11-28-2013 05:53 AM
Just configured site to site VPN for ASA 5515x and 5505. The tunnel is up, but couldn't ping to the other site from 5505 and vice versa. Below are the tunnel status and ASA configs. Any help or comment is appreciated. Thanks!
ASA5515X# sh crypto ipsec sa
interface: outside
Crypto map tag: outside_map, seq num: 10, local addr: 211.24.X.X
access-list outside_cryptomap_10 extended permit ip 192.168.0.0 255.255.255.0 192.168.2.0 255.255.255.0
local ident (addr/mask/prot/port): (192.168.0.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (192.168.2.0/255.255.255.0/0/0)
current_peer: 175.141.X.X
#pkts encaps: 1595, #pkts encrypt: 1595, #pkts digest: 1595
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 1595, #pkts comp failed: 0, #pkts decomp failed: 0
#pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
#PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
#TFC rcvd: 0, #TFC sent: 0
#Valid ICMP Errors rcvd: 0, #Invalid ICMP Errors rcvd: 0
#send errors: 0, #recv errors: 0
local crypto endpt.: 211.24.X.X/4500, remote crypto endpt.: 175.141.X.X/4500
path mtu 1492, ipsec overhead 66(44), media mtu 1500
PMTU time remaining (sec): 0, DF policy: copy-df
ICMP error validation: disabled, TFC packets: disabled
current outbound spi: FC699E19
current inbound spi : FFFCF744
inbound esp sas:
spi: 0xFFFCF744 (4294768452)
transform: esp-3des esp-sha-hmac no compression
in use settings ={L2L, Tunnel, NAT-T-Encaps, PFS Group 1, IKEv1, }
slot: 0, conn_id: 462848, crypto-map: outside_map
sa timing: remaining key lifetime (kB/sec): (3915000/22042)
IV size: 8 bytes
replay detection support: Y
Anti replay bitmap:
0x00000000 0x00000001
outbound esp sas:
spi: 0xFC699E19 (4234780185)
sa timing: remaining key lifetime (kB/sec): (3914825/22042)
IV size: 8 bytes
Anti replay bitmap:
ASA5515X
ASA Version 9.1(1)
hostname ASA5515X
interface GigabitEthernet0/0
description TIMEFibre
nameif outside
security-level 0
pppoe client vpdn group navision
ip address pppoe setroute
interface GigabitEthernet0/1
description Internal LAN
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 100
ip address 10.0.0.1 255.255.255.0
ftp mode passive
dns domain-lookup inside
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 192.168.0.10
object network SVR001
host 192.168.0.13
description Hyper-V Server
object network SVR002
host 192.168.0.12
description SQL server
object network SVR003
host 192.168.0.10
description Domain COntroller
object network SVR004
host 192.168.0.11
description Terminal server
object network local
subnet 192.168.0.0 255.255.255.0
description MFW
object network remote-A
subnet 192.168.1.0 255.255.255.0
description FWSG
object network remote-B
subnet 192.168.2.0 255.255.255.0
description FWWW
object network remote-C
subnet 192.168.3.0 255.255.255.0
description FWFM
object network remote-D
subnet 192.168.4.0 255.255.255.0
description FWMP
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list outside_cryptomap_10 extended permit ip object local object remote-B
access-list inside_access_in extended permit object-group TCPUDP any any
access-list inside_access_in extended permit icmp any4 any echo
access-list outside_access_in extended permit object-group TCPUDP any any
access-list inside_authentication extended permit tcp any any eq ssh
pager lines 24
logging enable
logging timestamp
logging buffered debugging
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source static local local destination static remote-A remote-A no-proxy-arp route-lookup inactive
nat (inside,outside) source static local local destination static remote-B remote-B no-proxy-arp route-lookup
nat (any,outside) static interface service tcp 3389 50013
nat (any,outside) static interface service tcp 3389 50012
nat (any,outside) static interface service tcp 3389 50010
nat (any,outside) static interface service tcp 3389 50011
nat (inside,outside) after-auto source dynamic any interface
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 211.24.199.129 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication match inside_authentication inside LOCAL
aaa authorization command LOCAL
http server enable
http 10.0.0.0 255.255.255.0 management
http authentication-certificate inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES
protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto ipsec security-association pmtu-aging infinite
crypto map outside_map 10 match address outside_cryptomap_10
crypto map outside_map 10 set pfs group1
crypto map outside_map 10 set peer 175.141.X.X
crypto map outside_map 10 set ikev1 transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto ca trustpool policy
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
authentication crack
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
ssh version 2
console timeout 0
vpdn group navision request dialout pppoe
vpdn group navision localname user@bb
vpdn group navision ppp authentication pap
vpdn username user@bb password ***** store-local
dhcpd address 192.168.0.100-192.168.0.200 inside
dhcpd dns 192.168.0.10 8.8.8.8 interface inside
dhcpd wins 192.168.0.10 interface inside
dhcpd enable inside
dhcpd address 10.0.0.100-10.0.0.110 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
tunnel-group 175.141.X.X type ipsec-l2l
tunnel-group 175.141.X.X ipsec-attributes
ikev1 pre-shared-key *****
class-map icmp-class
match default-inspection-traffic
class-map inspection_default
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map icmp_policy
class icmp-class
inspect icmp
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
service-policy icmp_policy interface inside
prompt hostname context
(Behind a router)
ASA5505# sh crypto ipsec sa
interface: outside
Crypto map tag: outside_map, seq num: 1, local addr: 172.16.10.200
access-list outside_1_cryptomap extended permit ip 192.168.2.0 255.255.255.0 192.168.0.0 255.255.255.0
local ident (addr/mask/prot/port): (192.168.2.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (192.168.0.0/255.255.255.0/0/0)
current_peer: 211.24.X.X
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 1539, #pkts decrypt: 1539, #pkts verify: 1539
#pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
local crypto endpt.: 172.16.10.200/4500, remote crypto endpt.: 211.24.X.X/4500
path mtu 1500, ipsec overhead 66, media mtu 1500
current outbound spi: FFFCF744
current inbound spi : FC699E19
inbound esp sas:
in use settings ={L2L, Tunnel, NAT-T-Encaps, PFS Group 1, }
slot: 0, conn_id: 348160, crypto-map: outside_map
sa timing: remaining key lifetime (kB/sec): (4373831/22284)
IV size: 8 bytes
Anti replay bitmap:
0xFFFFFFFF 0xFFFFFFFF
outbound esp sas:
sa timing: remaining key lifetime (kB/sec): (4374000/22284)
IV size: 8 bytes
Anti replay bitmap:
ASA5505
ASA Version 8.2(5)
hostname ASA5505
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 3
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 172.16.10.200 255.255.255.0
interface Vlan3
no forward interface Vlan2
nameif management
security-level 0
management-only
ftp mode passive
access-list inside_nat0_outbound extended permit ip 192.168.2.0 255.255.255.0 192.168.0.0 255.255.255.0
pager lines 24
logging enable
logging timestamp
mtu inside 1500
mtu outside 1500
mtu management 1500
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 172.16.10.1 1
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
http server enable
http 192.168.2.0 255.255.255.0 inside
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 211.24.X.X
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto isakmp enable outside
crypto isakmp policy 10
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 192.168.2.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.2.100-192.168.2.130 inside
dhcpd dns 192.168.2.1 8.8.8.8 interface inside
dhcpd enable inside
webvpn
tunnel-group 211.24.X.X type ipsec-l2l
tunnel-group 211.24.X.X ipsec-attributes
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
no call-home reporting anonymous
Update:
The traffic to the other end is dropped by implicit rule but there already is an access-list configured no?
interface: outside
#pkts encaps: 30188, #pkts encrypt: 30188, #pkts digest: 30188
#pkts decaps: 25550, #pkts decrypt: 25550, #pkts verify: 25550
#pkts not compressed: 30188, #pkts comp failed: 0, #pkts decomp failed: 0
current outbound spi: 7D03CD30
current inbound spi : B2B16E15
inbound esp sas:
spi: 0xB2B16E15 (2997972501)
slot: 0, conn_id: 516096, crypto-map: outside_map
sa timing: remaining key lifetime (kB/sec): (4371272/24996)
IV size: 8 bytes
Anti replay bitmap:
outbound esp sas:
spi: 0x7D03CD30 (2097401136)
sa timing: remaining key lifetime (kB/sec): (4367450/24996)
IV size: 8 bytes
Anti replay bitmap:
ASA5515X# packet-tracer input inside icmp 192.168.0.1 0 8 192.168.2.1 detailed
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in id=0x7fff2a320c70, priority=1, domain=permit, deny=false
hits=3417800, user_data=0x0, cs_id=0x0, l3_type=0x8
src mac=0000.0000.0000, mask=0000.0000.0000
dst mac=0000.0000.0000, mask=0100.0000.0000
input_ifc=inside, output_ifc=any
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 0.0.0.0 0.0.0.0 outside
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
NAT divert to egress interface outside
Untranslate 192.168.2.1/0 to 192.168.2.1/0
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in id=0x7fff2a2b5580, priority=500, domain=permit, deny=true
hits=6, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
src ip/id=192.168.0.1, mask=255.255.255.255, port=0, tag=0
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0 dscp=0x0
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Solved! Go to Solution.
11-29-2013 03:40 AM
Does it work now?
Please do remember to mark a reply as the correct answer if it answered your question.
It's working now, thank you!
I have marked the post above as correct answer.
11-29-2013 02:41 AM
Just added on both ASAs earlier today;
ASA5515X# sh run management-access
management-access inside
ASA5505# sh run management-access
11-29-2013 02:30 AM
Thanks for the input Jouni. I changed to random source IP, was that what you meant? But still getting the same result. ASA5505 behind the router doesn't have static NAT, instead the ports are being forwarded from the router.
ASA5515X# packet-tracer input inside icmp 192.168.0.10 0 8 192.168.2.1 detailed
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in id=0x7fff2a320c50, priority=1, domain=permit, deny=false
hits=5499, user_data=0x0, cs_id=0x0, l3_type=0x8
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in id=0x7fff2a3f2790, priority=11, domain=permit, deny=true
hits=2, user_data=0x5, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0
Result:
input-status: up
output-status: up
Action: drop
11-29-2013 02:32 AM
The inside interface was unplugged during the initial testing before my update here.
I'm trying to ping the inside interface from both ends, i.e; 192.168.0.1 to 192.168.2.1 and vice versa.
11-29-2013 02:41 AM
Actually a few issues here:
For the 5515:
I'm a little concerned about:
First it would allow any session from the internet to any internal client with any active translation, currently your traffic policy for incoming connections from the Internet is controlled only by the NAT statements.
Another thing: this ACL wouldn't allow the ICMP replies once you have fixed the other end.
...access-group inside_access_in in interface inside
(I asume the "4" is some "residue" from sanitizing your config...)
Thjis access-list/group will only allow outbound echo request, your packet-tracer input generates an echo-reply
(see http://www.iana.org/assignments/icmp-parameters/icmp-parameters.xhtml)
For the 5505:
There is no access-list/group at all permitting inbound VPN traffic. VPN traffic after being decapsulated/decrypted is handled like any other traffic originating from the outside destined for any inside target. Write an access-list/group permitting inbound VPN traffic.
11-29-2013 03:14 AM
Hi kafka,
The ACL for 5515 is only temp, as I attempting to fix this issue. And I have replaced the ICMP with
"extended permit icmp any any echo"
For 5505, I thought this line crypto map outside_map interface outside mapped the VPN to outside interface no?
11-29-2013 05:25 AM
I see, but I recommend to make more detailed ACL-entries when go productive.
Actually yes, this is for the tunnel-transport, not necessarily for the tunnel payload.
But you seem to have the default (and hidden) sysopt connection permit-vpn, I forgot about the change of defaults (it was different in older versions). On the newer versions the tunnel payload is permitted by default, on older versions you had to permit the tunnel payload explicitly.
Rgds, MiKa
11-29-2013 05:59 AM
Got it, thanks for your input. Appreciate it
