852745977ff159ba808c4a4feb61fa
: end
asdm location VPN_Start 255.255.255.255 inside
asdm location VPN_End 255.255.255.255 inside
Anyone have any idea why this is happening?
Thanks!
Also add, crypto dynamic-map outside_dyn_map 20 set reverse-route.
With Regards,
Safwan
9 Replies 9
Muhammed Safwan
Try by removing crypto dynamic-map outside_dyn_map 20 set transform-set TRANS_ESP_3DES_MD5
and add crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA. It should solve the problem
with Regards,
Safwan
Thank you very much, that fixed the connection problem!
However, the connection is not working 100%. I have it set up for split tunneling so the Internet can be accessed concurrently with the LAN behind the ASA, however, even though I do have internet access, I cannot access the LAN behind the ASA at all. Any idea why that is happening?
Here is the new running configuration:
: Saved
ASA Version 8.2(5)
hostname NCHCO
names
speed 100
duplex full
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
access-list inside_nat0_outbound extended permit ip 0.0.0.0 255.255.255.0 192.168.2.64 255.255.255.224
access-list NCHCO_splitTunnelAcl standard permit 0.0.0.0 255.255.255.0
access-list NCHCO_splitTunnelAcl_1 standard permit 0.0.0.0 255.255.255.0
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
webvpn
http server enable
http **.***.***.*** 255.255.255.255 outside
encryption 3des
hash md5
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
ipsec-udp enable
group-policy NCHCO internal
group-policy NCHCO attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value NCHCO_splitTunnelAcl_1
default-domain value NCHCO.local
strip-realm
strip-group
authentication pap
tunnel-group NCHCO type remote-access
tunnel-group NCHCO general-attributes
default-group-policy NCHCO
tunnel-group NCHCO ipsec-attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:00906b3d9f1ee2e8ec2a096407c2f506
: end
Thanks again!
Split tunnel ACL seems to be the issue.
Try by removing the ACL access-list NCHCO_splitTunnelAcl_1 standard permit 0.0.0.0 255.255.255.0
and add access-list NCHCO_splitTunnelAcl_1 standard permit 192.168.2.0 255.255.255.0
With Regards,
Safwan
Unfortunately, that didn't make a change. I did as you had requested, and I even double checked through ASDM that the NCHCO tunnel group was using that ACL for split tunneling, and verified that the static route for the 192.168.2.0 network was created correctly on the client computer, but any pings to IP addresses on the 192.168.2.0 network fail, and no hostnames resolve.
Here is the running configuration as of now with that change:
: Saved
ASA Version 8.4(1)
hostname NCHCO
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
speed 100
duplex full
boot system disk0:/asa841-k8.bin
ftp mode passive
object network NCHCO
subnet 192.168.2.0 255.255.255.0
object network obj-192.168.1.0
subnet 192.168.1.0 255.255.255.0
object network obj-192.168.2.64
subnet 192.168.2.64 255.255.255.224
object network obj-0.0.0.0
subnet 0.0.0.0 255.255.255.0
object network obj_any
subnet 0.0.0.0 0.0.0.0
access-list outside_nat0_outbound extended permit ip object NCHCO 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip object NCHCO 192.168.1.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip object NCHCO 192.168.1.0 255.255.255.0
access-list outside_1_cryptomap_1 extended permit ip object NCHCO 192.168.1.0 255.255.255.0
access-list LAN_Access standard permit 192.168.2.0 255.255.255.0
access-list AnyConnect_Client_Local_Print extended deny ip any any
access-list AnyConnect_Client_Local_Print extended permit tcp any any eq lpd
access-list AnyConnect_Client_Local_Print remark IPP: Internet Printing Protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any any eq 631
access-list AnyConnect_Client_Local_Print remark Windows' printing port
access-list AnyConnect_Client_Local_Print extended permit tcp any any eq 9100
access-list AnyConnect_Client_Local_Print remark mDNS: multicast DNS protocol
access-list AnyConnect_Client_Local_Print extended permit udp any host 224.0.0.251 eq 5353
access-list AnyConnect_Client_Local_Print remark LLMNR: Link Local Multicast Name Resolution protocol
access-list AnyConnect_Client_Local_Print extended permit udp any host 224.0.0.252 eq 5355
access-list AnyConnect_Client_Local_Print remark TCP/NetBIOS protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any any eq 137
access-list AnyConnect_Client_Local_Print extended permit udp any any eq netbios-ns
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
asdm image disk0:/asdm-649.bin
arp timeout 14400
nat (inside,any) source static NCHCO NCHCO destination static obj-192.168.1.0 obj-192.168.1.0
nat (inside,any) source static any any destination static obj-192.168.2.64 obj-192.168.2.64
nat (inside,any) source static obj-0.0.0.0 obj-0.0.0.0 destination static obj-192.168.2.64 obj-192.168.2.64
nat (inside,outside) dynamic interface
webvpn
http server enable
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set l2tp-transform esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set l2tp-transform mode transport
crypto ipsec ikev1 transform-set vpn-transform esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec ikev1 transform-set TRANS_ESP_3DES_MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set TRANS_ESP_3DES_MD5 mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map dyn-map 10 set ikev1 transform-set l2tp-transform vpn-transform
crypto dynamic-map outside_dyn_map 20 set ikev1 transform-set ESP-3DES-SHA
crypto map outside_map 1 set peer **.***.***.**
crypto map outside_map 1 set ikev1 transform-set ESP-3DES-SHA
crypto map vpn-map 1 set peer **.***.***.**
crypto map vpn-map 1 set ikev1 transform-set ESP-3DES-SHA
crypto ikev1 enable inside
crypto ikev1 enable outside
crypto ikev1 ipsec-over-tcp port 10000
crypto ikev1 policy 10
encryption 3des
hash md5
group 2
lifetime 86400
crypto ikev1 policy 15
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 35
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
vpn-tunnel-protocol ikev1 l2tp-ipsec
vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-client ssl-clientless
ipsec-udp enable
strip-realm
strip-group
ikev1 pre-shared-key *****
authentication pap
tunnel-group **.***.***.** type ipsec-l2l
tunnel-group **.***.***.** ipsec-attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:edae331358304d45edb0c43ec09f81d6
: end
Once again, i really appreciate all your help!
Add below command and connect the vpn, problem will be resolved.
access-list outside_nat0_outbound extended permit ip object NCHCO 192.168.2.0 255.255.255.0
With Regards,
Safwan
Thanks again for your reply, and sorry about the late response, havent gotten back to this issue until just now. I applied the above command as you specified, and unfortunately, it did not resolve the problem. Below are the logs from the VPN Client for the connection + attempted browsing of a network share that is behind the ASA, and the new running configuration.
VPN Client Log:
331    13:11:41.362  12/17/12  Sev=Info/4    CM/0x63100002
332    13:11:41.362  12/17/12  Sev=Info/4    CM/0x63100004
333    13:11:41.362  12/17/12  Sev=Info/4    CM/0x63100024
Attempt connection with server "69.61.228.178"
334    13:11:41.362  12/17/12  Sev=Info/6    IKE/0x6300003B
Attempting to establish a connection with 69.61.228.178.
335    13:11:41.362  12/17/12  Sev=Info/4    IKE/0x63000001
336    13:11:41.424  12/17/12  Sev=Info/6    GUI/0x63B00012
337    13:11:41.362  12/17/12  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 69.61.228.178
338    13:11:41.393  12/17/12  Sev=Info/5    IKE/0x6300002F
Received ISAKMP packet: peer = 69.61.228.178
339    13:11:41.393  12/17/12  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, KE, NON, ID, HASH, VID(Unity), VID(Xauth), VID(dpd), VID(Nat-T), NAT-D, NAT-D, VID(Frag), VID(?)) from 69.61.228.178
340    13:11:41.393  12/17/12  Sev=Info/5    IKE/0x63000001
341    13:11:41.393  12/17/12  Sev=Info/5    IKE/0x63000001
Peer supports XAUTH
342    13:11:41.393  12/17/12  Sev=Info/5    IKE/0x63000001
Peer supports DPD
343    13:11:41.393  12/17/12  Sev=Info/5    IKE/0x63000001
Peer supports NAT-T
344    13:11:41.393  12/17/12  Sev=Info/5    IKE/0x63000001
345    13:11:41.393  12/17/12  Sev=Info/6    IKE/0x63000001
346    13:11:41.393  12/17/12  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, NAT-D, NAT-D, VID(?), VID(Unity)) to 69.61.228.178
347    13:11:41.393  12/17/12  Sev=Info/6    IKE/0x63000055
348    13:11:41.393  12/17/12  Sev=Info/4    IKE/0x63000083
IKE Port in use - Local Port =  0xD271, Remote Port = 0x1194
349    13:11:41.393  12/17/12  Sev=Info/5    IKE/0x63000072
350    13:11:41.393  12/17/12  Sev=Info/4    CM/0x6310000E
351    13:11:41.424  12/17/12  Sev=Info/5    IKE/0x6300002F
352    13:11:41.424  12/17/12  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from 69.61.228.178
353    13:11:41.424  12/17/12  Sev=Info/4    CM/0x63100015
354    13:11:41.424  12/17/12  Sev=Info/4    CM/0x63100017
355    13:11:41.424  12/17/12  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 69.61.228.178
356    13:11:41.456  12/17/12  Sev=Info/5    IKE/0x6300002F
357    13:11:41.456  12/17/12  Sev=Info/4    IKE/0x63000014
358    13:11:41.456  12/17/12  Sev=Info/4    IKE/0x63000013
359    13:11:41.456  12/17/12  Sev=Info/4    CM/0x6310000E
360    13:11:41.456  12/17/12  Sev=Info/5    IKE/0x6300005E
361    13:11:41.456  12/17/12  Sev=Info/4    IKE/0x63000013
362    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x6300002F
363    13:11:41.502  12/17/12  Sev=Info/4    IKE/0x63000014
364    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x63000010
365    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x63000010
366    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x63000010
367    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x63000010
368    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x6300000D
369    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SPLIT_INCLUDE (# of split_nets), value = 0x00000001
370    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x6300000F
SPLIT_NET #1
    subnet = 192.168.2.0
    mask = 255.255.255.0
    protocol = 0
    src port = 0
    dest port=0
371    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x6300000E
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_DEFDOMAIN: , value = NCHCO.local
372    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x6300000D
373    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x6300000E
MODE_CFG_REPLY: Attribute = APPLICATION_VERSION, value = Cisco Systems, Inc ASA5505 Version 8.4(1) built by builders on Mon 31-Jan-11 02:11
374    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x6300000D
375    13:11:41.502  12/17/12  Sev=Info/5    IKE/0x6300000D
376    13:11:41.502  12/17/12  Sev=Info/4    CM/0x63100019
377    13:11:41.502  12/17/12  Sev=Info/4    IKE/0x63000056
Received a key request from Driver: Local IP = 192.168.2.70, GW IP = 69.61.228.178, Remote IP = 0.0.0.0
378    13:11:41.502  12/17/12  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK QM *(HASH, SA, NON, ID, ID) to 69.61.228.178
379    13:11:41.534  12/17/12  Sev=Info/5    IKE/0x6300002F
380    13:11:41.534  12/17/12  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:STATUS_RESP_LIFETIME) from 69.61.228.178
381    13:11:41.534  12/17/12  Sev=Info/5    IKE/0x63000045
382    13:11:41.534  12/17/12  Sev=Info/5    IKE/0x63000047
This SA has already been alive for 0 seconds, setting expiry to 86400 seconds from now
383    13:11:41.549  12/17/12  Sev=Info/5    IKE/0x6300002F
384    13:11:41.549  12/17/12  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK QM *(HASH, SA, NON, ID, ID, NOTIFY:STATUS_RESP_LIFETIME) from 69.61.228.178
385    13:11:41.549  12/17/12  Sev=Info/5    IKE/0x63000045
RESPONDER-LIFETIME notify has value of 28800 seconds
386    13:11:41.549  12/17/12  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK QM *(HASH) to 69.61.228.178
387    13:11:41.549  12/17/12  Sev=Info/5    IKE/0x63000059
Loading IPsec SA (MsgID=C4F5B5A6 OUTBOUND SPI = 0xD2DBADEA INBOUND SPI = 0x14762837)
388    13:11:41.549  12/17/12  Sev=Info/5    IKE/0x63000025
Loaded OUTBOUND ESP SPI: 0xD2DBADEA
389    13:11:41.549  12/17/12  Sev=Info/5    IKE/0x63000026
Loaded INBOUND ESP SPI: 0x14762837
390    13:11:41.549  12/17/12  Sev=Info/5    CVPND/0x63400013
    Destination           Netmask           Gateway         Interface   Metric
        0.0.0.0           0.0.0.0       192.168.1.1     192.168.1.162       10
      127.0.0.0         255.0.0.0         127.0.0.1         127.0.0.1      306
      127.0.0.1   255.255.255.255         127.0.0.1         127.0.0.1      306
127.255.255.255   255.255.255.255         127.0.0.1         127.0.0.1      306
    192.168.1.0     255.255.255.0     192.168.1.162     192.168.1.162      266
  192.168.1.162   255.255.255.255     192.168.1.162     192.168.1.162      266
  192.168.1.255   255.255.255.255     192.168.1.162     192.168.1.162      266
      224.0.0.0         240.0.0.0         127.0.0.1         127.0.0.1      306
      224.0.0.0         240.0.0.0     192.168.1.162     192.168.1.162      266
255.255.255.255   255.255.255.255         127.0.0.1         127.0.0.1      306
255.255.255.255   255.255.255.255     192.168.1.162     192.168.1.162      266
391    13:11:41.877  12/17/12  Sev=Info/6    CVPND/0x63400001
Launch VAInst64 to control IPSec Virtual Adapter
392    13:11:43.455  12/17/12  Sev=Info/4    CM/0x63100034
The Virtual Adapter was enabled:
    IP=192.168.2.70/255.255.255.0
    DNS=192.168.2.1,8.8.8.8
    WINS=0.0.0.0,0.0.0.0
    Domain=NCHCO.local
    Split DNS Names=
393    13:11:43.455  12/17/12  Sev=Info/5    CVPND/0x63400013
      224.0.0.0         240.0.0.0           0.0.0.0           0.0.0.0      266
255.255.255.255   255.255.255.255           0.0.0.0           0.0.0.0      266
394    13:11:47.517  12/17/12  Sev=Info/4    CM/0x63100038
Successfully saved route changes to file.
395    13:11:47.517  12/17/12  Sev=Info/5    CVPND/0x63400013
  69.61.228.178   255.255.255.255       192.168.1.1     192.168.1.162      100
    192.168.1.2   255.255.255.255     192.168.1.162     192.168.1.162      100
    192.168.2.0     255.255.255.0      192.168.2.70      192.168.2.70      266
    192.168.2.0     255.255.255.0       192.168.2.1      192.168.2.70      100
   192.168.2.70   255.255.255.255      192.168.2.70      192.168.2.70      266
  192.168.2.255   255.255.255.255      192.168.2.70      192.168.2.70      266
      224.0.0.0         240.0.0.0      192.168.2.70      192.168.2.70      266
255.255.255.255   255.255.255.255      192.168.2.70      192.168.2.70      266
396    13:11:47.517  12/17/12  Sev=Info/6    CM/0x63100036
The routing table was updated for the Virtual Adapter
397    13:11:47.517  12/17/12  Sev=Info/4    CM/0x6310001A
One secure connection established
398    13:11:47.517  12/17/12  Sev=Info/4    CM/0x6310003B
Address watch added for 192.168.1.162.  Current hostname: MATT-PC, Current address(es): 192.168.2.70, 192.168.1.162.
399    13:11:47.517  12/17/12  Sev=Info/4    CM/0x6310003B
Address watch added for 192.168.2.70.  Current hostname: MATT-PC, Current address(es): 192.168.2.70, 192.168.1.162.
400    13:11:47.517  12/17/12  Sev=Info/5    CM/0x63100001
Did not find the Smartcard to watch for removal
401    13:11:47.517  12/17/12  Sev=Info/4    IPSEC/0x63700008
402    13:11:47.517  12/17/12  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
403    13:11:47.517  12/17/12  Sev=Info/6    IPSEC/0x6370002C
Sent 109 packets, 0 were fragmented.
404    13:11:47.517  12/17/12  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
405    13:11:47.517  12/17/12  Sev=Info/4    IPSEC/0x63700010
Created a new key structure
406    13:11:47.517  12/17/12  Sev=Info/4    IPSEC/0x6370000F
Added key with SPI=0xeaaddbd2 into key list
407    13:11:47.517  12/17/12  Sev=Info/4    IPSEC/0x63700010
408    13:11:47.517  12/17/12  Sev=Info/4    IPSEC/0x6370000F
Added key with SPI=0x37287614 into key list
409    13:11:47.517  12/17/12  Sev=Info/4    IPSEC/0x6370002F
Assigned VA private interface addr 192.168.2.70
410    13:11:47.517  12/17/12  Sev=Info/4    IPSEC/0x63700037
Configure public interface: 192.168.1.162. SG: 69.61.228.178
411    13:11:47.517  12/17/12  Sev=Info/6    CM/0x63100046
Set tunnel established flag in registry to 1.
412    13:11:52.688  12/17/12  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, NOTIFY:DPD_REQUEST) to 69.61.228.178
413    13:11:52.688  12/17/12  Sev=Info/6    IKE/0x6300003D
Sending DPD request to 69.61.228.178, our seq# = 2722476009
414    13:11:52.704  12/17/12  Sev=Info/5    IKE/0x6300002F
415    13:11:52.704  12/17/12  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:DPD_ACK) from 69.61.228.178
416    13:11:52.704  12/17/12  Sev=Info/5    IKE/0x63000040
Received DPD ACK from 69.61.228.178, seq# received = 2722476009, seq# expected = 2722476009
417    13:12:03.187  12/17/12  Sev=Info/4    IKE/0x63000013
418    13:12:03.187  12/17/12  Sev=Info/6    IKE/0x6300003D
Sending DPD request to 69.61.228.178, our seq# = 2722476010
419    13:12:03.202  12/17/12  Sev=Info/5    IKE/0x6300002F
420    13:12:03.202  12/17/12  Sev=Info/4    IKE/0x63000014
421    13:12:03.202  12/17/12  Sev=Info/5    IKE/0x63000040
Received DPD ACK from 69.61.228.178, seq# received = 2722476010, seq# expected = 2722476010
422    13:12:14.185  12/17/12  Sev=Info/4    IKE/0x63000013
423    13:12:14.185  12/17/12  Sev=Info/6    IKE/0x6300003D
Sending DPD request to 69.61.228.178, our seq# = 2722476011
424    13:12:14.201  12/17/12  Sev=Info/5    IKE/0x6300002F
425    13:12:14.201  12/17/12  Sev=Info/4    IKE/0x63000014
426    13:12:14.201  12/17/12  Sev=Info/5    IKE/0x63000040
Received DPD ACK from 69.61.228.178, seq# received = 2722476011, seq# expected = 2722476011
427    13:12:24.762  12/17/12  Sev=Info/4    IKE/0x63000013
428    13:12:24.762  12/17/12  Sev=Info/6    IKE/0x6300003D
Sending DPD request to 69.61.228.178, our seq# = 2722476012
429    13:12:24.778  12/17/12  Sev=Info/5    IKE/0x6300002F
430    13:12:24.778  12/17/12  Sev=Info/4    IKE/0x63000014
431    13:12:24.778  12/17/12  Sev=Info/5    IKE/0x63000040
Received DPD ACK from 69.61.228.178, seq# received = 2722476012, seq# expected = 2722476012
New running configuration:
: Saved
ASA Version 8.4(1)
hostname NCHCO
names
interface Vlan1
 nameif inside
 security-level 100
interface Vlan2
 nameif outside
 security-level 0
 ip address 69.61.228.178 255.255.255.248
 speed 100
 duplex full
ftp mode passive
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 69.61.228.177 1
 webvpn
http server enable
http 69.61.228.178 255.255.255.255 outside
 encryption 3des
 hash md5
 group 2
 lifetime 86400
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
 encryption 3des
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
 ipsec-udp enable
username NCHvpn99 password dhn.JzttvRmMbHsP encrypted
 strip-realm
 strip-group
 authentication pap
 parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
call-home
 profile CiscoTAC-1
  no active
Cryptochecksum:b6ce58676b6aaeba48caacbeefea53a5
: end
I'm at a loss myself as to why this isn't working, and i'm sure that you are running out of solutions yourself. Any other ideas? I really need to get this working.
Thanks so much!
Matthew
your config looks good now, How you are accessing the network share?. Is it using hostname or ip address. Did you try ping  netwok share server,  dns server ie. 192.168.2.1
With Regards,
Safwan
With Regards,
Safwan
That did it! Thanks so much for your help. My client will be one happy guy now that he can work from home.
