Beginner
site to site IPSEC SA stuck can not clear.
Hi there,
We just have a issue on our VPN hub after a short internet outage. our site to site VPN hub is setup on a pear of cisco 3925 router.  after outage we notice 3 remote site can not connect to our data centre anymore.
we have verified the phase 1 negotiation work ok. and looks like the phase 2 IPsec have got stack. no matter how we try clear the crypto isakmp sa. It still not helping. I also can not find any command to clear the IPSEC SA.
   protected vrf: VRF_VPN
   local  ident (addr/mask/prot/port): (172.16.0.0/255.240.0.0/0/0)
   remote ident (addr/mask/prot/port): (192.168.210.0/255.255.255.0/0/0)
   current_peer <remote IP> port 500
     PERMIT, flags={}
    #pkts encaps: 481619, #pkts encrypt: 481619, #pkts digest: 481619
    #pkts decaps: 780905, #pkts decrypt: 780905, #pkts verify: 780905
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: <Local IP>, remote crypto endpt.: 210.86.1.51
     path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0.12
     current outbound spi: 0x0(0)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
     local crypto endpt.: <local IP>, remote crypto endpt.: <remote IP>
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
when we turn on debugging we see log below
8958079: Sep 28 16:54:46.590 NZDT: IPSEC(key_engine): got a queue event with 1 KMI message(s)
8958080: Sep 28 16:54:47.382 NZDT: IPSEC(validate_proposal_request): proposal part #1
8958081: Sep 28 16:54:47.382 NZDT: IPSEC(validate_proposal_request): proposal part #1,
  (key eng. msg.) INBOUND local= <Local IP>:0, remote= <remote IP>:0,
    local_proxy= 172.16.0.0/255.240.0.0/256/0,
    remote_proxy= 192.168.210.0/255.255.255.0/256/0,
    protocol= ESP, transform= NONE  (Tunnel-UDP),
    lifedur= 0s and 0kb,
    spi= 0x0(0), conn_id= 0, keysize= 128, flags= 0x0
8958082: Sep 28 16:54:47.386 NZDT: IPSEC(key_engine): got a queue event with 1 KMI message(s)
IRERX017#
8958083: Sep 28 16:54:47.386 NZDT: IPSEC(crypto_ipsec_create_ipsec_sas): Map found VPN
IRERX017#
8958084: Sep 28 16:54:54.998 NZDT: IPSEC(validate_proposal_request): proposal part #1
8958085: Sep 28 16:54:54.998 NZDT: IPSEC(validate_proposal_request): proposal part #1,
  (key eng. msg.) INBOUND local= <Local IP>:0, remote= <remote ip>:0,
    local_proxy= 10.0.0.0/255.0.0.0/256/0,
Does anyone see similar issue before. thanks in advance.
Everyone's tags (1)
3 REPLIES 3
the phase 2 is not up as
the phase 2 is not up as there are no SA's formed; the counters will still show up in show crypto ipsec sa output.
to clear the counters, you can run the following command: clear crypto sa counters
please attach the complete output of the phase 2 debugs.
Beginner
Thanks Pjain, I think I
Thanks Pjain,
I think I resort the issue now. I have to remove the crypto map and readd it to the interface. all remote VPN are working after that.
Thanks for the reply.
Contributor
The command isclear crypto
The command is
clear crypto ipsec sa peer a.b.c.d
