2017
Highlighted
Static to Dynamic ASA VPN Problems
I am getting errors and unable to send traffic across my VPN tunnel. I am using a ASA 5505 and 5510. The 5505 is setup static with the 5510 dynamic. I am getting the following errors on the 5510 and getting similar errors on the 5505:
Nov 21 [IKEv1]Group = DefaultL2LGroup, IP = xxx.xxx.xxx.xxx, Removing peer from correlator table failed, no match!
Nov 21 [IKEv1]Group = DefaultL2LGroup, IP = xxx.xxx.xxx.xxx, QM FSM error (P2 struct &0xae2d6d70, mess id 0x9df74ed4)
These are with just debugging at level 1 with ipsec and ikev1. Both ASA's are running code 8.4(2) and ASDM 6.4(5) 106. The SA is established:
5510# show crypto ikev1 sa
IKEv1 SAs:
   Active SA: 1
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1   IKE Peer: xxx.xxx.xxx.xxx
    Type    : L2L             Role    : responder
    Rekey   : no              State   : MM_ACTIVE
I am showing active tunnels in ipsec, ikev1, and isakmp stats. It may have something to do with NAT. You do not want VPN traffic to be NAT'd correct? Any ideas, help, and suggestions would be appreciated. Thank you. Attached is a example drawing.
5 REPLIES 5
Advocate
I usually have to enable/disable pfs on one end or the other when I see the qm fsm error...but would need to see the configs.
This is my first site to site setup. Here is the configuration for the 5510:
ASA Version 8.4(2)
hostname 5510
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 10.1.1.1 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.2.2.1 255.255.255.252
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network Remote-Network
subnet 10.10.10.0 255.255.255.252
object network Local-Network
subnet 10.2.2.0 255.255.255.252
access-list global_access extended permit ip any any log debugging
access-list outside_cryptomap extended permit ip any any log debugging
pager lines 24
logging enable
logging console debugging
logging monitor debugging
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any inside
icmp permit any management
no asdm history enable
arp timeout 14400
nat (inside,outside) source static Local-Network Local-Network destination static Remote-Network Remote-Network no-proxy-arp
access-group global_access global
route outside 0.0.0.0 0.0.0.0 10.1.1.2 1
route inside 0.0.0.0 0.0.0.0 10.2.2.1 tunneled
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
http server enable
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
sysopt noproxyarp outside
sysopt noproxyarp inside
sysopt noproxyarp management
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
crypto dynamic-map 10.1.1.1 1 match address outside_cryptomap
crypto dynamic-map 10.1.1.1 1 set pfs
crypto dynamic-map 10.1.1.1 1 set ikev1 transform-set ESP-AES-256-SHA
crypto map outside_map1 1 ipsec-isakmp dynamic 10.1.1.1
crypto map outside_map1 interface outside
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 60
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol ikev1 l2tp-ipsec
tunnel-group DefaultL2LGroup ipsec-attributes
ikev1 pre-shared-key *****
peer-id-validate nocheck
ikev2 remote-authentication pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
tunnel-group 10.1.1.1 type ipsec-l2l
tunnel-group 10.1.1.1 ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Configuration for the 5505:
ASA Version 8.4(2)
hostname 5505
names
description WAN-DHCP-Connection
switchport access vlan 2
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 10.10.10.1 255.255.255.252
interface Vlan2
nameif outside
security-level 0
ip address 192.168.1.2 255.255.255.0
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network Remote_Network
pager lines 24
logging enable
logging console emergencies
logging monitor informational
mtu inside 1500
mtu outside 1500
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
route inside 0.0.0.0 0.0.0.0 10.10.10.1 tunneled
http server enable
crypto map outside_map0 1 match address outside_cryptomap
crypto map outside_map0 1 set pfs
crypto map outside_map0 1 set connection-type originate-only
crypto map outside_map0 1 set peer 10.1.1.1
crypto map outside_map0 1 set ikev1 transform-set ESP-AES-256-SHA
crypto map outside_map0 interface outside
encryption aes-256
integrity sha
group 5 2
prf sha
encryption aes-192
integrity sha
group 5 2
prf sha
encryption aes
integrity sha
group 5 2
prf sha
encryption 3des
integrity sha
group 5 2
prf sha
encryption des
integrity sha
group 5 2
prf sha
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
I toggled the PFS on each side and still getting the same error. Ideas anybody? Thanks.
Beginner
I currently have the same problem (but I am testing the configuration using ASA 5510 on GNS3 - not in operation devices), it does not have anything to do with PFS. However, in another post, someone suggested to change the IOS below 8.4 and reconfigure the ASA's, apparently it worked.
