337
Beginner
VPN Between ASA 5510 and Unknown Firewall.
Hello all.
I set the asa Vpn to connect to the other firewall, the VPN is ok but when i see the logs of bytesTX and BytesRX the asa receive a lot of packages in BytesRX but dont send anything in BytesTX.
Someone have experienced this problem?
Thanks for help
Everyone's tags (4)
1 REPLY 1
Highlighted
Contributor
Can you check with the packet capture wizard if there are any outbound ESP packets to the VPN endpoint?
Also in Monitoring Tab (ASDM) check the details of the Site-2-Site if the tunnel is finally up.
Michael Please rate all helpful posts
