Highlighted
Beginner
split tunnel setup on asa 8.4 with asdm 6.4
we have anyconnect set up and working, except for split tunneling.
in the ASDM 6.4 I went to : remote access VPN > network (Client) access > group policies >  GroupPolicy_anyconnect_vpn > edit > advanced > split tunneling > then unchecked "inherit" on network list and have selected an ACL called "SPLIT-TUNNEL"
the ACL is pasted below from the CLI, these are all of our internal networks, everything is static routed and on the same vlan
SG-ASA-1# sho access-list SPLIT-TUNNEL
access-list SPLIT-TUNNEL; 10 elements; name hash: 0x25b1daf1
access-list SPLIT-TUNNEL line 1 extended permit ip 192.168.100.0 255.255.255.0 192.168.22.96 255.255.255.224 (hitcnt=0) 0xe3a9484b
access-list SPLIT-TUNNEL line 2 extended permit ip 192.168.105.0 255.255.255.0 192.168.22.96 255.255.255.224 (hitcnt=0) 0x377afd96
access-list SPLIT-TUNNEL line 3 extended permit ip 192.168.110.0 255.255.255.0 192.168.22.96 255.255.255.224 (hitcnt=0) 0x0b4d6f9c
access-list SPLIT-TUNNEL line 4 extended permit ip 192.168.120.0 255.255.255.0 192.168.22.96 255.255.255.224 (hitcnt=0) 0x7a6cc93f
access-list SPLIT-TUNNEL line 5 extended permit ip 192.168.130.0 255.255.255.0 192.168.22.96 255.255.255.224 (hitcnt=0) 0xe228bdad
access-list SPLIT-TUNNEL line 6 extended permit ip 192.168.140.0 255.255.255.0 192.168.22.96 255.255.255.224 (hitcnt=0) 0x317f80c8
access-list SPLIT-TUNNEL line 7 extended permit ip 192.168.150.0 255.255.255.0 192.168.22.96 255.255.255.224 (hitcnt=0) 0xe4c276b0
access-list SPLIT-TUNNEL line 8 extended permit ip 192.168.160.0 255.255.255.0 192.168.22.96 255.255.255.224 (hitcnt=0) 0x0c2dd3ab
access-list SPLIT-TUNNEL line 9 extended permit ip 192.168.170.0 255.255.255.0 192.168.22.96 255.255.255.224 (hitcnt=0) 0x00a4d4e3
access-list SPLIT-TUNNEL line 10 extended permit ip 192.168.180.0 255.255.255.0 192.168.22.96 255.255.255.224 (hitcnt=0) 0xfb381008
SG-ASA-1#
after that setting in the ASDM group policy, we tested unsuccessfully yesterday morning. They can connect and ping any of those inside networks but no internet. The asa log showed the following when a vpn client tried to ping yahoo.com
6      Aug 14 2012      07:51:04            64.60.xxx.xxx      4397      206.169.203.226      1433      Routing failed to locate next hop for TCP from inside:64.60.xxx.xxx/4397 to outside:206.169.203.226/1433
we can ping the inside network no problem after connecting to VPN from the outside.
64.60.xxx.xxx is our public IP that is on the outside interface which is the IP we use for vpn.ourdomain.com
thanks in advance for any help
1 ACCEPTED SOLUTION
Participant
could you try to use the standard acces list from the same menu.
Clck spit tunnel policy list > click manage, select standard acl tab and only add 192.168.0.0 255.255.0.0 (for testing pruposes)
Then test if it works to connect to Internet
The filtering that you want above in your post you can do with a security acl.
If this works, you can add more specific entries in the standard acl split tunneling list, like
add 192.168.100.0
etcetc
4 REPLIES 4
Participant
add 192.168.100.0
etcetc
Beginner
hi Ton thank you for the reply. I have that set up like you asked, but I have to wait until after hours to test since I dont have a test environment. I will test this weekend and get back to you.
thanks again
Beginner
thanks Ton that did the trick!
Participant
Cool!
You re welcome!
