site to site vpn with internet connection in same time
goran ljubic
i configured site to site VPN beetwen the asa 5505 (asa 8.4.2) and the asa 5510 (asa 8.4.4). how i can configure that the users from one side and second side use internet in same time? pls help me
thanks
ps: this option is split tunneling? how it configure?
13 Replies 13
nkarthikeyan
Level 7
Level 7
Nope.... You can do evrything with the ACL......
You have the general outbound acl for internet traffic as well as the site to site permits in the same ACL... and you will have the crypto acl for site to site vpn traffic..... whatever you have mentioned in site to site crypto acl... that alone will get in to s2s tunnel... rest other you can pass through the internet......
If you have the client to site.... then you have to do the split tunneling.....
Please rate if the info really helps!
if i understanded all acl's which are in crypto ace enable traffic through tunnel. the other acl's which are not in crypto ace go to internet. my config asa5505 is:
ASA Version 8.4(2)
hostname ciscoasa
enable password csq7sfr0bQJqMGET encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 10.15.100.8 255.255.255.0
ftp mode passive
object service ParagrafLex1
service tcp source eq 6190
description Odlazni
object service paragraf
service tcp destination eq 6190
description dolazni
object network server
host 192.168.0.2
object network NETWORK_OBJ_192.168.0.0_24
subnet 192.168.0.0 255.255.255.0
object network NETWORK_OBJ_192.168.2.0_24
subnet 192.168.2.0 255.255.255.0
object-group service DM_INLINE_SERVICE_1
service-object ip
service-object tcp
service-object icmp echo-reply
service-object tcp destination eq domain
service-object tcp destination eq echo
service-object tcp destination eq ldap
object-group protocol DM_INLINE_PROTOCOL_2
protocol-object udp
protocol-object tcp
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service DM_INLINE_SERVICE_5
service-object ip
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_1 any any
access-list outside_cryptomap extended permit ip 192.168.2.0 255.255.255.0 192.168.0.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp outside 10.13.74.1 000d.bd64.a8e2
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_192.168.2.0_24 NETWORK_OBJ_192.168.2.0_24 destination static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 no-proxy-arp route-lookup
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 10.15.100.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 10.15.100.0 255.255.255.0 outside
http 192.168.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
crypto map outside_map 1 match address outside_cryptomap
crypto map outside_map 1 set peer x.x.x.x
crypto map outside_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map interface outside
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.2.2-192.168.2.128 inside
dhcpd auto_config outside interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy GroupPolicy_x.x.x.x internal
group-policy GroupPolicy_x.x.x.x attributes
vpn-tunnel-protocol ikev1 ikev2
tunnel-group x.x.x.x type ipsec-l2l
tunnel-group x.x.x.x general-attributes
default-group-policy GroupPolicy_x.x.x.x
tunnel-group x.x.x.x ipsec-attributes
ikev1 pre-shared-key *****
ikev2 remote-authentication pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map type inspect ftp paragraf
parameters
policy-map global_policy
class inspection_default
inspect dns
inspect icmp
inspect ip-options
inspect netbios
inspect tftp
inspect h323 h225
inspect h323 ras
inspect ftp
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:b6f6c923f233ac9974a733f82ad17fea
: end
Yes... you are correct!!!... at present you don have any acl for outgoing traffic since evry traffic you pointed to site to site vpn... i.e you have only crypto acl for s2s traffic....
So you need to create inside_to_outside acl which will have all filtered traffic for both internet and vpn traffic & assigh that to inside interface.... since you already have the crypto ACL for vpn... no issues with if that is working.....
VPN Traffic
VPN traffic will check the inside_to_outside acl and then it comes to crypto acl and it goes out.....
Internet traffic
all other traffic you mentioned other than vpn will get away as internet traffic...
access-list inside_to_outside extended permit ip 192.168.2.0 255.255.255.0 192.168.0.0 255.255.255.0 (VPN)
access-list inside_to_outside extended permit internet filtered traffic permits
access-list inside_to_outside extended deny ip any any
access-group inside_to_outside in interface inside
Also you need to have the NAT/PAT & routes to be defined accordingly to access internet....
Please rate if the given information helps!
sorry, i don't understand commands. can you explain them:
how go on syntax of command for me? i need tcp,icmp,ip
why blocking ip for any any?
my lan is bihind asa5505. the outside interface of asa5505 is natted on public address. i defined static route 0.0.0.0 0.0.0.0 10.15.100.1
thanks
Prsently you have the below ACL's in your ASA
Outside to Inside LAN ACL
VPN ACL
access-group outside_access_in in interface outside === Pointed to outside interface (Outside to Inside) LAN.
What am asking you to have the acl for inside interface as well.... there you need to have access rules for internet as well as site to site.....
access-list inside_to_outside extended permit ip 192.168.2.0 255.255.255.0 192.168.0.0 255.255.255.0 (S2sVPN)
access-list inside_to_outside extended permit tcp 192.168.2.0 255.255.255.0 any eq 80 (HTTP-Internet)
access-list inside_to_outside extended permit tcp 192.168.2.0 255.255.255.0 any eq 443 (HTTPS-Internet)
access-list inside_to_outside extended permit udp 192.168.2.0 255.255.255.0 eq 53 (DNS)
like tha above you create the traffic whichever you want to permit..... so as per the above acl only http,https and domain traffic is allowed for internet and rest all get blocked.
assigning it to inside interface
Please do rate if the given information helps!
pls tell me, i have not problem if my outside interface of asa5505 is natted on public ip with this configuration? i setted static route for outside interface on gateway 10.15.100.1
PAT is required for the internet access from the lan which is in private segment as well as site to site.... i assume your site to site is created for the public IP's... i.e your outside interface of the ASA....
If your site to site is working now.... then the internet also should work if you follow the steps i provided earlier...
Thanks!
before my lan computers that is now bihind asa5505 have been in network 10.15.100.0/24 where's now outside interface of asa5505. they used internet so what are they received ip, dns, gateway automatic from gateway (router) on ip address 10.15.100.1. i don't know whether i should set nat on my asa5505.
i tested site to site vpn but site to site doesn't work. i can't ping lan bihind asa5510 but not bihind asa5505. when i put command
sh crypto isakmp sa
There are no IKEv1 SAs
IKEv2 SAs:
Session-id:2, Status:UP-ACTIVE, IKE count:1, CHILD count:1
Tunnel-id                 Local                Remote     Status         Role
159733105      10.15.100.8/4500  178.254.133.178/4500      READY    INITIATOR
      Encr: AES-CBC, keysize: 256, Hash: SHA96, DH Grp:5, Auth sign: PSK, Auth verify: PSK
      Life/Active Time: 86400/113 sec
Child sa: local selector  192.168.5.0/0 - 192.168.5.255/65535
          remote selector 192.168.0.0/0 - 192.168.0.255/65535
          ESP spi in/out: 0x8825e2c3/0x86e50a36
when i put
asa-siv(config)# show crypto ip sa
interface: outside
    Crypto map tag: outside_map, seq num: 1, local addr: 10.15.100.8
      access-list outside_cryptomap extended permit ip 192.168.5.0 255.255.255.0 192.168.0.0 255.255.255.0
      local ident (addr/mask/prot/port): (192.168.5.0/255.255.255.0/0/0)
      remote ident (addr/mask/prot/port): (192.168.0.0/255.255.255.0/0/0)
      current_peer: 178.254.133.178
      #pkts encaps: 78, #pkts encrypt: 78, #pkts digest: 78
      #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 78, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 10.15.100.8/4500, remote crypto endpt.: 178.254.133.178/4500
      path mtu 1500, ipsec overhead 82, media mtu 1500
      current outbound spi: 86E50A36
      current inbound spi : 8825E2C3
    inbound esp sas:
      spi: 0x8825E2C3 (2284184259)
         transform: esp-aes-256 esp-sha-hmac no compression
         in use settings ={L2L, Tunnel,  NAT-T-Encaps, }
         slot: 0, conn_id: 8192, crypto-map: outside_map
         sa timing: remaining key lifetime (kB/sec): (4331520/28524)
         IV size: 16 bytes
         replay detection support: Y
         Anti replay bitmap:
          0x00000000 0x00000001
    outbound esp sas:
      spi: 0x86E50A36 (2263157302)
         sa timing: remaining key lifetime (kB/sec): (4101111/28524)
         IV size: 16 bytes
         Anti replay bitmap:
asa-siv(config)#
when i put
debug cry isa
debug cry isa
debug cry ipsec
i don't receive nothing
what ido?
Hi Goran,
Can u pls share the configs at both the ends... i do see encap happening and decaps not happening... some parameter missing.... need to check.... Thanks
Also check with your routing.... this also should work fine.... @ both the ends....
configuration from asa5505 is
ASA Version 8.4(2)
hostname asa-siv
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.5.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
object network obj_any
subnet 192.168.5.0 255.255.255.0
object network NETWORK_OBJ_192.168.5.0_24
service-object ip
service-object tcp
object-group service DM_INLINE_SERVICE_2
service-object ip
service-object tcp
service-object udp
access-list inside_access_in extended permit object-group DM_INLINE_SERVICE_1 any any
access-list inside_to_outside extended permit ip 192.168.5.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list inside_to_outside extended permit object-group DM_INLINE_SERVICE_2 192.168.5.0 255.255.255.0 any
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_192.168.5.0_24 NETWORK_OBJ_192.168.5.0_24 destination static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 no-proxy-arp route-lookup
route inside 192.168.0.0 255.255.255.0 192.168.5.1 2
route outside 192.168.0.0 255.255.255.0 10.15.100.1 3
http server enable
http 192.168.5.0 255.255.255.0 inside
crypto map outside_map 1 set peer x.x.133.178
encryption aes-256
integrity sha
group 5 2
prf sha
encryption aes-192
integrity sha
group 5 2
prf sha
encryption aes
integrity sha
group 5 2
prf sha
encryption 3des
integrity sha
group 5 2
prf sha
encryption des
integrity sha
group 5 2
prf sha
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside vpnclient-wins-override
dhcpd address 192.168.5.2-192.168.5.128 inside
dhcpd enable inside
webvpn
group-policy GroupPolicy_x.x.133.178 internal
group-policy GroupPolicy_x.x.133.178 attributes
tunnel-group x.x.133.178
type ipsec-l2l
tunnel-group x.x.133.178 general-attributes
default-group-policy GroupPolicy_x.x.133.178
tunnel-group x.x.133.178 ipsec-attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:ddf78fdde83332e5c63f9fecded1fc48
: end
configuration from asa 5510
: Saved
ASA Version 8.4(2)
hostname asa5510
domain-name dri.local
enable password 8Ry2YjIyt7RRXU24 encrypted
names
nameif outside
security-level 0
ip address xx.xx.133.178 255.255.255.248
nameif inside
security-level 100
ip address 192.168.0.10 255.255.255.0
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
dns server-group DefaultDNS
object network VPN-POOL
subnet 192.168.50.0 255.255.255.0
description VPN Client pool
object network LAN-NETWORK
description LAN Network
object network NETWORK_OBJ_10.15.100.0_24
subnet 10.15.100.0 255.255.255.0
object network 192.168.0.10
host 192.168.0.10
object-group network PAT-SOURCE-NETWORKS
description Source networks for PAT
network-object 192.168.0.0 255.255.255.0
access-list INSIDE-IN remark Allow traffic from LAN
access-list INSIDE-IN extended permit ip 192.168.0.0 255.255.255.0 any
access-list Split_Tunnel_List extended permit ip 192.168.0.0 255.255.255.0 any
access-list outside_cryptomap extended permit ip 192.168.0.0 255.255.255.0 192.168.5.0 255.255.255.0
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool vpnadrese 192.168.50.1-192.168.50.100 mask 255.255.255.0
arp timeout 14400
nat (inside,outside) source static LAN-NETWORK LAN-NETWORK destination static VPN-POOL VPN-POOL
nat (inside,outside) source static NETWORK_OBJ_192.168.0.0_24 NETWORK_OBJ_192.168.0.0_24 destination static NETWORK_OBJ_10.15.100.0_24 NETWORK_OBJ_10.15.100.0_24 no-proxy-arp route-lookup
nat (inside,outside) after-auto source dynamic PAT-SOURCE-NETWORKS interface
access-group INSIDE-IN in interface inside
route outside 0.0.0.0 0.0.0.0 178.254.133.177 1
route inside 192.168.5.0 255.255.255.0 192.168.0.10 1
action terminate
dynamic-access-policy-record dripolisa
aaa-server DRI protocol ldap
aaa-server DRI (inside) host 192.168.0.20
ldap-base-dn DC=dri,DC=local
ldap-scope subtree
ldap-naming-attribute sAMAccountName
ldap-login-password *****
ldap-login-dn CN=dragan urukalo,OU=novisad,OU=sektor2,OU=REVIZIJA,DC=dri,DC=local
server-type microsoft
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication serial console LOCAL
aaa authorization command LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 set peer 195.222.96.223
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
encryption aes-256
integrity sha
group 5 2
prf sha
encryption aes-192
integrity sha
group 5 2
prf sha
encryption aes
integrity sha
group 5 2
prf sha
encryption 3des
integrity sha
group 5 2
prf sha
encryption des
integrity sha
group 5 2
prf sha
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.0.14-192.168.0.45 inside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection statistics port
threat-detection statistics protocol
webvpn
group-policy GroupPolicy_x.x.96.223 internal
group-policy GroupPolicy_x.x.96.223 attributes
vpn-tunnel-protocol ikev1 ikev2 l2tp-ipsec
group-policy drivpn internal
group-policy drivpn attributes
dns-server value 192.168.0.20 192.168.0.254
vpn-simultaneous-logins 10
vpn-idle-timeout 30
vpn-tunnel-protocol ikev1 l2tp-ipsec
split-tunnel-network-list value Split_Tunnel_List
default-domain value dri.local
username driadmin password AojCAMO/soZo8W.W encrypted privilege 15
tunnel-group drivpn type remote-access
tunnel-group drivpn general-attributes
address-pool vpnadrese
authentication-server-group DRI
default-group-policy drivpn
tunnel-group drivpn ipsec-attributes
tunnel-group x.x.96.223 type ipsec-l2l
tunnel-group x.x.96.223 general-attributes
default-group-policy GroupPolicy_x.x.96.223
tunnel-group x.x.96.223 ipsec-attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect http
Cryptochecksum:3cbb469aab1b4563a0025bf7753a585e
: end
Yes, site 1 is behind router. i tryed with command
crypto map outside_map 1 set ikev1 phase1-mode aggressive
on site 1 asa5505, but nothing
