Site-to-Site IPSEC VPN configuration not connecting
Naeem_Khan
Hello. I am very new to networking, and I am working on a school project in GNS 3 to simulate a network topology that I have created. Here is my set up so far:
cf0dc940ad879b78b682d6f9088aab25
Configuration for R7:
version 12.4
hostname R7
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip tcp synwait-time 5
crypto isakmp policy 1
 encr aes 256
 authentication pre-share
 group 5
crypto isakmp key naeem_vpn address 1.1.1.1
crypto ipsec transform-set transform_set_vpn esp-aes 256 esp-sha-hmac
crypto map crypto_map 10 ipsec-isakmp
 set peer 1.1.1.1
 set transform-set transform_set_vpn
 set pfs group5
 match address vpn_traffic
interface FastEthernet0/0
 ip address 192.168.6.1 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.7.254 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet1/0
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
 no ip address
router eigrp 1
 network 192.168.6.0
 network 192.168.7.0
 auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip access-list extended vpn_traffic
 permit ip 192.168.7.0 0.0.0.255 192.168.5.0 0.0.0.255
no cdp log mismatch duplex
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
Configuration for R5:
version 12.4
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
 encr aes 256
 group 5
crypto isakmp key naeem_vpn address 1.1.1.2
 set peer 1.1.1.2
 set pfs group5
 ip address 192.168.4.1 255.255.255.0
 duplex auto
 speed auto
 ip address 192.168.5.254 255.255.255.0
 duplex auto
 speed auto
interface Vlan1
 no ip address
router eigrp 1
 network 192.168.4.0
 network 192.168.5.0
 auto-summary
no ip http server
 permit ip 192.168.5.0 0.0.0.255 192.168.7.0 0.0.0.255
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
Router R1, R2, and R3 are connected through OSPF routing, and the rest of the routers are connected to their respective area through eigrp. Additionally, R2 and R3 both advertise their eigpr and ospf routes to each other. Basically there a link between every node and I can reach every node from any location and all of them have internet access.
I want to establish an encrypted connection between R7 and R5. I have taken the approach to implement Site-to-Site IPSEC tunneling, but when I do show crypto session on either routers, it says the session status is DOWN. I have tried pinging both sides but still still the status is down.
What am I doing wrong here? Any help will be really appreciated!
The peer IP address defined in the crypto map should be the outside interface (Fa0/0) of the other router. Check that each router can ping the other routers' Fa0/0 IP address.
The crypto map needs to be assigned to the Fa0/0 (outside interface) as the tunnel will be formed between these interfaces. Your internal networks are defined in the vpn-traffic ACL, when the source network attempts to communicate with the remote peers private network (that is defined in the vpn-traffic ACL) it should be tunneled over the VPN.
5 Replies 5
It looks like you've assigned the crypto map to the Fa0/1 interface, when it needs to be assigned to the Fa0/0 interface.
You've also defined the peer IP addresses as 1.1.1.1 and 1.1.1.2, but you don't appear to have these IP addresses defined - unless you are NATTING?....but your diagram does not indicate that though. The peer IP address would need to be the Fa0/0 IP address, each router needs should be able to ping the other router's Fa0/0 IP address.
I do have NAT but that is only in router 1. R7 and R5 both use Eigpr to advertise their neighbors.
Is there no way to have encryption only for f0/1 of both R7 and R5?
That is correct. I do not have those addresses. I misunderstood what those IPs are. I thought that would be a new IP created for traffic between these two interfaces.
If I want to tunnel the traffic of 192.168.7.1-254 from R7, and 192.168.5.1-254 between each other, what should I do?
I'm sorry if I'm not making any sense. I'm still very new to all this.
I understand now, and it works. Thank you so much!
