07-15-2011 06:29 AM
Dears
I have question how to setup a VPN failover with a failover ISP
my senario
ASA(1) ------------------------------- internet --------ISP1-------------- ASA(2)
-------ISP2---------------- ASA(2)
My ASA (1) have S2S tunnle configured to ASA(2) ISP1 interfate. ASA(2) have ISP failover. When ISP1 down I lost the tunnel connection!
Should I creat another S2S tunnel to ASA(2) ISP2 interface or the is another way to do it?
Thanks in advance!
Mike
07-16-2011 05:53 AM
No, you can't create another S2S tunnel.
On ASA (1), just configure 2 IP Address on the "set peer" command, first with the first ISP and second IP with the second ISP.
You would also need to configure the pre-shared-key for ISP2 IP Address as well.
07-19-2011 12:14 PM
I will give a try and update you if it works
