01-21-2019 09:48 AM
I recently configured an SSL VPN on my ASA v9.8 and it seems to work just fine when accessing its fqdn from outside.
I would like to have users also access the same fqdn from inside the network, but connection attempts to the same fqdn just time out.
On the Connection Profiles node in the ASDM, I am allowing access from both the inside and outside interfaces.
In watching the ASA logs while a connection is attempted from the inside, I do not see applicable logs being generated.
Running a Wireshark capture on the local host during connection attempts, I see SYN timeouts to the outside address of the ASA.
What am I missing? Should this even be possible?
Thanks in advance for your suggestions.
Solved! Go to Solution.
01-21-2019 10:14 AM
01-21-2019 10:14 AM
01-21-2019 10:22 AM
Thank you Mohammed... that's perfect!
01-21-2019 10:54 AM - edited 01-21-2019 10:55 AM
No one wants to wait two to four weeks to unlock the bootloader. At least, they should make a "fast path" for long-term https://xender.pro/ https://discord.software/ https://omegle.onl/
01-21-2019 08:13 PM
