Highlighted
Beginner
VPN tunnel not starting
Hello, I have a CISCO 5505 with ASDM version 6.2 and ASA version 8.2, which is broken. I replaced it with a CISCO 5505 , but the ASDM version is 7 and the ASA version is 9.0.1
The connection of the OLD CISCO looks like :
STORED POLICY
Secure Unit Authentication Enabled : Policy not stored
Split Tunnel Networks              : None
Backup Servers                     : None
RELATED CONFIGURATION
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.1.128 255.255.255.248
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 10.10.10.0 255.255.255.240
access-list inside_nat0_outbound extended permit ip any object cisco
access-list inside_nat0_outbound extended permit ip any 10.0.0.16 255.255.255.240
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 object Genk
access-list outside_access_in extended permit tcp any host 192.168.1.7 eq 3390
access-list outside_access_in extended permit ip any 192.168.1.0 255.255.255.0
access-list outside_access_in extended permit tcp any interface outside eq https
access-list outside_access_in extended permit tcp any 192.168.1.0 255.255.255.0 eq ssh
access-list outside_access_in extended permit udp any any eq isakmp
access-list outside_access_in extended permit udp any any object-group VPN
access-list outside_access_in extended permit tcp any interface outside eq 9675
access-list outside_access_in extended permit tcp any interface outside eq 9676
access-list outside_access_in extended permit tcp any interface outside eq 3400
access-list outside_access_in extended permit tcp any interface outside eq smtp
access-list outside_access_in extended permit tcp any interface outside eq 50001
access-list outside_access_in extended permit tcp any interface outside eq 40001
access-list outside_access_in extended permit tcp any interface outside eq 50002
access-list outside_access_in extended permit tcp any interface outside eq 50003
access-list outside_access_in extended permit tcp any interface outside eq 50004
access-list outside_access_in extended permit tcp any interface outside eq 50005
access-list inside_access_in extended permit ip 192.168.1.0 255.255.255.0 any
access-list Consenso_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list outside_cryptomap extended permit ip 192.168.1.0 255.255.255.0 object Genk
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto map outside_map 1 match address outside_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 81.99.99.99
crypto map outside_map 1 set ikev1 transform-set ESP-3DES-SHA
crypto map outside_map 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp nat-traversal 3600
AND the new one looks like :
STORED POLICY
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 Genk 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 Genk 255.255.255.0
access-list inside_nat0_outbound extended permit ip any VPN 255.255.255.248
access-list inside_nat0_outbound extended permit ip any host Cisco
access-list outside_access_in extended permit tcp any host TSTongeren object-group RDP
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto isakmp enable outside
crypto isakmp policy 10
 authentication pre-share
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto isakmp ipsec-over-tcp port 10000
I noticed NAT rules looks different as EXEMPT rules cannot be created anymore, but Internet is working when I connect the new one. But the VPN connection does not want to start ?
Can any expert have a look at it and help me get this working ?
4 REPLIES 4
Beginner
Hi Troosters,I hope you're
Hi Troosters,
I hope you're doing great
Could you please attach the current running configuration of  the new ASA? I noticed that you are missing some information but I would need to verify the configuration first. You could also take some debugs to see why the connection is not working. Please use the following debugs:
debug crypto condition peer x.x.x.x >>>> Public IP address where the client is connecting from (You can use whatismyip.com to find that out.
debug crypto ikev1 200
debug crypto ipsec 200
Luis.
Beginner
Hereby I post the config ZIP
Hereby I post the config ZIP file. I must say, I cannot test the new config on the live system right now as the "old" CISCO is still connected and the VPN is crucial.
VIP Advocate
The following command is the
The following command is the problem:
nat (any,outside) source dynamic any interface
You are using dynamic NAT in the manual NAT section and it is placed above all your other NAT statements...Here is the copy past from your config file
nat (inside,outside) after-auto source static LOCAL_LAN LOCAL_LAN destination static REMOTE_LAN REMOTE_LAN
nat (any,outside) after-auto source dynamic 192.168.1.7 interface service 3390 3390
nat (any,any) after-auto source static any any
Manual NAT is matched first then auto NAT and then after-auto manual NAT.
So here is what I suggest you do.
1.
no nat (any,outside) source dynamic any interface
nat (any,outside) after-auto source dynamic any interface
2.
no nat (inside,outside) after-auto source static LOCAL_LAN LOCAL_LAN destination static REMOTE_LAN REMOTE_LAN
nat (inside,outside) source static LOCAL_LAN LOCAL_LAN destination static REMOTE_LAN REMOTE_LAN
3.
no nat (any,outside) after-auto source dynamic 192.168.1.7 interface service 3390 3390
nat (any,outside) source static192.168.1.7 interface service 3390 3390
4. This statement is not needed
no nat (any,any) after-auto source static any any
As Karthik has mentioned your outside_access_in ACL should specify the private IP of the NATed server and not the ASA outside interface (public IP).
Please remember to select a correct answer and rate helpful posts
Please remember to rate and select a correct answer
Rising star
Hi, Your NAT exempt rules
Your NAT exempt rules should be created like this, which is very important change in post 8.3 Version.....
eg:
for this acl line
object network locallan
subnet 192.168.1.0 255.255.255.0
object network remotelan
subnet 10.10.10.0 255.255.255.240
nat (inside,outside) source static locallan locallan destination static remotelan remotelan no-proxy-arp.
Like this you have to create multiple objects for source and destination and do nat-exempt...... make sure you created different object group names even though you used the same subnet..... objects can be used once in your config....
And also you ACL's should be real address...... in 8.2 for outside interface acl will have the NATed IP.... here you should give real ip address..... if any.....
Karthik
