521
Beginner
site to site between two ASA firewall
I have two ASA and I would configure both ASA til S2S. ASA1 is in HQ and ASA2 is in Brunch office. HQ ASA has multi S2S connection and Brunch ASA has only S2S to HQ. The Senario is that I would send the all the traffic (both to the Internet and to the local network in the HQ ASA) from ASA2 throug the tunnel. The issue is that when the tunnel is up and there is connevtivity from ASA2 (brunch office) to the local network behinde ASA1 (HQ), but client behinde ASA2 has no conectivity when they atempt to go to the the Internet. Tanks a lot in advance for any help!
HQ ASA extern ip 192.x.y.z/24, local network 10.70.0.0/16
Brunch office ASA has extern ip 168.x.y.z/24, local network 10.79.1.0/24
1 ACCEPTED SOLUTION
Beginner
Re: site to site between two ASA firewall
This should help you out:
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-list inside_nat0_outbound extended permit ip 10.79.1.0 255.255.255.0 x.x.x.x 255.255.255.0
access-list outside_1_cryptomap extended permit ip 10.79.1.0 255.255.255.0 x.x.x.x 255.255.255.0
x.x.x.x = the subnet of HQ,  in the HQ ASA you need the reverse ACL:
access-list inside_nat0_outbound extended permit ip x.x.x.x 255.255.255.0 10.79.1.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip x.x.x.x 255.255.255.0 10.79.1.0 255.255.255.0
This way traffic going to the internet will be nated as it goes out and traffic for thet VPN will
not be nated as it goes down the tunnel
11 REPLIES 11
you need to configure so called "hairpinning". Check the below document:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00805734ae.shtml
The important steps are:
same-security-traffic permit intra-interface
+ proper NAT
pre-8.3
nat (outside) 10 ...
global (outside) 10 ...
post-8.3
nat (outside,outside) ...
Pawel
Beginner
Tanks for your reply. I have to say that i am a new in this ASA. In my senario is no ipsec client involved. Your diagram is littel different copmpared to my senario. In my senario two ASA os 9.0 with there own local network are involved!
Highlighted
Yes I'm aware the the document is about VPN Client, however the idea is the same.
You need to do a u-turn on th ASA. For that you need sames-security... And after that you need to translate the source of the packets so they will be routable on the Internet.
Configuration guide which explains all you need:
http://www.cisco.com/en/US/docs/security/asa/asa90/configuration/guide/vpn_params.html#wp1042114
Pawel
Beginner
Hi again:)
the enabling traffic in sames-security has to be done in ASA2 (in Brunch office) right? and you mean I can still send the internet traffic throug the tunnel to ASA1 (HQ) if I do nat the same source ip from the lokal network in brunch office ASA2?
Beginner
I forgot to send my configuration from ASA2 (in brunch office). Maybe it wil help!
Result of the command: "sh run"
: Saved
ASA Version 8.2(5)
hostname ciscoasa
domain-name default.domain.invalid
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan1
nameif inside
security-level 100
ip address 10.79.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
boot system disk0:/asdm-711-52
boot system disk0:/asdm-701.bin
boot system disk0:/asa825-k8.bin
ftp mode passive
dns server-group DefaultDNS
access-list outside_1_cryptomap extended permit ip 10.79.1.0 255.255.255.0 any
access-list inside_access_in extended permit ip any any
access-list inside_nat0_outbound extended permit ip 10.79.1.0 255.255.255.0 any
pager lines 24
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-701.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_nat0_outbound
access-group inside_access_in in interface inside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.79.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group5
crypto map outside_map 1 set peer 130.225.0.84
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client client-id interface outside
dhcpd address 10.79.1.50-10.79.1.80 inside
dhcpd dns 10.70.1.245 10.70.1.245 interface inside
dhcpd wins 10.70.1.245 10.70.1.246 interface inside
dhcpd lease 10000 interface inside
dhcpd domain oddermuseum.au.dk interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
tunnel-group 130.x.y.z type ipsec-l2l
tunnel-group 130.x.y.z ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:7f2b8f8b6111f1ce4ea7dbd6cf1869ce
: end
same-security-traffic permit intra-interface has to be enabled on the HQ (ASA1) as this is where you need to do a u-turn with the Internet traffic.
NAT should also be performed on the HQ, so that the Internet will know where to send the traffic back - HQ.
The crypto ACL should look something like that (assuming that 10.79.1.0/24 is the branch subnet):
HQ - access-list NAME permit ip any 10.79.1.0 255.255.255.0
BRANCH - access-list NAME permit ip 10.79.1.0 255.255.255.0 any
+ PAT (first example: http://www.cisco.com/en/US/docs/security/asa/asa90/configuration/guide/vpn_params.html#wp1047799)
Pawel
Beginner
Tanks Pawel!
I will try to see if it works!
Beginner
Can you post HQ config I'm sure that's where the problem is.
Beginner
It is very long configuration. I just desided that traffic to remote local network should go trough the tunnel. and now I want to figure out that how i can send the traffic to the Internet trough the brunch ASA's outside Interface it selfs not trough the HQ ASA.
Beginner
Beginner
That was it!
Tanks a lot:)
