VPN
Cisco CyberSecurity
Labels
Hi! The last weeks it has been a big increase of brute force attempts from all over the world to our Cisco ASAs. We use two factors, so we're not to afraid that they will actually access any of our accounts, but the problem is that they manage to blo...
Sonflaa by Level 1
  • 76 Views
  • 5 replies
Following upgrading to upgrading to 5.1.2.42 to fix the vulnerability CVE-2024-20337Within Microsoft Defender this is still flagged as vulnerability for the CVEIt appears to refer to a component of the install:C:\Program Files (x86)\Cisco\Cisco Secur...
ansto by Level 1
  • 183 Views
  • 3 replies
Hi, We are trying to implement Azure SAML SSO on our Firepower 1010. We are using ASA 9.19.1 and Secure client 5.0.02075. When we try the login via Azure by clicking the "Test this applicaton" the login works and there are no errors in the logs. The ...
I am using Cisco AnyConnect Secure Mobility Client version Version 4.10.07062 on my Windows 10 system to connect to our office VPN. From past few days I am experiencing a weird issue where my Internet speed is reduced by 96-97% after connecting to VP...
Hi, I have one issue with IPSec tunnel Lan-to-Lan between ASA 5525x (v9.8) and ASA FPR 2110 (v9.16). My Tunnel is up but ping between each client was not successful. Both peer status sh cry isakmp sa in "MM_ACTIVE".I ran packet-tracer icmp between pe...
El Rondo by Level 1
  • 728 Views
  • 30 replies
We have clients receiving a "PKCS12 (PFX) without a supplied password" error while connecting to RAVPN using Cisco Secure Client (5.1.2.42). The headend device is FTD 3130.The full error is "There was an erro during initialization: PKCS12 (PFX) witho...
