555
Beginner
Problem with VPN between 5510 and 881
Hi I setup a vpn lan to lan between a cisco 5510 and 881.
I setup both box using the wizzard assiten and I see the vpn up but  i can make a ping between lans.
I try using difernte configuration and i see alway the same.
I can acces to ASA but in it it're work some other vpn and i dont know were're the problem and i need to be sure that my setup at my cisco 881 it's ok.
The diagagram of my vpn is :
10.57.88.1      : C881: 181.81.57.47 --- Internet --- 90.11.11.202 : ASA5510 : 10.57.1.10
10.57.88.0/27        10.57.0.0/18
The setup and some show are :
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key 1234567890 address 90.11.11.202
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode tunnel
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
mode tunnel
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
mode tunnel
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to90.11.11.202
set peer 90.11.11.202
set transform-set ESP-3DES-SHA2
match address 103
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description $ETH-WAN$
ip address 181.81.57.47 255.255.248.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
description $ETH_LAN$
ip address 10.57.88.1 255.255.255.224
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 186.80.64.1
ip sla auto discovery
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.57.88.0 0.0.0.31
access-list 23 permit 10.57.88.0 0.0.0.31
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.57.88.0 0.0.0.31 10.57.0.0 0.0.63.255
access-list 101 remark CCP_ACL Category=2
access-list 101 remark IPSec Rule
access-list 101 deny   ip 10.57.88.0 0.0.0.31 10.57.0.0 0.0.63.255
access-list 101 permit ip 10.57.88.0 0.0.0.31 any
access-list 102 remark CCP_ACL Category=4
access-list 102 remark IPSec Rule
access-list 102 permit ip 186.80.56.0 0.0.7.255 10.57.0.0 0.0.63.255
access-list 103 remark CCP_ACL Category=4
access-list 103 remark IPSec Rule
access-list 103 permit ip 10.57.88.0 0.0.0.31 10.57.0.0 0.0.63.255
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 101
banner exec ^C
^C.
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
end
MCQ#sh cry session detail
Crypto session current status
Code: C - IKE Configuration mode, D - Dead Peer Detection
K - Keepalives, N - NAT-traversal, T - cTCP encapsulation
X - IKE Extended Authentication, F - IKE Fragmentation
Interface: FastEthernet4
Uptime: 02:19:33
Session status: UP-ACTIVE
Peer: 90.11.11.202 port 500 fvrf: (none) ivrf: (none)
      Phase1_id: 90.11.11.202
      Desc: (none)
  IKEv1 SA: local 181.81.57.47/500 remote 90.11.11.202/500 Active
          Capabilities:(none) connid:2001 lifetime:21:40:26
  IPSEC FLOW: permit ip 10.57.88.0/255.255.255.224 10.57.0.0/255.255.192.0
        Active SAs: 2, origin: crypto map
        Inbound:  #pkts dec'ed 2643 drop 0 life (KB/Sec) 4210590/2043
        Outbound: #pkts enc'ed 5410 drop 0 life (KB/Sec) 4210567/2043
MCQ#sh crypto ipsec sa detail
interface: FastEthernet4
    Crypto map tag: SDM_CMAP_1, local addr 181.81.57.47
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (10.57.88.0/255.255.255.224/0/0)
   remote ident (addr/mask/prot/port): (10.57.0.0/255.255.192.0/0/0)
   current_peer 90.11.11.202 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 5422, #pkts encrypt: 5422, #pkts digest: 5422
    #pkts decaps: 2643, #pkts decrypt: 2643, #pkts verify: 2643
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #pkts no sa (send) 0, #pkts invalid sa (rcv) 0
    #pkts encaps failed (send) 0, #pkts decaps failed (rcv) 0
    #pkts invalid prot (recv) 0, #pkts verify failed: 0
    #pkts invalid identity (recv) 0, #pkts invalid len (rcv) 0
    #pkts replay rollover (send): 0, #pkts replay rollover (rcv) 0
    ##pkts replay failed (rcv): 0
    #pkts tagged (send): 0, #pkts untagged (rcv): 0
    #pkts not tagged (send): 0, #pkts not untagged (rcv): 0
    #pkts internal err (send): 0, #pkts internal err (recv) 0
     local crypto endpt.: 181.81.57.47, remote crypto endpt.: 90.11.11.202
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet4
     current outbound spi: 0xA9082DFD(2835885565)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
      spi: 0x9C615383(2623624067)
        transform: esp-3des esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 5, flow_id: Onboard VPN:5, sibling_flags 80000040, crypto map: SDM_CMAP_1
        sa timing: remaining key lifetime (k/sec): (4210590/1988)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE(ACTIVE)
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
MCQ#sh crypto route
No VPN routes to display
MCQ#sh crypto isakmp sa detail
Codes: C - IKE configuration mode, D - Dead Peer Detection
       T - cTCP encapsulation, X - IKE Extended Authentication
       psk - Preshared key, rsig - RSA signature
       renc - RSA encryption
IPv4 Crypto ISAKMP SA
C-id  Local           Remote          I-VRF  Status Encr Hash   Auth DH Lifetime Cap.
2001  181.81.57.47    90.11.11.202          ACTIVE 3des sha    psk  2  21:38:21
       Engine-id:Conn-id =  SW:1
IPv6 Crypto ISAKMP SA
MCQ#sh crypto ruleset detail
Mtree:
199 VRF 0  11 181.81.57.47/500 ANY Forward, Forward
299 VRF 0  11 181.81.57.47/4500 ANY Forward, Forward
200000199 VRF 0  11 ANY/848 ANY Forward, Forward
200000299 VRF 0  11 ANY ANY/848 Forward, Forward
100000000000101 VRF 0 IP 10.57.88.0/27 10.57.0.0/18 Discard/notify, Encrypt
100000000000199 VRF 0 IP 10.57.88.0/27 10.57.0.0/18 Discard/notify, Discard/notify
MCQ#sh crypto map interface FastEthernet4
Crypto Map IPv4 "SDM_CMAP_1" 1 ipsec-isakmp
        Description: Tunnel to90.11.11.202
        Peer = 90.11.11.202
        Extended IP access list 103
        Current peer: 90.11.11.202
        Security association lifetime: 4608000 kilobytes/3600 seconds
        Responder-Only (Y/N): N
        PFS (Y/N): N
        Transform sets={
                ESP-3DES-SHA2:  { esp-3des esp-sha-hmac  } ,
        Interfaces using crypto map SDM_CMAP_1:
                FastEthernet4
Everyone's tags (5)
2 REPLIES 2
Contributor
Can you check for a NAT exemption on the ASA? Using ASDM you should see some logs when you ping from 881-LAN to ASA-LAN
Michael
Please rate all helpful posts
Michael Please rate all helpful posts
Highlighted
Beginner
Hi, i found the problem, i check a setup in ASA and found that the default in ASA is other GW  than the gateway of peer.
I create a route that send all traficto fo 10.57.88.0/27 to gateway of ASA peer and it work.
Thanks for you help.
