12-12-2012 08:43 AM
Hi everyone
We have the following scenario:
Connections:
Users successfully establish a VPN connection, but the connection periodically drops with ASA, do you know what is the problem .
or how can i fix it .
crypto isakmp identity address
crypto isakmp enable QL
crypto isakmp enable management
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet 0.0.0.0 0.0.0.0 Inside183
telnet 10.4.1.0 255.255.255.0 management
telnet timeout 60
ssh 0.0.0.0 0.0.0.0 Inside183
ssh 189.203.27.61 255.255.255.255 QL
ssh timeout 5
console timeout 0
management-access Inside183
dhcpd address 10.4.1.2-10.4.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_TrustPoint1 OUTSITE
ssl trust-point ASDM_TrustPoint1 QL
webvpn
enable QL
svc enable
tunnel-group-list enable
smart-tunnel list asavpn 01 outlook.exe platform windows
smart-tunnel auto-signon appserver use-domain host rexchmx
group-policy Test internal
group-policy Test attributes
wins-server value 192.168.180.10 192.168.160.10
dns-server value 192.168.180.10 192.168.160.10
vpn-tunnel-protocol l2tp-ipsec
default-domain value berry.net
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
group-policy asavpn internal
group-policy asavpn attributes
vpn-tunnel-protocol svc webvpn
split-tunnel-policy excludespecified
split-tunnel-network-list value outside_access_in
webvpn
url-list value RjocoFiles
svc ask none default webvpn
customization value DfltCustomization
smart-tunnel auto-signon enable appserver domain berry.net
group-policy BERRYVPN internal
group-policy BERRYVPN attributes
wins-server value 192.168.180.10 192.168.140.10
dns-server value 192.168.180.10 192.168.140.10
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split_tunnel
tunnel-group 206.104.22.2 type ipsec-l2l
tunnel-group 206.104.22.2 ipsec-attributes
pre-shared-key **
tunnel-group asa-joco type remote-access
tunnel-group asa-joco general-attributes
address-pool test
authentication-server-group AD-Radius
authentication-server-group (Inside) AD-Radius
authorization-server-group AD-Radius
authorization-server-group (Inside) AD-Radius
accounting-server-group AD-Radius
default-group-policy asavpn
encryption 3des
hash md5
group 2
lifetime 86400
telnet timeout 60
ssh timeout 5
console timeout 0
webvpn
enable QL
svc enable
webvpn
pre-shared-key **
address-pool test
12-12-2012 03:49 PM
I find it the solution
This has to happen on the remote computer. The PCF file can be edited by first opening Notepad. Once notepad is open, under File Types, select "All Files". Then navigate to C:\Program Files\Cisco Systems\VPN client\Profiles. In our situation, the only PCF file that contained line I was looking for was in the SW VPN General.pcf file.
The line you're looking for is titeled ForceKeepAlives. By default, it's set to "0". You want to change that to "1
or
add the line ForceKeepAlives=1
