Stateful Failover for IPsec on Cisco 3925
appserv
We are try to use two cisco 3925 setup a IPSec VPN Hub. Could you any one let me know whether 3925 will support Stateful Failover for IPsec. If it does. which document are best to referring to.
both router are running c3900-universalk9-mz.SPA.153-1.T.bin with advance security licenses.
Thanks in advance.
Cheers,
Lei
Marcin Latosiewicz
Hi Lei,
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_conn_vpnav/configuration/15-mt/sec-vpn-availability-15-mt-book/sec-state-fail-ipsec.html#GUID-12B9F69D-EE16-4CB6-81DD-427E9A2AC014
  •  Stateful failover for IPsec is supported on the Cisco Integrated Services Routers Generation 2 (ISR G2), with or without the Internal Service Module (ISM).
The config examples in this doc are valid ones. I'd check before deploying for known bugs to avoid problems down the line.
M.
