RSA token will not allow RDC connections from Vista
patel.nishit
The secure tunnel which is set up for applications on the Cisco ADSM when using the RSA token will not allow RDC connections from Windows Vista computers. This works on Windows XP machines.
Does anyone know how to fix the issue.
wong34539
Level 6
Level 6
Cisco IPSec Client does not support 64-bit. If the user requires 64-bit support, the upgrade path is to use the Cisco AnyConnect VPN Client instead, which does support 64-bit. However, the AnyConnect Client supports only SSL VPN connections (CSCsi26069).
For Windows Vista, there is no firewall support in the VPN Client. To resolve the Bluescreen issue on Windows XP related to the VPN client built-in firewall, upgrade to VPN Client version 5.0.5.x or higher.
