Route or NAT problem?
ken.montgomery
Hi Everyone,
We have an ASA 5540 at our data center, with ASA 5505's at most remote sites.
At the sites without layer 3 switches behind the ASA 5505's, we can't reach the data center internal network through the ASA for flow-export, etc.
So, what I'm basically saying is, even though the tunnel is up and everything behind the branch ASA can reach the data center networks fine, the ASA itself cannot reach hosts on the data center network.
I'm hoping to configure these ASA 5505's so I can do flow export and SNMP logging from them, but without this routing or nat problem resolved, they just won't do it.
Doing a packet tracer from the ASA 5505 to the data center server I'm most focused on, reveals this:
BRANCH5505f01# packet input inside icmp 10.15.16.1 8 0 10.1.1.15 detailed
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xcb0b6698, priority=1, domain=permit, deny=false
        hits=1004755, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0100.0000.0000
        input_ifc=inside, output_ifc=any
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.1.1.15       255.255.255.255 outside
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (rpf-violated) Reverse-path verify failed
I am thinking the problem is NAT related, but with the new ASA NAT rule format due to v9.1... struggling to get a grip on where it is... any thoughts/help are appreciated.
Ken
Here is the relevant config for the Branch ASA and also the relevant config from the data center ASA:
Branch ASA Config Parts:
: Saved
ASA Version 9.1(2)
hostname BRANCHASA5505
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
speed 100
duplex full
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
description LAN_NETWORK
nameif inside
security-level 100
ip address 10.15.6.1 255.255.254.0
interface Vlan2
nameif outside
security-level 0
ip address <outside ip> 255.255.255.248
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object-group network BRANCH_NETWORKS
description BRANCH LOCAL NETWORKS
network-object 10.15.6.0 255.255.254.0
object-group network LAN_NETWORKS
network-object 10.0.0.0 255.0.0.0
network-object 134.200.131.0 255.255.255.0
network-object 134.200.220.0 255.255.255.0
network-object 134.201.2.0 255.255.255.0
network-object 163.243.195.0 255.255.255.0
network-object 172.16.0.0 255.240.0.0
network-object 192.168.0.0 255.255.0.0
network-object 10.1.3.0 255.255.255.0
network-object 10.31.2.0 255.255.255.0
network-object 10.1.1.0 255.255.255.0
network-object 172.26.1.0 255.255.255.0
object-group network NETWORK_MGMT
access-list DATACENTER_VPN_ACL remark *******************************************************************
access-list DATACENTER_VPN_ACL remark * FOR VPN CONNECTION TO DATACENTER/VEYANCE NETWORKS *
access-list DATACENTER_VPN_ACL extended permit ip host <outside ip> host <outside ip datacenter asa>
access-list DATACENTER_VPN_ACL extended permit ip object-group BRANCH_NETWORKS object-group LAN_NETWORKS
access-list INSIDE_NONAT extended permit ip object-group BRANCH_NETWORKS object-group LAN_NETWORKS
access-list INSIDE_FILTER extended permit tcp any4 any4 eq www
access-list INSIDE_FILTER extended permit tcp any4 any4 eq 8080
logging host inside 10.1.1.15
flow-export destination inside 10.1.1.15 2055
ip verify reverse-path interface inside
ip verify reverse-path interface outside
nat (inside,outside) source static LAN_NETWORKS LAN_NETWORKS destination static BRANCH_NETWORKS BRANCH_NETWORKS route-lookup
nat (inside,outside) source static BRANCH_NETWORKS BRANCH_NETWORKS destination static NETWORK_MGMT NETWORK_MGMT route-lookup
nat (inside,outside) source dynamic any interface
nat (inside,outside) dynamic interface
access-group FROM_OUTSIDE in interface outside
route outside 0.0.0.0 0.0.0.0 <outside ip gateway> 1
route outside 10.1.1.15 255.255.255.255 <outside ip datacenter asa> 1
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
tunnel-group <outside ip datacenter asa> type ipsec-l2l
tunnel-group <outside ip datacenter asa> ipsec-attributes
ikev1 pre-shared-key *****
class-map type regex match-any DomainBlockList
match regex DomainList-Netflix
class-map type inspect http match-all BlockDomainsClass
match request header host regex class DomainBlockList
class-map inspection_default
match default-inspection-traffic
class-map httptraffic
match access-list INSIDE_FILTER
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map type inspect http http_inspection_policy
parameters
  protocol-violation action log
class BlockDomainsClass
  reset log
policy-map URL-filter-policy
class httptraffic
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect http
class class-default
  flow-export event-type all destination 10.1.1.15
service-policy URL-filter-policy interface inside
prompt hostname context
Datacenter ASA Config Parts:
ASA Version 9.0(1)
hostname DATACENTERASA5540
names
interface GigabitEthernet0/0
description *** TO OUTSIDE NETWORK AT DATACENTER ***
speed 100
duplex full
nameif OUTSIDE
security-level 0
interface GigabitEthernet0/1
description *** TO INSIDE NETWORK ***
nameif INSIDE
security-level 100
ip address 10.1.3.2 255.255.255.0
object-group network DATACENTER_NETWORKS
network-object 10.1.0.0 255.255.0.0
access-list BRANCH_VPN_ACL remark ****************************************************
access-list BRANCH_VPN_ACL remark *  FOR SITE TO SITE VPN TO BRANCH WV USA  *
access-list BRANCH_VPN_ACL extended permit ip host <outside ip> host <outside ip branch asa>
access-list BRANCH_VPN_ACL extended permit ip object-group LAN_NETWORKS object-group BRANCH_NETWORKS
flow-export destination INSIDE 10.1.1.15 2055
flow-export template timeout-rate 1
flow-export delay flow-create 180
ip verify reverse-path interface OUTSIDE
ip verify reverse-path interface INSIDE
no failover
nat (INSIDE,OUTSIDE) source static LAN_NETWORKS LAN_NETWORKS destination static BRANCH_NETWORKS BRANCH_NETWORKS route-lookup
access-group FROM_OUTSIDE in interface OUTSIDE
route OUTSIDE 0.0.0.0 0.0.0.0 <outside ip> 1
route INSIDE 10.0.0.0 255.0.0.0 10.1.3.1 1
route OUTSIDE 10.15.6.0 255.255.254.0 <outside ip branch asa> 1
crypto map OUTSIDE-MAP 156 match address BRANCH_VPN_ACL
crypto map OUTSIDE-MAP 156 set pfs
crypto map OUTSIDE-MAP 156 set peer <outside ip branch asa>
crypto map OUTSIDE-MAP 156 set ikev1 transform-set ESP-3DES-MD5 ESP-3DES-SHA
tunnel-group <outside ip branch asa> type ipsec-l2l
tunnel-group <outside ip branch asa> ipsec-attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
class class-default
  user-statistics accounting
service-policy global_policy global
smtp-server 172.19.1.137
call-home reporting anonymous
Again, any help you can provide is appreciated... will vote for best...
5 Replies 5
Jouni Forss
First off it seems to me that you are using the wrong IP address in the "packet-tracer" command as the source.
Atleast I presume you meant to use the interface IP address of 10.15.6.1 but you are using 10.15.16.1.
Then again if you were to use the actual interface IP address of the "inside" interface of the ASA5505 then that "packet-tracer" should also fail since you are using the interface IP address as the source.
This whole situation reminds me of a similiar setup I tested for someone. Though in that case we built a L2L VPN connection between Remote Site and Central Site and used it to send the remote ASA Syslogs through the VPN and also use SNMP for the remote ASA through the L2L VPN. That worked great.
If this traffic generated from the remote ASA itself is anything like Syslog and SNMP then it would seem to me that the problem is in the Crypto ACL you are using.
I notice that you have used an ACL line that specifies the external IP addresses of the ASA firewalls (Central and Remote Site). In your case since the flow export destination is 10.1.1.15 shouldnt you be specifying the remote site ASAs Crypto ACL as the following?
Remote Site
access-list DATACENTER_VPN_ACL extended permit ip host host 10.1.1.15
Central Site
access-list BRANCH_VPN_ACL extended permit ip host 10.1.1.15 host
In addtion to that I think the remote ASA would not need any NAT configurations related to this as its traffic generated from the device itself. On the other hand I think the Central Site would required a NAT0 configuration addition as at that side the the host involved in the flow export is not the ASA but a device behind that.
So I think you would need
object network FLOW-EXPORT
host 10.1.1.15
object network REMOTE-SITE-ASA-PUBLIC
host
nat (INSIDE,OUTSIDE) 1 source static FLOW-EXPORT FLOW-EXPORT destination static REMOTE-SITE-ASA-PUBLIC REMOTE-SITE-ASA-PUBLIC
The above NAT configuration would naturally mean that ALL this internal hosts traffic towards the remote ASA public IP address would use the L2L VPN connection rather than the public Internet (wihout VPN)
Hope this helps
Let me know what the situation is
- Jouni
Hmm... that is interesting considering we are using similar setups to what I originally posted, with a layer 3 switch behind them and working fine. let me take a look at it... I'm not sure that what you're proposing will resolve it or not...
harshisi_2
Hi Ken,
can you please run the packet tracer command  as follows :
packet input inside icmp 10.15.16.2 8 0 10.1.1.15 detailed
and share results.
~Harry
I ran it, with the source IP corrected (it is 10.15.6.2):
BRANCHASA# packet input inside icmp 10.15.6.2 8 0 10.1.1.15 detailed
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
        hits=1203279, user_data=0x0, cs_id=0x0, l3_type=0x8
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
NAT divert to egress interface outside
Untranslate 10.1.1.15/0 to 10.1.1.15/0
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.15.6.0       255.255.254.0   inside
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
Static translate 10.15.6.2/0 to 10.15.6.2/0
in  id=0xcb12f2f0, priority=6, domain=nat, deny=false
        hits=15824, user_data=0xcb0fdef8, cs_id=0x0, flags=0x0, protocol=0
        src ip/id=10.15.6.0, mask=255.255.254.0, port=0, tag=0
        dst ip/id=10.0.0.0, mask=255.0.0.0, port=0, tag=0, dscp=0x0
        input_ifc=inside, output_ifc=outside
Phase: 6
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
in  id=0xcaa712e0, priority=0, domain=nat-per-session, deny=true
        hits=77610, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0, dscp=0x0
        input_ifc=any, output_ifc=any
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xcb0bc128, priority=0, domain=inspect-ip-options, deny=true
        hits=91404, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in  id=0xcb0bbc28, priority=66, domain=inspect-icmp-error, deny=false
        hits=4585, user_data=0xcb0bb238, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
        src ip/id=0.0.0.0, mask=0.0.0.0, icmp-type=0, tag=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, icmp-code=0, tag=0, dscp=0x0
Phase: 9
Type: VPN
Subtype: encrypt
Result: ALLOW
Config:
out id=0xcb0c1218, priority=70, domain=encrypt, deny=false
        hits=708, user_data=0xbf63c, cs_id=0xcb9ad918, reverse, flags=0x0, protocol=0
        input_ifc=any, output_ifc=outside
Phase: 10
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
out id=0xcb12fb00, priority=6, domain=nat-reverse, deny=false
        hits=15837, user_data=0xcb124438, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 143081, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_translate
snp_fp_adjacency
snp_fp_encrypt
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
Result:
input-status: up
output-status: up
Action: allow
ken.montgomery
Turns out the problem is neither.
The actions below, discovered by one of my staff members, repairs it:
The fix is to apply the default inspection globally
On old codes, default inspection is enabled by default thus it does not show up on show run. So on the new versions although we have the default policy maps, this will not take effect unless we “explicitly” apply the service policy:
  inspect ftp
class class-default
So, thank you all for attempting, but that seems to fix it
