355
Beginner
VPN concentrator dropping wireless connections
I am getting disconnects from my VPN clients for a VPN concentrator 3000.
clients a thin terminals with cisco wireless cards connected to 1100 access points going through ISA 2004 server.
The concentrator logs show the following disconnects
15054 05/30/2005 11:26:11.620 SEV=5 IKE/50 RPT=197 172.21.0.14
Group [IPS-SAFE] User [TTWXP-WA56101]
Connection terminated for peer TTWXP-WA56101.
Reason: Peer Terminate
Remote Proxy 172.31.0.12, Local Proxy 0.0.0.0
15057 05/30/2005 11:26:11.620 SEV=5 IKE/194 RPT=214 172.21.0.14
Sending IKE Delete With Reason message: No Reason Provided.
15059 05/30/2005 11:26:11.630 SEV=4 AUTH/28 RPT=215 172.21.0.14
User [TTWXP-WA56101] Group [IPS-SAFE] disconnected:
Session Type: IPSec/TCP
Duration: 0:52:11
Bytes xmt: 136896
Bytes rcv: 74672
Reason: User Requested
1 REPLY 1
Highlighted
Beginner
Re: VPN concentrator dropping wireless connections
hi,
Which image you are using on concentrator? try to upgrade your image 4.1.7.F. It will reslove your problum.
Mustafa
