12-15-2012 08:46 AM
Hi all,
To enable start before logon for my any connect vpn in my environment, do i need to download images to add onto my ASA?
Can the SBL components be pushed from ASA to my client PC rather than manually install the components on the client pc?
Thks in advance.
12-16-2012 01:18 AM
SBL component doesn't need to be manually installed on client's pc.
To enable the SBL feature, you just need to make changes to the AnyConnect profile and allow ASA to download the AnyConnect module for SBL.
Here is more information for your reference:
Hope that helps.
12-16-2012 11:32 PM
Hi Jennifer,
THk you for your response. My objective is to allow my windows server to do a vpn connection automatically upon bootup without user intervention. Is this possible using SBL?
12-17-2012 12:04 AM
SBL will connect to the VPN before user login to the Windows PC upon booting up.
It will have an icon that user needs to click to connect to the AnyConnect VPN.
