Community Helping Community
480
Beginner
remote login layer 3 switches
I have a problem with me, Layer 3 switches, how do you do on remote login with ssh and telnet
6 REPLIES 6
Beginner
Re: remote login layer 3 switches
# conf t
(config)# line vty 0 4
(config)# transport input all
(config)# password 1234
(config)# end
#wr
hth
Muammer
Beginner
how you can remotely log into the layer 3 switches on port 6000?
Highlighted
Beginner
for telnet,
you can use "rotary" command under line vty, rotary listens to ports 3000-3099.
Router# configure terminal
Router(config)# line vty 0 4
Router(config-line)# rotary 23
Router(config-line)# end
Router# wr
and try to connect port 3023
for ssh,
Router(config)# ip ssh port 3001 rotary 99
Router(config)# username user password xxxxx
Router(config-line)# login local
Router(config-line)# rotary 99
Router(config-line)# transport input ssh
Router# wr
hth
Muammer
Beginner
you can do this toe applied to all layer 3 switch
Beginner
you can do this for telnet.
Beginner
I'll just problems the aim is to use ssh
Content for Community-Ad
FusionCharts will render here
