Restrict and Filter UDP/500 Cisco ASA
Daniel Barbosa
I need filter and block UDP/500 on CISCO ASA 5510.
I created the following rules
X.X.X.X deny to connect P.P.P.P UDP/500
Y.Y.Y.Y permit to connect P.P.P.P UDP/500
or
Permit some IPs and deny ALL UDP/500 (optional)
Rules:
access-list ACL_OUTSIDE_IN extended deny udp host X.X.X.X interface outside log
access-list ACL_OUTSIDE_IN extended deny udp host X.X.X.X host P.P.P.P eq isakmp
access-list ACL_OUTSIDE_IN extended permit udp host Y.Y.Y.Y host P.P.P.P eq isakmp
access-list ACL_OUTSIDE_IN extended deny udp any host P.P.P.P eq isakmp (optional)
access-group ACL_OUTSIDE_IN  in interface outside
access-group ACL_OUTSIDE_IN  in interface outside control-plane
When start packet-tracer is ALLOWED
packet-tracer input outside udp X.X.X.X 500 P.P.P.P 500
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
MAC Access list
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 3
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found flow with id 68636288, using existing flow
Result:
input-interface: outside
input-status: up
input-line-status: up
Action: allow
This firewall works on Dynamic VPN mode because remote peers using dynamic public IP.
How can i solve this? Any idea?
Tks
Daniel
Dinesh Moudgil
Hi Daniel,
I tested this in my lab but could not replicate the issue. Also , please confirm if you are referring P.P.P.P as your ASA interface's IP . To check if the packets are really getting dropped, you can apply "capture asp type asp-drop all" and run "show cap asp | in <IP_of_originating_host>" and these will show if the dropped packets along with the reason.
Dinesh Moudgil
P.S. Please rate helpful posts.
Cisco Network Security Channel - https://www.youtube.com/c/CiscoNetSec/
Hi Dinesh,
Yes, my ip P.P.P.P is the ASA Interface.
And when I do capture, I can´t see dropp. I belive that giving is not match the ACL.
I have a friend who said in a video of Brian McGahan INE CCIE Security, he talks about this filter.
You know something?
I'm researching and looking for that video.
