299
Participant
SSL VPN Access from inside and outside
I recently configured an SSL VPN on my ASA v9.8 and it seems to work just fine when accessing its fqdn from outside.
I would like to have users also access the same fqdn from inside the network, but connection attempts to the same fqdn just time out.
On the Connection Profiles node in the ASDM, I am allowing access from both the inside and outside interfaces.
In watching the ASA logs while a connection is attempted from the inside, I do not see applicable logs being generated.
Running a Wireshark capture on the local host during connection attempts, I see SYN timeouts to the outside address of the ASA.
What am I missing?  Should this even be possible?
Thanks in advance for your suggestions.
1 ACCEPTED SOLUTION
Highlighted
VIP Advisor
Re: SSL VPN Access from inside and outside
For inside users the fqdn should resolve to inside interface IP rather than
outside. Although I don't understand the requirement for your scenario,
you can fix it by creating an A record for same fqdn in your internal dns
server to resolve to inside interface IP of the ASA
4 REPLIES 4
Highlighted
VIP Advisor
Participant
Thank you Mohammed... that's perfect!
Beginner
No one wants to wait two to four weeks to unlock the bootloader. At least, they should make a "fast path" for long-term https://xender.pro/ https://discord.software/ https://omegle.onl/
Beginner
Hi John i have a question i configure here tunnel routers see each others but only in one side. Haw i configure routers and they see each other in all side photo_2019-01-10_16-38-37.jpg
