Highlighted
Beginner
VPN Dual Nic Access Problem
Here is how the network looks like:
192.168.16.0---SBS2003---192.168.2.0---ASA5505---Site-To-Site-VPN---ASA5505---192.168.1.0---RT-N66U---192.168.3.0
VPN Works
I can access everything from 16.0 to 3.0 and vice versa.
I need to access 3.0 from the SBS2003. But it does not work most likely due to the double nic situation and it using the outside 2.x address.
Is there anything I could do to make this work? Any windows or ASA settings I could change without messing with the overall network configuration? Any help would be greatly appreciated.
Thanks.
Everyone's tags (5)
1 ACCEPTED SOLUTION
VIP Advisor
Make sure you incldue 192.168.2.0/24 in the crypto domains and it should work.
1 REPLY 1
VIP Advisor
