252
Highlighted
Beginner
Unable to ping to ASA outside interface
Hi all,
Below in the configuration in ASA0, still unable to ping to outside interface gi/2, pls help
interface GigabitEthernet1/1
nameif inside
security-level 0
interface GigabitEthernet1/2
nameif outside
security-level 100
ip address 100.100.100.2 255.255.255.0
interface GigabitEthernet1/3
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/4
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/5
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/6
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/7
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/8
no nameif
no security-level
no ip address
shutdown
interface Management1/1
management-only
no nameif
no security-level
no ip address
object network LAN
subnet 192.168.1.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 100.100.100.1 1
access-list in_to_internet extended permit tcp any any
access-list in_to_internet extended permit icmp any any
access-group in_to_internet in interface outside
object network LAN
nat (inside,outside) dynamic interface
2 REPLIES 2
VIP Advisor RJI VIP Advisor
VIP Advisor
Re: Unable to ping to ASA outside interface
You need to change the security-levels on your inside and outside interfaces. Inside should be 100 and outside should be 0. I assume you are pinging from the other ASA on 200.200.200.1? Make the changes below and try again.
nameif inside
security-level 100
nameif outside
security-level 0
Beginner
I have corrected security level, but also no luck
