Trouble connecting using Any Connect and Ipsec VPN Client
mrkylewood
I'm having trouble connecting with Any Connect VPN client.  I can connect with Ipsec VPN client in Windows 7 32 bit.
Here is my latest running config.
Thank you for taking the time to read this over.
passwd W/KqlBn3sSTvaD0T encrypted
no names
name 192.168.1.117 kylewooddesk description kyle
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa822-k8.bin
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
domain-name wood.local
same-security-traffic permit intra-interface
object-group service rdp tcp
description rdp access
port-object eq 3389
access-list outside_access_in extended permit tcp any interface outside eq 3389
access-list outside_access_in extended permit tcp any interface outside eq 8080
access-list outside_access_in extended permit tcp any interface outside eq 3334
access-list outside_access_in extended permit ip 192.168.5.0 255.255.255.240 192.168.1.0 255.255.255.0
access-list woodgroup_splitTunnelAcl standard permit host 192.168.1.117
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.5.0 255.255.255.240
access-list outside_access_in_1 extended permit tcp any host 192.168.1.117 eq 3389
access-list woodgroup_splitTunnelAcl_1 standard permit 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound_1 extended permit ip 192.168.1.0 255.255.255.0 192.168.5.0 255.255.255.240
access-list inside_nat0_outbound_1 extended permit ip 192.168.5.0 255.255.255.240 any
access-list inside_test extended permit icmp any host 192.168.1.117
no pager
logging enable
logging timestamp
logging asdm informational
logging debug-trace
mtu inside 1500
mtu outside 1500
ip local pool Kyle 192.168.5.1-192.168.5.10 mask 255.255.255.0
ip local pool vpnpool 192.168.1.220-192.168.1.230
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
global (inside) 1 interface
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound_1
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 3389 192.168.1.117 3389 netmask 255.255.255.255  dns
static (inside,outside) tcp interface 8080 192.168.1.117 8080 netmask 255.255.255.255
static (inside,outside) tcp interface 3334 192.168.1.86 3334 netmask 255.255.255.255
static (inside,inside) 75.65.238.40 192.168.1.117 netmask 255.255.255.255
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
webvpn
  file-browsing enable
  file-entry enable
  http-proxy enable
  url-entry enable
  svc ask none default svc
aaa authentication http console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 8.8.8.8 8.8.4.4
dhcpd lease 3000
dhcpd address 192.168.1.100-192.168.1.130 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
svc image disk0:/anyconnect-win-2.4.1012-k9.pkg 1
svc enable
group-policy sslwood internal
group-policy sslwood attributes
vpn-tunnel-protocol svc webvpn
webvpn
  url-list none
group-policy woodgroup internal
group-policy woodgroup attributes
dns-server value 8.8.8.8 8.8.4.4
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value woodgroup_splitTunnelAcl_1
username mrkylewood password Q4339wmn1ourxj9X encrypted privilege 15
username mrkylewood attributes
vpn-group-policy sslwood
vpn-simultaneous-logins 3
group-lock value sslwood
webvpn
  svc ask none default webvpn
tunnel-group woodgroup type remote-access
tunnel-group woodgroup general-attributes
address-pool Kyle
default-group-policy woodgroup
tunnel-group woodgroup ipsec-attributes
pre-shared-key *****
tunnel-group sslwood type remote-access
tunnel-group sslwood general-attributes
address-pool Kyle
authentication-server-group (inside) LOCAL
authentication-server-group (outside) LOCAL
default-group-policy sslwood
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect ip-options
policy-map type inspect dns MY_DNS_INSPECT_MAP
parameters
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination address http https://tools.cisco.com/its/service/...es/DDCEService
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:6fa8db79bcf695080cbdc1159b409360
: end
asawood(config)#
Jennifer Halim
Also need to add the following:
webvpn
    tunnel-group-list enable
exit
tunnel-group sslwood webvpn-attributes
    group-alias sslwood enable
Let us know if it works.
12 Replies 12
Jennifer Halim
webvpn
exit
Jennifer, that worked!!  But I can't access any of my inside resources.  What could be the problem?
Hello Kyle,
Can you give it a try to the following:
clear configure access-list inside_nat0_outbound_1
access-list  inside_nat0_outbound_1 permit ip 192.168.1.0 255.255.255.0 192.168.5.0 255.255.255.0
If that does not make a difference please provide us the following?
Packet-tracer input inside tcp 192.168.5.2 1025 192.168.1.2 80
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Add the split tunnel policy as well:
access-list sslwood_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
     split-tunnel-network-list value sslwood_splitTunnelAcl
I tried both suggestions.  I'm still unable to open explorer in windows and enter \\192.168.1.117 and view the shares on that drive.
Here is the packet tracer
asawood(config)# Packet-tracer input inside tcp 192.168.5.2 1025 192.168.1.2 80
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.1.0     255.255.255.0   inside
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: NAT-EXEMPT
Subtype: rpf-check
Result: ALLOW
Config:
  match ip inside 192.168.1.0 255.255.255.0 inside 192.168.5.0 255.255.255.0
    NAT exempt
    translate_hits = 0, untranslate_hits = 1
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
  match ip inside any inside any
    dynamic translation to pool 1 (192.168.1.1 [Interface PAT])
    translate_hits = 1, untranslate_hits = 0
Dynamic translate 192.168.5.2/1025 to 192.168.1.1/6605 using netmask 255.255.255
.255
Phase: 8
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
Phase: 9
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 11
Type: NAT
Result: ALLOW
Config:
Phase: 12
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Hello Kyle,
Can you provide us the No_Nat configuration again.
Julio Carvajal
this is my running config
User Access Verification
Password:
Password:
Type help or '?' for a list of available commands.
asawood> enable
Password: ******
Invalid password
Password: **********
asawood# conf t
asawood(config)# show run
: Saved
ASA Version 8.2(2)
hostname asawood
enable password W/KqlBn3sSTvaD0T encrypted
no names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
port-object eq 3389
89
no pager
logging enable
logging timestamp
logging debug-trace
mtu inside 1500
mtu outside 1500
arp timeout 14400
5.255  dns
5.255
.255
webvpn
  file-entry enable
  http-proxy enable
  url-entry enable
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3000
dhcpd enable inside
webvpn
enable outside
svc enable
webvpn
  url-list none
webvpn
address-pool Kyle
address-pool Kyle
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect ip-options
parameters
call-home
profile CiscoTAC-1
  no active
CEService
Cryptochecksum:e07ba8b053b7e3d16726ff27e725d947
: end
asawood(config)#
Hello Kyle,
So basically this time you are able to connect,you get to the portal and select the sslwood tunnel group.
You get an ip address on the 192.168.5.0 range but you are still  unable to access the internal resources..
That is what is happening right now right?
Julio
Julio Carvajal
Yes, Julio, that is correct.
I would say the configuration looks good,
What kind of traffic are you trying to send. No traffic is being able to get to the Local lan from the anyconnect clients.
What happens if you add the:
managment-access inside and then try to ping the inside interface?
Julio Carvajal
It looks like the command
fixed it.
I'm able to access inside resources, thanks for all your help!!
Great to hear, and thanks for your update. Pls kindly mark the post answered, thanks.
