Beginner
VPN Site to Site with IPSec and CA Certificates
I have to configure a VPN tunnel site to site with IPSec and CA certificate but when I try to paste the certificate the router give me an error.
I have two certificates of the other side of the IPSec tunnel.
I couldn't find a howto to implement this configuration.
Some one know some tutorial for a configuration like this?
Thanks.
Everyone's tags (6)
10 REPLIES 10
Hi Carlos ,
what is the error you are seeing when pasting the certificate ? what are the steps you are using to enroll the router ?
you can check this :
http://www.cisco.com/en/US/docs/solutions/Enterprise/Security/DCertPKI.html
Hope that this helps .
Mohammad.
Highlighted
Beginner
Hi Mohammad
Thanks for your reply. The problem with the certificate was that can't copy all the certificate at the same time. I had to copy line by line.
Now I have another issue. I create this:
Phase 1:
crypto isakmp policy 10
authentication rsa-sig
encr 3des
hash md5
group 2
But I don't know how assign the CA Certitifacte for this configuration.
I took a test in packettracert with pre-share keys and works fine but, how can I use rsa-sig?
Eg: crypto isakmp key "passwd123" address "192.168.0.2"
Phase 2:
crypto ipsec transform-set SET esp-3des esp-md5-hmac
Enthusiast
Re: VPN Site to Site with IPSec and CA Certificates
Here is how to do it:
1- have a windows 2003 Server with iis installed,
2- install Certificate Authority (CA) service on the Windows 2003,
3- install microsoft SCEP,
4- Configure the Certificate Authority to issue certificate immediately.
on the router, do this:
1- assign a hostname,
2- assign domain-name
3- generate a crypto rsa key
4- the following commands on both routers:
crypto pki trustpoint cciesec
  enrollment url http://ip-address-of-the-windows-2003:80/certsrv/mscep/mscep.dll
  no revocation-check
  exit
crypto pki authenticate cciesec
crypto pki enroll cciesec
now your routers can do IPSec with each other via certificates.
Easy right?
Beginner
Thank David,
Could I not do that without Windows 2003 Server? I only know one part of the tunnel. The other side is configured with its digital certificates. I think it are the same that I have.
Could I not use the router as CA server?
I only have one Cisco 887 and 2 computers with XP. This not enough?
Enthusiast
I have never had to use router as CA server but it can be done because the concept is the same.  However, if you're going to use the router as a CA server, it has to be a dedicated router.  The CA server can not be on the same router that terminates VPN.  I could be wrong on that part but that how I remember it.
Beginner
Carlos; you can use a router as a CA server, I hve a practice lab that I made that has something similar to what you are looking for. Instead of a site-to-site VPN my lab uses a GRE-over-IPSec tunnel.
Here is the network diagram and configs:
1. First configure all of the requirements (routing, interfaces, NTP, generating certificates, CA server, etc.)
- CA router -
hostname CA-RTR
ip domain name TEST
ntp master
ip ssh ver 2
crypto key generate rsa general-keys label CA-RTR modulus 2048 exportable
crypto key export rsa CA-RTR pem url nvram: 3des !Q@W#E$R5t
ip http server
crypto pki server CA-SVR
database url nvram:
issuer-name CN=CA-SVR.CA-RTR.TEST
lifetime ca-certificate 365
no shut
interface Loopback0
ip address 10.10.0.0 255.255.255.255
interface FastEthernet0/0
ip address 192.168.255.1 255.255.255.254
speed 100
full-duplex
no shut
interface FastEthernet0/1
ip address 192.168.255.2 255.255.255.254
speed 100
full-duplex
no shut
speed 100
full-duplex
no shut
end
- RTR1 -
hostname RTR1
ip domain name TEST
interface Loopback0
ip address 10.10.1.1 255.255.255.0
ip address 192.168.255.0 255.255.255.254
speed 100
duplex full
no shut
ip address 192.168.255.4 255.255.255.254
speed 100
duplex full
interface Tunnel0
ip address 172.16.255.0 255.255.255.254
keepalive 10 3
tunnel source 192.168.255.4
tunnel destination 192.168.255.5
ip route 0.0.0.0 0.0.0.0 192.168.255.1
ntp server 10.10.0.0
ip ssh ver 2
crypto key generate rsa modulus 2048
crypto pki trustpoint CA-SVR
enrollment url http://10.10.0.0:80
revocation-check none
crypto pki auth CA-SVR
crypto pki enroll CA-SVR
end
- RTR2 -
hostname RTR2
ip domain name TEST
interface Loopback0
ip address 10.10.2.1 255.255.255.0
ip address 192.168.255.3 255.255.255.254
speed 100
duplex full
no shut
ip address 192.168.255.5 255.255.255.254
speed 100
duplex full
no shut
interface Tunnel0
ip address 172.16.255.1 255.255.255.254
keepalive 10 3
tunnel source 192.168.255.5
tunnel destination 192.168.255.4
ip route 0.0.0.0 0.0.0.0 192.168.255.2
ip ssh ver 2
end
2. After the CA server is running, finish configuring the remaining routers.
   a. In a real network, before accepting a certificate from the CA server, you should make sure that the Fingerprint
       MD5 certificate matches the one that is displayed on the CA-RTR after entering the following command:
          show crypto pki server
   b. On the CA-RTR view and grant the pending certifcates by entering the following commands:
          crypto pki server CA-SVR info requests
          crypto pki server CA-SVR info grant all
- RTR 1 -
ip access-list extended VPN-TRAFFIC
permit gre host 192.168.255.4 host 192.168.255.5
crypto ikev2 proposal PHASE-1
encryption aes-cbc-256
integrity sha256
group 14
crypto ikev2 policy VPN-POLICY
proposal PHASE-1
crypto ikev2 profile RTR1-RTR2-PROFILE
match identity remote fqdn RTR2.TEST
identity local fqdn RTR1.TEST
authentication remote rsa-sig
authentication local rsa-sig
crypto ipsec transform-set PHASE-2 esp-aes 256 esp-sha256-hmac
mode tunnel
crypto map VPN-MAPS 10 ipsec-isakmp
set peer 192.168.255.5
set transform-set PHASE-2
set ikev2-profile RTR1-RTR2-PROFILE
match address VPN-TRAFFIC
crypto map VPN-MAPS
end
- RTR2 -
permit gre host 192.168.255.5 host 192.168.255.4
integrity sha256
group 14
proposal PHASE-1
crypto ikev2 profile RTR2-RTR1-PROFILE
match identity remote fqdn RTR1.TEST
identity local fqdn RTR2.TEST
mode tunnel
set peer 192.168.255.4
set ikev2-profile RTR2-RTR1-PROFILE
crypto map VPN-MAPS
end
-You can test the configuration by doing an extended ping from RTR1's loopback interface to RTR2's loopback interface:
          ping 172.16.255.1 source 172.16.255.0
Beginner
Hello  jorgeramos78
Is it mandatory to copy the Cetificate from one router to another one ?
I tried your configuration on my 3800 routers but the router doesn't give to configure what is ikev2 ?
thanks
Roee
Beginner
Sorry, but I don't work on security full-time so I am not 100% sure if it is mandatory to copy the certificate from router to router. The example that I posted was just a proof of concept.
Regarding IKEv2; I am not sure if 3800 series routers support it. The new integrated service router do support it, but you need to be using the correct IOS version and possibly purchase the appropriate license.
Beginner
Hi David,  Can u pls provide me the steps to configure CA & SCEP on Windows 2003 server.  Also how to configure the Certificate Authority to issue certificate.  Awaiting your reply.
Beginner
I suspect the cert is not printable probable UTF8 string. Make sure your cert is a printable cert string you are putting on a cisco device.
