04-30-2013 06:29 AM - edited 02-21-2020 06:51 PM
we have upgradet our AnyConnect Client from V3.0.4235 to V3.1.03103. After the upgrade, I can me authenticate with RSA. After authentication, the AnyConnect will startup the connection but it failed with the error message "VPN connection terminated, Smartcard Error". We use the mashine certificate to encrypt the SSL-connection. We don't use smart cards. When I disable the smartcard reader (DELL Wireless 5540 HSPA Mini-Card USIM Port) in the device manager, the connection is established.
In the version 3.0.08057 it works too. The error is only from verion 3.1.03103 and only on Windows 7 Prof. Under Win XP it works.
How can I disable the query the smartcard?
Thanks for help or answers.
Daniel
05-01-2013 11:31 AM
Hi Daniel,
This is a known issue on systems with the Dell 5540, and 5550 card, Cisco bug ID is CSCue30862. You cannot disable querying of this card. The fix for this issue is in the next release of AnyConnect.
Steve S.
05-08-2013 07:14 AM
Hi Steve,
We are having the same issue. Do you have any idea when the next release is? Is this in weeks months, etc, etc? Otherwise we have to think of a workaround
Marcel
05-08-2013 07:54 AM
Hi Marcel,
This release should be available in the next month or so. Sorry, but I don't have an exact date.
Steve S.
06-13-2013 03:08 AM
Same issue here with client 3.1.02040 and
several hw clients not only dell.
