12-31-2012 03:36 PM - edited 02-21-2020 06:35 PM
Hi experts,
We got some Avaya VPN phones. After the ASA firmware upgrade from 8.0.2 to 8.4.5 the phone is not working anymore...The VPN still works for the PC vpn client software... I have verified the isakmp preshared key several times... Here is output of "debug crypto ikev1 11" and "debug crypto ipsec 11"
fw-vadc-01#
fw-vadc-01#
fw-vadc-01# Dec 31 09:05:27 [IKEv1]IP = 209.82.99.145, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + KE (4) + NONCE (10) + ID (5) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 372
Dec 31 09:05:27 [IKEv1 DEBUG]IP = 209.82.99.145, processing SA payload
Dec 31 09:05:27 [IKEv1 DEBUG]IP = 209.82.99.145, processing ke payload
Dec 31 09:05:27 [IKEv1 DEBUG]IP = 209.82.99.145, processing ISA_KE payload
Dec 31 09:05:27 [IKEv1 DEBUG]IP = 209.82.99.145, processing nonce payload
Dec 31 09:05:27 [IKEv1 DEBUG]IP = 209.82.99.145, processing ID payload
Dec 31 09:05:27 [IKEv1 DEBUG]IP = 209.82.99.145, processing VID payload
Dec 31 09:05:27 [IKEv1 DEBUG]IP = 209.82.99.145, Received NAT-Traversal RFC VID
Dec 31 09:05:27 [IKEv1 DEBUG]IP = 209.82.99.145, Received NAT-Traversal ver 02 VID
Dec 31 09:05:27 [IKEv1 DEBUG]IP = 209.82.99.145, Received xauth V6 VID
Dec 31 09:05:27 [IKEv1]IP = 209.82.99.145, Connection landed on tunnel_group gtphones
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, processing IKE SA payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, IKE SA Proposal # 1, Transform # 1 acceptable Matches global IKE entry # 1
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, constructing ISAKMP SA payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, constructing ke payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, constructing nonce payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, Generating keys for Responder...
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, constructing ID payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, constructing hash payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, Computing hash for ISAKMP
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, constructing Cisco Unity VID payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, constructing xauth V6 VID payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, constructing dpd vid payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, constructing NAT-Traversal VID ver RFC payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, constructing NAT-Discovery payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, computing NAT Discovery hash
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, constructing Fragmentation VID + extended capabilities payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, constructing VID payload
Dec 31 09:05:27 [IKEv1 DEBUG]Group = gtphones, IP = 209.82.99.145, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Dec 31 09:05:27 [IKEv1]IP = 209.82.99.145, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + KE (4) + NONCE (10) + ID (5) + HASH (8) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 444
Dec 31 2012 09:05:27: %ASA-4-713903: Group = gtphones, IP = 209.82.99.145, Information Exchange processing failed
Dec 31 09:05:27 [IKEv1]IP = 209.82.99.145, IKE_DECODE RECEIVED Message (msgid=9433fe3b) with payloads : HDR + NOTIFY (11) + NONE (0) total length : 456
Dec 31 09:05:27 [IKEv1]Group = gtphones, IP = 209.82.99.145, Received an un-encrypted INVALID-PAYLOAD-TYPE notify message, dropping
Dec 31 09:05:27 [IKEv1]Group = gtphones, IP = 209.82.99.145, Information Exchange processing failed
Here is my config
group-policy gtphones internal
group-policy gtphones attributes
dns-server value 10.26.150.75
vpn-tunnel-protocol ikev1
ipsec-udp enable
ipsec-udp-port 10000
split-tunnel-policy tunnelspecified
split-tunnel-network-list value vpnsplit
default-domain value gtcorp.com
tunnel-group gtphones type remote-access
tunnel-group gtphones general-attributes
address-pool gtphones-vpnpool
authentication-server-group ias_auth LOCAL
default-group-policy gtphones
tunnel-group gtphones ipsec-attributes
ikev1 pre-shared-key *****
peer-id-validate nocheck
crypto dynamic-map gtphones 1 set ikev1 transform-set ESP-AES-128-SHA
crypto dynamic-map gtphones 1 set reverse-route
crypto map vpnmap 2 ipsec-isakmp dynamic gtphones
crypto map vpnmap interface outside
Any idea why??
Thanks and happy new year!
01-01-2013 01:40 AM
Hi difan,
can you share access list or check access list for VPN and NAT access list
01-01-2013 02:00 PM
This message usually appears due to mismatched ISAKMP policies or a missing NAT 0 statement.
try this link
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
01-01-2013 05:44 PM
Hi Difan,
I ran in to the same issue, In my case the issue was a ASA firmware bug. It affects SIP inspection on UDP traffic.
If you only use UDP for SIP server connectivity from your phone, your traffic will come in to your SIP server through the ASA but the ASA will drop the return traffic from the SIP server.
The workaround:
1) if it allows, change the SIP settings on the phones to use TCP instead of UDP
2) "Disable SIP inspection" on the ASA ( But you need to be carefull, if you have other SIP retaled services that needs NATing through the ASA, you might brake them, If your SIP server is inside your LAN, it would be fine..
Please rate this if helpful
01-01-2013 10:02 PM
Thanks guys... I have called Cisco TAC. It turned out to be Avaya phone bug. It sends payload type 20 rather than 15... May have to downgrade the ASA now... Thanks for your help though
