VPN problem behind ASA5505 -regular translation creation failed for protocol 50
Zoltan Adler
Dear All,
I have to connect behind my ASA5505 with an VPN klient to an other site.
First time i got this failure.
"Deny protocol 50 src inside:192.168.50.X dst  outside:x.x.x.x by access-group "acl_in" [0x0, 0x0]"
Than I opened our inside (src 192.168.50.0) network  the UDP 500,4500 TCP 500,4500,10000 and ESP (dest x.x.x.x remote firewall ip).
access-list acl_in extended permit esp host 192.168.50.0  host x.x.x.x eq isakmp
access-list acl_in extended permit udp host 192.168.50.0  host x.x.x.x eq 500
access-list acl_in extended permit eudp host 192.168.50.0  host x.x.x.x eq 4500
etc.
After that i could connect for the remote firewall with vpn client but i couldn't reach any PC1s on there side and ping gives back no anwser.
Deny protocol 50 was solved but i got an other problem:
"regular translation creation failed for protocol 50 src  inside:192.168.50.X dst outside:x.x.x.x"
I found somewhere thet lines can help:
crypto isakmp nat-traversal
inspect ipsec-pass-thru
But this wasn't usefull.
I tried a many thing but i'm stuck.
Could somebody help me what can i do to solve this problem?
Thanks for all anwsers!
andrew.prince
Level 10
Level 10
The issue is the remote end - have them enable IPSec Pass-Thru/NAT Traversal.
Thank you for your aswer and i will forward it for the remote side administrator!
The solution was the following for one IP!
object network x.x.x.x                      (inside IP)
   host x.x.x.x                                  (inside IP)
   nat (inside,outside) static y.y.y.y     (remote IP)
