Small Office Recommendation
santiago.jem
Hi Experts,
May I ask for your recmmendation, on what type of equipment should I use in a Small Office probably around 50-100 users.
Feature sets that I would want are: VPN - 5 VPN Peers for L2L connectivity and 50 SSL VPN connections, Firewall, Active-Standby Fail-over. I'm on a limited budget, ASA 5510 with Security Plus License can give me this but its a bit expensive.
Is there something else that you guys can recommend. ISR maybe?
Hoping to hear from you soon.
Thank you!
Michael Muenz
Level 5
Level 5
There's no ISR which is capable of 50 simultaneos SSL VPN's and also cheaper than ASA5510. ISR also lacks of good Active-Standby failover.
Michael Please rate all helpful posts
Hi you can purchase with Lower SSL VPN LIC and in future you can upgrade that lic.
Jawad
