04-09-2013 09:17 AM
I have two problems with IPSEC VPN, using the cisco client and a third that I think could be answered here though it is not strictly VPN related.
1. Cannot get to the internet while VPN is up. This may be a client issue as I *think* I have split tunneling setup correctly.
2. Cannot access other networks except the natively attached network to the inside interface.
3. I cannot ping out to the internet from inside, whether on VPN or not.
I tend to use teh ADSM; please, if possible, keep response to that kindof input.
Here is the config:
Result of the command: "sh run"
: Saved
ASA Version 8.4(1)
hostname BVGW
domain-name blueVector.com
enable password qWxO.XjLGf3hYkQ1 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif Outside
security-level 10
ip address 5.29.79.10 255.255.255.248
interface Ethernet0/1
nameif Inside
security-level 100
ip address 172.17.1.2 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 172.19.1.1 255.255.255.0
management-only
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network WiFi
subnet 172.17.100.0 255.255.255.0
description WiFi
object network inside-net
subnet 172.17.1.0 255.255.255.0
object network NOSPAM
host 172.17.1.60
object network BH2
host 172.17.1.60
object network EX2
host 172.17.1.61
description Internal Exchange / Outbound SMTP
object network Mail2
host 5.29.79.11
description Ext EX2
object network NETWORK_OBJ_172.17.1.240_28
subnet 172.17.1.240 255.255.255.240
object network NETWORK_OBJ_172.17.200.0_24
subnet 172.17.200.0 255.255.255.0
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq https
object-group network DM_INLINE_NETWORK_1
network-object object BH2
network-object object NOSPAM
access-list Outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_1 eq smtp
access-list Outside_access_in extended permit tcp any object BH2 object-group DM_INLINE_TCP_1
pager lines 24
logging enable
logging asdm informational
mtu Outside 1500
mtu Inside 1500
mtu management 1500
ip local pool VPN 172.17.1.240-172.17.1.250 mask 255.255.255.0
ip local pool VPN2 172.17.200.100-172.17.200.200 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (Inside,Outside) source static EX2 Mail2
nat (Inside,Outside) source static any any destination static NETWORK_OBJ_172.17.1.240_28 NETWORK_OBJ_172.17.1.240_28
nat (Inside,Outside) source static any any destination static NETWORK_OBJ_172.17.200.0_24 NETWORK_OBJ_172.17.200.0_24
nat (Inside,Outside) source static inside-net inside-net destination static NETWORK_OBJ_172.17.1.240_28 NETWORK_OBJ_172.17.1.240_28
nat (Inside,Outside) dynamic interface
nat (Inside,Outside) static 5.29.79.12
access-group Outside_access_in in interface Outside
route Outside 0.0.0.0 0.0.0.0 5.29.79.9 1
route Inside 10.2.0.0 255.255.255.0 172.17.1.1 1
route Inside 10.3.0.0 255.255.255.128 172.17.1.1 1
route Inside 10.10.10.0 255.255.255.0 172.17.1.1 1
route Inside 172.17.100.0 255.255.255.0 172.17.1.3 1
route Inside 172.18.1.0 255.255.255.0 172.17.1.1 1
route Inside 192.168.1.0 255.255.255.0 172.17.1.1 1
route Inside 192.168.11.0 255.255.255.0 172.17.1.1 1
route Inside 192.168.30.0 255.255.255.0 172.17.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server blueVec protocol ldap
aaa-server blueVec (Inside) host 172.17.1.41
ldap-base-dn DC=adrs1,DC=net
ldap-group-base-dn DC=adrs,DC=net
ldap-scope subtree
ldap-naming-attribute sAMAccountName
ldap-login-password *****
ldap-login-dn CN=Hanna\, Roger,OU=Humans,OU=WPLAdministrator,DC=adrs1,DC=net
server-type microsoft
http server enable
http 192.168.1.0 255.255.255.0 management
http 172.17.1.0 255.255.255.0 Inside
http 24.32.208.223 255.255.255.255 Outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map Outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map Outside_map interface Outside
crypto ikev1 enable Outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication crack
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 172.17.1.0 255.255.255.0 Inside
ssh timeout 5
console timeout 0
dhcpd address 172.17.1.100-172.17.1.200 Inside
dhcpd dns 4.2.2.2 8.8.8.8 interface Inside
dhcpd lease 100000 interface Inside
dhcpd domain adrs1.net interface Inside
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
group-policy blueV internal
group-policy blueV attributes
wins-server value 172.17.1.41
dns-server value 172.17.1.41 172.17.1.42
vpn-tunnel-protocol ikev1
default-domain value ADRS1.NET
group-policy blueV_1 internal
group-policy blueV_1 attributes
split-tunnel-policy tunnelspecified
default-domain value adrs1.net
username gwhitten password 8fLfC1TTV35zytjA encrypted privilege 0
username gwhitten attributes
vpn-group-policy blueV
username rparker password FnbvAdOZxk4r40E5 encrypted privilege 15
username rparker attributes
username mhale password 2reWKpsLC5em3o1P encrypted privilege 0
username mhale attributes
username VpnUser2 password SlHbkDWqPQLgylxJ encrypted privilege 0
username VpnUser2 attributes
username Vpnuser3 password R6zHxBM9chjqBPHl encrypted privilege 0
username Vpnuser3 attributes
username VpnUser1 password mLHXwxsjJEIziFgb encrypted privilege 0
username VpnUser1 attributes
username dcoletto password g53yRiEqpcYkSyYS encrypted privilege 0
username dcoletto attributes
username jmcleod password aSV6RHsq7Wn/YJ7X encrypted privilege 0
username jmcleod attributes
username rhanna password Pd3E3vqnGmV84Ds2 encrypted privilege 15
username rhanna attributes
username rheimann password tHH5ZYDXJ0qKyxnk encrypted privilege 0
username rheimann attributes
username jwoosley password yBOc8ubzzbeBXmuo encrypted privilege 0
username jwoosley attributes
username kdavis password 2DBQVSUbfTBuxC8u encrypted privilege 0
username kdavis attributes
username mbell password adskOOsnVPnw6eJD encrypted privilege 0
username mbell attributes
username bmiller password dpqK9cKk50J7TuPN encrypted privilege 0
username bmiller attributes
tunnel-group blueV type remote-access
tunnel-group blueV general-attributes
address-pool VPN2
authentication-server-group blueVec
default-group-policy blueV_1
tunnel-group blueV ipsec-attributes
ikev1 pre-shablue-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
hpm topN enable
Cryptochecksum:2491a825fb8a81439a6c80288f33818e
: end
Any help appreciated!!!!
-Roger
Solved! Go to Solution.
04-09-2013 09:34 AM
Hey,
Sadly I dont use ASDM myself but will still mention the things that might be done.
You are not using Split Tunneling. All traffic is Tunneled to the ASA while VPN is active
You have the following line under the "group-policy"
You will also need this line
split-tunnel-network-list value
Which defines the destination networks for the VPN Client. If you go to the Group-policy settings on the ASDM side you should see that no ACL is selected. You dont actually seem to have any ACL in the above configuration meant for Split Tunneling?
To enable Internet access through the VPN Client now in the current configuration I would suggest the following NAT configuration
object-group network VPN-CLIENT-PAT-SOURCE
network-object 172.17.200.0 255.255.255.0
nat (Outside,Outside) after-auto source dynamic VPN-CLIENT-PAT-SOURCE interface
With regards to the traffic not working for the other networks I am not really sure. I guess they arent hitting the NAT rule which are configured. I think they should but I guess they are not since its not working
I might myself try out the following NAT configuration
object-group network LAN-NETWORKS
network-object 10.2.0.0 255.255.255.0
network-object 10.3.0.0 255.255.255.128
network-object 10.10.10.0 255.255.255.0
network-object 172.17.100.0 255.255.255.0
network-object 172.18.1.0 255.255.255.0
network-object 192.168.1.0 255.255.255.0
network-object 192.168.11.0 255.255.255.0
network-object 192.168.30.0 255.255.255.0
object-group network VPN-POOL
nat (Inside,Outside) source static LAN-NETWORKS LAN-NETWORKS destination static VPN-POOL VPN-POOL
For ICMP add the ICMP Inspection
inspect icmp
or alternatively
fixup protocol icmp
This will automatically allow the ICMP Echo Reply messages to get through the firewall. I presume they are getting blocked by the firewall now since you have not previously enabled ICMP Inspection.
- Jouni
04-09-2013 09:34 AM
Hey,
inspect icmp
or alternatively
fixup protocol icmp
- Jouni
04-24-2013 10:32 AM
Sorry for delay in getting back.
Well that helped with the internet access issue; Thanks!.
I still cannot get access to the internal networks; I am posting the SH RUN below as current config if anyone has a thought. FYI: The core switch is a 3750, handling routing and I can access these networks fine form a machine hooked to the core (172.17.1.1).
: Saved
ASA Version 8.4(1)
hostname RVGW
domain-name RedVector.com
enable password b5aqRk/6.KRmypWW encrypted
passwd 1ems91jznlfZHhfU encrypted
names
nameif Outside
security-level 10
nameif Inside
security-level 100
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
banner login RedV GW
ftp mode passive
object network WiFi
description WiFi
host 172.17.1.60
object network BH2
host 172.17.1.60
object network EX2
host 172.17.1.61
host 5.29.79.11
description Ext EX2
object network VPN-CLIENT
port-object eq www
description VPN-CLIENT-PAT-SOURCE
network-object object VPN-CLIENT
network-object host 10.10.10.0
network-object host 10.2.0.0
network-object host 172.17.100.0
network-object host 172.18.1.0
network-object host 192.168.1.0
network-object host 192.168.11.0
network-object host 192.168.30.0
network-object host 10.3.0.0
network-object host 172.17.200.0
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object icmp
access-list global_mpc extended permit ip any any
access-list Inside_access_in extended permit object-group DM_INLINE_PROTOCOL_1 any any
pager lines 24
logging enable
no logging message 106015
no logging message 313001
no logging message 313008
no logging message 106023
no logging message 710003
no logging message 106100
no logging message 302015
no logging message 302014
no logging message 302013
no logging message 302018
no logging message 302017
no logging message 302016
no logging message 302021
no logging message 302020
flow-export destination Inside 172.17.1.52 9996
mtu Outside 1500
mtu Inside 1500
mtu management 1500
no failover
arp timeout 14400
access-group Inside_access_in in interface Inside
aaa-server RedVec protocol ldap
aaa-server RedVec (Inside) host 172.17.1.41
ldap-scope subtree
aaa authentication ssh console LOCAL
http server enable
snmp-server host Inside 172.17.1.52 community *****
snmp-server location Server Room 3010
snmp-server contact Roger Hanna
snmp-server community *****
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
telnet 172.17.1.0 255.255.255.0 Inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 172.17.1.41 172.17.1.42 interface Inside
webvpn
group-policy RedV internal
group-policy RedV attributes
group-policy RedV_1 internal
group-policy RedV_1 attributes
username xxxxxxx password FnbvAdOZxk4r40E5 encrypted privilege 15
username xxxxxxx attributes
vpn-group-policy RedV
username xxxxxxx password 2reWKpsLC5em3o1P encrypted privilege 0
username xxxxxxx password Pd3E3vqnGmV84Ds2 encrypted privilege 15
tunnel-group RedV type remote-access
tunnel-group RedV general-attributes
address-pool VPN2
authentication-server-group RedVec
default-group-policy RedV_1
tunnel-group RedV ipsec-attributes
ikev1 pre-shared-key *****
class-map global-class
match access-list global_mpc
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
class global-class
flow-export event-type all destination 172.17.1.52
call-home
profile CiscoTAC-1
no active
hpm topN enable
Cryptochecksum:69bf9a78c46c081d1d386fa6d2c2adb0
: end
04-24-2013 02:20 PM
Can you post the current routing table from your 3750? This sounds like a routing issue on that device.
Matt
04-24-2013 02:31 PM
Sure, Here you go:
Things to keep in mind:
172.17.1.2 is internal int 5510
172.17.1.10 is upstream router to other networks
172.17.1.3 is wifi router
ip default-gateway 172.17.1.2
ip classless
ip route 0.0.0.0 0.0.0.0 172.17.1.2
ip route 10.2.0.0 255.255.255.0 172.17.1.10
ip route 10.3.0.128 255.255.255.128 172.17.1.10
ip route 10.10.10.0 255.255.255.0 172.17.1.10
ip route 10.20.0.0 255.255.255.0 172.17.1.10
ip route 172.17.100.0 255.255.255.0 172.17.1.3
ip route 172.17.200.0 255.255.255.0 172.17.1.2
ip route 172.18.1.0 255.255.255.0 172.17.1.10
ip route 192.168.1.0 255.255.255.0 172.17.1.10
ip route 192.168.11.0 255.255.255.0 172.17.1.10
ip route 192.168.30.0 255.255.255.0 172.17.1.10
ip http server
04-24-2013 02:53 PM
I'm sure you're already aware of this, but your routing table is correct. You really don't need the static route for the 172.17.200.0/24.
One thing I noticed in your latest config is that your tunnel group is configured to use the RedV_1 group-policy, but your users are configured to use the RedV group-policy. Is that by design?
Also, it appears your object groups called LAN-NETWORKS and VPN-POOL contain host addresses, not subnets like Jouni recommended. Enter the following at the command line:
config t
no network-object host 10.10.10.0
no network-object host 10.2.0.0
no network-object host 172.17.100.0
no network-object host 172.18.1.0
no network-object host 192.168.1.0
no network-object host 192.168.11.0
no network-object host 192.168.30.0
no network-object host 10.3.0.0
no network-object host 172.17.200.0
end
wr
Matt
05-02-2013 08:35 AM
Ok, I think I have everything setup as suggested now but still not working. I cannot ping the host I need to access (10.2.0.125) through the firewall though I can ping the core router and anything in the 172.17.1.0/24 subnet. And a tracert is REALLY wierd, showing a single hop the the system I am trying to reach and then solid astericks for the next 29 lines.
Here is the config
ASA Version 8.4(1)
hostname RVGW
names
nameif Outside
security-level 10
nameif Inside
security-level 100
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
ftp mode passive
object network WiFi
description WiFi
host 172.17.1.60
object network BH2
host 172.17.1.60
object network EX2
host 172.17.1.61
host 5.29.79.11
description Ext EX2
port-object eq www
network-object 10.3.0.0 255.255.255.0
protocol-object ip
pager lines 24
logging enable
mtu Outside 1500
mtu Inside 1500
mtu management 1500
no failover
arp timeout 14400
ldap-scope subtree
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
address-pool VPN2
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
class global-class
call-home
profile CiscoTAC-1
no active
hpm topN enable
Cryptochecksum:35d60ea06316769de21761bd29ace22e
